dejanR Posted July 23, 2011 Posted July 23, 2011 imam neku kombinaciju za uzeti prednja kljesta od alfe 147 GTA (BREMBO 4 klipa za 305 disk). da li ih mogu na integralku montirati plug&play bez adaptera, da li stanu ispod 16cola OZ SUPERTURISMO WRC?
STFIESTAST Posted July 23, 2011 Posted July 23, 2011 ja imam 300mm disk u 16 cola retardiranoj Dezent felgi sa uvučenim krakovima i lipovima, razmak je par milimetara , ali ide bez greške. ovo za adapter nemam pojma
niknejm Posted July 23, 2011 Posted July 23, 2011 imam neku kombinaciju za uzeti prednja kljesta od alfe 147 GTA (BREMBO 4 klipa za 305 disk). da li ih mogu na integralku montirati plug&play bez adaptera, da li stanu ispod 16cola OZ SUPERTURISMO WRC? ako su klijesta ista kao na fiat coupeu.. idu pod 7x16 ET38, ali zbog specificnog dizajna krakova.. pod 7x17 ET 38 Ultra leggeru ne idu bez distance od 10mm first hand info
STFIESTAST Posted July 23, 2011 Posted July 23, 2011 moja klješta nisu 4 klipna pa su vjerojatno manja , tj. sigurno jesu, po et 35 mi stanu bez problema, sad sam naručio oz alleggerita 16" , et42, pa ćemo vidit hoće li se vrtiti
dejanR Posted July 23, 2011 Author Posted July 23, 2011 Felge su Et 37 i imam distancu 12mm. Kljesta pasu na glavcinu?
dejanR Posted July 24, 2011 Author Posted July 24, 2011 Kakva distanca? Kaj ni razmak rupa na kljestima ne pase?
dejanR Posted July 24, 2011 Author Posted July 24, 2011 Ok, dakle pod felgu ide. Koja bi klješta treba da mi pašu na glavčinu bez adaptera? Od Alfe 147 GTA, Fiat coupe turbo 20V, Delta integrale EVO?
Alfaludak Posted July 24, 2011 Posted July 24, 2011 nijedna diskovi imaju 10 rupa a ti trebas 4 razmak rupa na celjustima je skoro duplo nego ti je na rukavcu
fiatuno Posted July 25, 2011 Posted July 25, 2011 Ok, dakle pod felgu ide. Koja bi klješta treba da mi pašu na glavčinu bez adaptera? Od Alfe 147 GTA, Fiat coupe turbo 20V, Delta integrale EVO? razlika je u glavcinama ne pasu ti bez adaptera ovako adapteri izgledaju
dejanR Posted July 25, 2011 Author Posted July 25, 2011 Znači svejedno mi adapter ne gine. Onda ili opcija coupe turbo klješta brembo ili uzeti od PORSCHEA s radijalnim rupama i opet adapter.
Grga20VT Posted August 3, 2011 Posted August 3, 2011 Ja na glavcini od hgt-a imam kljesta brembo 4-eroklipna sa alfe 166 3.0v6 i dal sam napravit adaptere i nemam problema i imam i diskove s alfe s 10 rupa i neke sam prosiril koji se poklapaju a neke su rupe jos dodane. Izgleda ko svicarski sir ali sve funkcionira vrhunski. I da imam OZ ultralaggera 7*17 et 36 i netreba mi distanca ide bez problema.
