Stepp Posted January 18, 2011 Posted January 18, 2011 1998 W129 -- Riknula mi jedna; kratko svjetlo. Kako se to gleda kod generičkih žarulja; postoji više modela prihvata ili?
Coupe VD Posted January 18, 2011 Posted January 18, 2011 D2R vrlo vjerojatno...ako se radi o klasičnom reflektorskom faru. Naprimjer, ona stara S klasa je imala D2R.
Vlado206 Posted January 18, 2011 Posted January 18, 2011 Stepp said: Price? Where? hitno Ako ti je HITNO. Chipoteka, cca 130kn komad, D2s, vjerujem da imaju i d2r, samo moraš znat koja ti točno ide
dvoracek Posted January 18, 2011 Posted January 18, 2011 mjenja se u paru zbog svjetla, da nebi razlicito svjetlilo. 250 kn imam jos dva para d2s žarulje. probam provjeriti sad dal ide d2s ili d2r. d2s su puno cesce.
Vlado206 Posted January 18, 2011 Posted January 18, 2011 dvoracek said: mjenja se u paru zbog svjetla, da nebi razlicito svjetlilo.250 kn imam jos dva para d2s žarulje. probam provjeriti sad dal ide d2s ili d2r. d2s su puno cesce. Možeš li provjerit za Mercedes ML w163 2002godina, ima leću. Hvala puno :thumbsup:
pacey Posted January 18, 2011 Posted January 18, 2011 Stepp said: Tnx. Jens ha? jens clan sa foruma, ce znat i koja ide i vjerojatno ju imat za prodat novu
dvoracek Posted January 18, 2011 Posted January 18, 2011 (edited) Vlado tvoja je ipak D2R M class (W163) with Xenon 1998-2005 D2R Xenon H7 B-03 H8 B-13 PY21W B-22 LED W5W B-28 PY21W B-22 P21W B-21 P21/4W B-20 P21/4W B-20 P21W B-21 C5W B-25 Stepp tvoja je D2S SL (W129) with Xenon 1994-2001 D2S Xenon H1 B-04 H3 B-05 PY21W B-22 WY5W B-33 W5W B-28 P21W B-21 P21/4W B-20 P21/4W B-20 P21/4W B-20 P21W B-21 C5W B-25 http://www.gelighting.com/eu/product_portfolio/automotive/manufacturers/auto_spec.html?mercedes Edited January 18, 2011 by dvoracek
dvoracek Posted January 18, 2011 Posted January 18, 2011 da. Ja trenutno nemam d2r ali imam d2s 250 kn par
Jens Posted January 18, 2011 Posted January 18, 2011 A mogu samo potvrdit, u projektor tj. lecu ide D2S, u reflektor ide D2R. Mislim da imam i jednih i drugih. D2S imam i original philips, mislim da je oko 500kn par s 1 god. garancije.
Stepp Posted January 18, 2011 Author Posted January 18, 2011 2 jens: smatraj da kupujem, samo da vidim koje su
dvoracek Posted January 19, 2011 Posted January 19, 2011 jens: to i ja kazem, al izgleda da onda ovi imaju krivo napisano u GE lightning. I meni je isto bilo jasno do sad da u lecu idu d2s, a u obican far d2r. Nego... dobra cijena za par philipsa...
Vlado206 Posted January 19, 2011 Posted January 19, 2011 Jens said: A mogu samo potvrdit, u projektor tj. lecu ide D2S, u reflektor ide D2R.Mislim da imam i jednih i drugih. D2S imam i original philips, mislim da je oko 500kn par s 1 god. garancije. Kako saznat okoXpi metodom? Jer, i ja sam čuo i sve da d2s ide u leću, a na ovoj stranici mi stoji da ML ima d2r u leći...
Jens Posted January 19, 2011 Posted January 19, 2011 2 vlado: mozda onda nije za lecu. Jer nemaju svi ML-ovi lecu, ima ih i sa reflektorom. Zavisi ti i od trzista... 2 stepp: danas cu znat za orig. philips..
Vlado206 Posted January 19, 2011 Posted January 19, 2011 u reflektor ide h7 kako saznat koja je sigurno? to me zanima
Jens Posted January 19, 2011 Posted January 19, 2011 Da, ide h7 ak je halogen. Sa D2S ne mozes fulat za projektor.
Jens Posted January 19, 2011 Posted January 19, 2011 E da, cijena za par d2s philips je 650kn s garancijom, naravno ima samo 4100K. Ja sam krivo skuzio, kolega mi je imao na akciji original philips D1S za 500kn/kom.
