Risbo Posted June 17, 2011 Posted June 17, 2011 Gledam malo 2 DIN HU-ove... pa sam naletio recimo na ovo... čini mi se vrlo ok cijena... jel valja to šta? http://www.emmezeta.hr/multimedija/audio/auto-radio/15900/autoradio-cdmp3usb-jvc-kw-xr611ey/ ako netko zna neki dobar da se prodaje a da nije preko 1000 kn nek viče....
Risbo Posted June 17, 2011 Author Posted June 17, 2011 pa mjerio sam i trebao bi pasati...... a i vidi ovo
Misek_Chipsy Posted June 17, 2011 Posted June 17, 2011 Nesto malo je premalo mjesta...treba neke modifikacije napravit i skidat taj dio armature... Warning: This install will not allow you screw your bezel into place. If you require the bezel to be screwed in, you must modify the bezels face for the radio to slide in from the front rather than the back. Evo upute: http://forums.focaljet.com/ice-car-entertainment/629436-how-fit-double-din-00-04-focus.html
entuzijast Posted June 17, 2011 Posted June 17, 2011 Risbo said: Gledam malo 2 DIN HU-ove...pa sam naletio recimo na ovo... čini mi se vrlo ok cijena... jel valja to šta? http://www.emmezeta.hr/multimedija/audio/auto-radio/15900/autoradio-cdmp3usb-jvc-kw-xr611ey/ ako netko zna neki dobar da se prodaje a da nije preko 1000 kn nek viče.... Ja sam pred tjedan dana kupio model 811, u emmezeti definitivno najjeftiniji i za te pare definitivno best buy od 2 DIN uređaja...
Misek_Chipsy Posted June 17, 2011 Posted June 17, 2011 Ciki_Vts said: Pioneer AVH2300DVD <1000kn.....
Risbo Posted June 17, 2011 Author Posted June 17, 2011 hmmmm, da tog sam se i bojao.... ne bi paš rezao.... možda ipak 1DIN.... Da li postoji 1,5 DIN? nekad sam čuo da ima, ali nisam nigdje uspio naći ništa....
Misek_Chipsy Posted June 17, 2011 Posted June 17, 2011 (edited) imas 1,5DIN, naravno Samo ih je teze nac npr: http://www.njuskalo.hr/auto-mp3-cd-dvd/jvc-kd-avx2-dvd-divx-mp3-oglas-3045052 http://www.njuskalo.hr/auto-mp3-cd-dvd/p-m-auto-dvd-radio-pixatronioc-divx-usb-sd-oglas-2974626 a zasto bas trazis veci od 1DIN? Moj savjet bi bio da zaboravis te 2 i 1.5din i ubodes neki kvalitetnji 1DIN kojih imas barem puno na odabir...imas npr multimedija alpine IVA d105rb vec od nekih 1500kn polovnih pa imas i 7" lcd sa touchem. a za obicni sigle din ima alpine IDA seriju od 1300kn vec nove. Edited June 17, 2011 by Misek_Chipsy
Risbo Posted June 17, 2011 Author Posted June 17, 2011 Daj neki link, di ima, cijena, bilo šta jer ja nisam uspio naći.....
Ciki Posted June 17, 2011 Posted June 17, 2011 Misek_Chipsy said: <1000kn..... Tek sad vidim... risbo, ako ces trebati alpine, javi mi se.
Vlado206 Posted June 17, 2011 Posted June 17, 2011 I mene zanima 2DIN. Kakav je ovaj pajo AVH-3200BT. Nisam trenutno baš previše u tome, zadnji lcd što sam imao je bio audiovox... Bitno mi je da čita cd/mp3/dvd i nebi bilo loše da ima priključak za usb npr. Naravno, svima dvd i to radi u vožnji? Ona fora s kabelom za ručnu kao masa (tako nekako) igra još uvijek? Plavo-crveno osvjetljenje bi bilo poželjno iako nikad nisam gledao na to Ugl, paše mi i polovno, i 1din al da je na izvlačenje tipa Alpine IVA i tako to...
Kroky Posted June 17, 2011 Posted June 17, 2011 taj kabel nemoras vuc da rucne nego ga samo usarafi u kuciste hu-a
matija0311 Posted June 18, 2011 Posted June 18, 2011 jel zna neko za kakav dobar DVD HU da nije preskup..dajem deh 85 BT pod račun
Žile Posted June 18, 2011 Posted June 18, 2011 Ja sam u metrou uzeo prije cca 2-3mj...mislim da ih ima još...ovaj moj je bio oko 800+kn a drugi model je sa bluetoothom oko 1000kn...prezadovoljan sam sa zvukom i brzinom iako to nisam očekivao od JVC-a nakon nekoliko pioneera koje sam imao
Risbo Posted June 19, 2011 Author Posted June 19, 2011 Misek_Chipsy said: imas 1,5DIN, naravno Samo ih je teze nac npr: http://www.njuskalo.hr/auto-mp3-cd-dvd/jvc-kd-avx2-dvd-divx-mp3-oglas-3045052 http://www.njuskalo.hr/auto-mp3-cd-dvd/p-m-auto-dvd-radio-pixatronioc-divx-usb-sd-oglas-2974626 a zasto bas trazis veci od 1DIN? Moj savjet bi bio da zaboravis te 2 i 1.5din i ubodes neki kvalitetnji 1DIN kojih imas barem puno na odabir...imas npr multimedija alpine IVA d105rb vec od nekih 1500kn polovnih pa imas i 7" lcd sa touchem. a za obicni sigle din ima alpine IDA seriju od 1300kn vec nove. Ne bi polovni.... mislio sam veći da bolje zgleda ne treba biti DVD niti ekran neki... samo da ima dobar zvuk, da ima MP3, USB i eventualno SD čitač....
Misek_Chipsy Posted June 19, 2011 Posted June 19, 2011 (edited) Uzmi onda neki kvatetniji pioneer ili alpine 1din sa usbom i nece ti bit zao, a i nemas kemija. P.s. Ja planiram prodat svoj alpine iva d310rb, touchscreen, pulsetouch ovo ono , ekran nit ne koristim, poledao 2 Dvda na njemu, kad ceko na tehnicki , a htio bi nes sa konekcijom za iphone ili HDD pa ak nekog zanima- ponude na pp. Edited June 19, 2011 by Misek_Chipsy
riceburner Posted June 19, 2011 Posted June 19, 2011 risbo, ako ces trebat adapter za radio sa pretincom za dokumente, dodi do mene na kat pa cemo dogovorit nesto meni ostalo od mondea...
