Iggy_R Posted June 21, 2011 Posted June 21, 2011 Imas i jednu dobru u astri Znam. Hvala :lol: Iman ja brusilicu i novi brus, samo ti donesi da je sredin Ako će nakon toga šaltat ko tvoja onda može
bOzO Posted June 21, 2011 Posted June 21, 2011 Hello, The rings are priced £192 each and you will require 2x Delivery is £18 Regards Paul Regal Autosport 72 - 82 Belgrave Rd Portswood Southampton SO17 3AN tel: +44 (0)23 80558636 fax: +44 (0)23 80516455 cav ne odgovara, mitsu ne odgovara - za sada
Iggy_R Posted June 21, 2011 Posted June 21, 2011 Još će na kraju ispast jeftinije dat napravit novi :doh:
Peras Posted June 21, 2011 Posted June 21, 2011 Hello,The rings are priced £192 each and you will require 2x IDEŠ, preskupo jebote, pa ja za EVO getribu nabavija po 30-40 dolara i to mitsu OEM
Iggy_R Posted June 21, 2011 Posted June 21, 2011 IDEŠ, preskupo jebote, pa ja za EVO getribu nabavija po 30-40 dolara i to mitsu OEM A to je to, nakon 2 min zbrajanja je meni bilo jasno da je isplativije kupit drugu getribu nego ić popravljat išta unutra :no2:
Iggy_R Posted June 21, 2011 Posted June 21, 2011 Meni, ali nije ništa hitno, mislim složit ovu getriba šta imam sa strane, nikad se ne zna koliko će ova što je na autu dugo izdržat :doh:
bOzO Posted June 21, 2011 Posted June 21, 2011 treba nam jedno 10komada dalo bi se prodat! vidis ti to Peras ovo je teror od cijene...neznam po cemu, onaj jos uvijek nije odgovorio sa mitsua
mr_G Posted June 21, 2011 Posted June 21, 2011 Ja prodajem svoju f28 za dijelove za 500kn. Ako netko treba... Skinuta sa auta.. Sinkrone nema, tako da to zaboravite.. :lol:
mutni Posted June 21, 2011 Posted June 21, 2011 mrg javi se uzet cu ju ja imam ja sinhrona još jedo 5 komadaa
Fox Posted July 7, 2011 Posted July 7, 2011 (edited) ima tko sinkrone prve i druge za F20? . Edited July 7, 2011 by Fox
mr_G Posted July 7, 2011 Posted July 7, 2011 Stavi F17 ili ako ti se da zaje F23... Daleko bolje jače i modernije getribe sa boljim sinkronima...
Fox Posted July 7, 2011 Posted July 7, 2011 ma treba mi za ovu astru gsi... steka malo prva a malo vise druga a ionako cu mijenjati sve pa dam motor i getribu pod racun pa da bar bude ispravna... ili ako netko ima komplet F20 ispravnu za male novce... .
mr_G Posted July 7, 2011 Posted July 7, 2011 Pa kažem ti da uzmeš F17. Jer bi trebala pasati na isto mjesto gdje je i F20... Samo što je novija i ne zapinje...
Fox Posted July 7, 2011 Posted July 7, 2011 Pa kažem ti da uzmeš F17. Jer bi trebala pasati na isto mjesto gdje je i F20... Samo što je novija i ne zapinje... da... i onda imam 182 km/h krajnju brzinu na 2.0 i 170 konja :lol: .
mr_G Posted July 7, 2011 Posted July 7, 2011 Naprotiv imaš dužu 5-tu, pogotovo ako uzmeš F17WR. Onda imaš 5-tu do 300...
Veki Posted July 7, 2011 Posted July 7, 2011 (edited) Imam ti ja D16 ak si zainteresiran i ak ti se da prebacit na hidrauliku ..getriba + lajtunzi, papučica , kaj god.. 2. 90, 3. 140, 4. 180 , 5. e znam..220-230 .. Edited July 7, 2011 by Veki
Fox Posted July 7, 2011 Posted July 7, 2011 Nemoj ništa kemijati .... F20 stavi i bok... as I said, ili sinkrone ili citavu da mi netko ponudi... cekam .
