bojan25 Posted October 23, 2009 Posted October 23, 2009 pitanje..pošto razmišljam o nabavci nekog wooferčića..ovaj mi se čini dosta ok,s obzirom na cijenu(1099kn,leocommerce) i "ime".i da već ima pojačalo na sebi...kaj mislite o tome ili dajte neki drugi prijedlog za aktivni woofer.thnx ovdje su spec za ovaj EMb 800A active sub main features: Active subwoofer with passive radiator technology in extremely compact enclosure The easiest way to more bass - amplifier and speaker in a box! 200mm drive unit using passive radiator technology Powerful 150Watt Class 'D' amplifier Efficiency 4 ohm Can accept line level (RCA) or speaker level inputs Frequency response 30 - 120Hz Phase regulator (0-180°) adjuster Variable low-pass filter (70 - 200Hz) Gain controls (0.3V - 8.0V) Dimensions 250w x 250h x 270d (mm). Weight 6.6kg Two year manufacturer's warranty Complete with installation guide
