Drag_steer Posted December 8, 2008 Posted December 8, 2008 Imam neku turbinu nenzam nista o njoj, evo tu je slika jedina koju imam za sad, vidi se plocica ali jedan broj se slabo vidi... slika je u jako velikoj rez pa stavljam link http://www.imagesforme.com/out.php/i253994_Slika046.jpg
obie Posted December 8, 2008 Posted December 8, 2008 (edited) koliko ja vidim oznaka joj je K02. bogami nemam pojma di se ugrađivalo to... kod audija 1.8T 150ks je isla kkk k03, 180 k03 modificirana a na 225ks k04 Edited December 8, 2008 by obie
Drag_steer Posted December 8, 2008 Author Posted December 8, 2008 (edited) znaci trebala bi bit manja od tih koje si spomenuo? edit: nasoa sam ovo : The KKK K02 (ex Audi 1.8T) will be a nice turbo to use on the TF if you wanted to build a low pressure conversion with lots of torque gain at the bottom end and not wanting to rev the engine to 6000+ rpm valjda je sa starog 1.8t audija. Edited December 8, 2008 by Drag_steer
obie Posted December 8, 2008 Posted December 8, 2008 pa logicno bi bilo da je nesto manja... sad sam malo googla i uspia san iskopat da se ugrađivala u neke Audije Part number Application C.H.R.A. Service kit A/R Replaced by STATUS K02 5302-988-0001 AUDI 5302-988-0002 AUDI i to je to....
Drag_steer Posted December 8, 2008 Author Posted December 8, 2008 (edited) E hvala ti....evo poslao mi frend sifru cijelu 5003 335 369 K03 034 CL5024341 K03 je , nije K02 izgleda. koliko po plocici vidim sad... edit: znas mozda koliko se krecu cijene takvih turbina za reparaciju? znaci da je lagano sjebana Edited December 8, 2008 by Drag_steer
obie Posted December 8, 2008 Posted December 8, 2008 E hvala ti....evo poslao mi frend sifru cijelu 5003 335 369 K03 034 CL5024341 K03 je , nije K02 izgleda. koliko po plocici vidim sad... na plocici pise k02... čudno. aj sad bar znas di je bila k03. :thumbsup:
obie Posted December 8, 2008 Posted December 8, 2008 sad kad malo bolje pogledam, broj 3 je izlizan pa mi se na brzinu ucinilo da pise 2... ipak pise k03. my bad....
Drag_steer Posted December 8, 2008 Author Posted December 8, 2008 da , izlizan je. znas mozda koliko to dodje ako je za reparaciju? nisam nikad gledao cijene takvih pa nenzam niti otprilike...
obie Posted December 8, 2008 Posted December 8, 2008 da , izlizan je. znas mozda koliko to dodje ako je za reparaciju? nisam nikad gledao cijene takvih pa nenzam niti otprilike... nova novcata turbina u zubaka dode 5800kn + pdv. a kad san pita jednog lika za reparaciju, kaze mi od 2000 do 3000 kn.
Drag_steer Posted December 8, 2008 Author Posted December 8, 2008 a turbina sama koliko dodje, ako je za reparaciju, znaci losa? hvala
obie Posted December 8, 2008 Posted December 8, 2008 a turbina sama koliko dodje, ako je za reparaciju, znaci losa? hvala napisa san ti koliko dode sama turbina kod zubaka. a obicno se preventivno obavi reparacija te turbine, jer joj je navodno vijek trajanja nekih 120tkm.
Drag_steer Posted December 8, 2008 Author Posted December 8, 2008 mislio sam na polovnu. ok, nema veze . hvala na informacijama
Renda Posted December 8, 2008 Posted December 8, 2008 To sam odvagni kolko bi mislio dat za tako nešto... Ako je 7000kn nova, a reparacija ove 3000kn, onda po meni kojih max 2000kn za ovu polovnu (ovisno koliko je razje...). Al opet, to je na tebi da vidiš kolko ti se max isplati dat za zafrkanciju sa time...
Drag_steer Posted December 8, 2008 Author Posted December 8, 2008 ma manja lova je u pitanju, zato bi je i uzeo, nije da mi treba. nije na autu pa nenzam koliko je u kurcu, odnest cu nekome da pogleda. glavno da znam s kojeg je auta.
bravo-ri Posted December 8, 2008 Posted December 8, 2008 ma manja lova je u pitanju, zato bi je i uzeo, nije da mi treba. nije na autu pa nenzam koliko je u kurcu, odnest cu nekome da pogleda. glavno da znam s kojeg je auta. Odi to kod đume reparirat...2000 kn sa garancijom...znam jel sam ga neki dan zvao za hibrid složiti i rekao mi je dva soma sa reparacijom i garancijom :thumbsup:
Drag_steer Posted December 8, 2008 Author Posted December 8, 2008 da kod njega cu odnest da je pogleda, jer neke budu toliko ubijene da se nedaju reparirat.
