DinkoV Posted April 25, 2012 Report Share Posted April 25, 2012 Znači tražim nekog ko zna isključit dnevna kratka svijetla na Toyoti RAV4 2.2 D-cat,automatik, najjača oprema sa senzorom za mrak iz 2010 godine. U sevisu to ne mogu napravit jer na testeru nema te opcije. (bar su mi tako rekli) Poželjno da to bude na području ZG-VŽ. lp Link to comment Share on other sites More sharing options...
DarioB Posted April 25, 2012 Report Share Posted April 25, 2012 I meni su rekli da ne mogu, ne kuzim kak to nemaju... Link to comment Share on other sites More sharing options...
riceburner Posted April 25, 2012 Report Share Posted April 25, 2012 moze se iskljucit, al onda se time iskljucuje i senzor za kisu i jos neke stvari.... Link to comment Share on other sites More sharing options...
stealth Posted April 25, 2012 Report Share Posted April 25, 2012 Kako to iskljucit na novom Polu 6R, dize mi tlak to automatsko paljenje, autom imam dva mj, vec su crkle zarulje...da ne govorim po zimi kad pocne ubijat akumulator... Link to comment Share on other sites More sharing options...
Dario Posted April 25, 2012 Report Share Posted April 25, 2012 na polu izvuces prekidac i zicu TFL precvikas ili vag com ako netko ima Link to comment Share on other sites More sharing options...
stealth Posted April 25, 2012 Report Share Posted April 25, 2012 u servisu su rekli da nemogu...ono wtf? Link to comment Share on other sites More sharing options...
Dario Posted April 25, 2012 Report Share Posted April 25, 2012 glupost ,to je tak i tak cisto iskodirano da radi Link to comment Share on other sites More sharing options...
TomiTraktor Posted April 25, 2012 Report Share Posted April 25, 2012 Kako to iskljucit na novom Polu 6R, dize mi tlak to automatsko paljenje, autom imam dva mj, vec su crkle zarulje...da ne govorim po zimi kad pocne ubijat akumulator... na toyoti se pale svijetla nakon sto motor radi - ne pale se na kontakt ja bi volio da ima daylight za aurisa da ne gore svijetla ali nisu oni bas tako pametni Link to comment Share on other sites More sharing options...
stealth Posted April 25, 2012 Report Share Posted April 25, 2012 Cim okrenes kontakt pale se...ocaj... Link to comment Share on other sites More sharing options...
Tihi Posted April 25, 2012 Report Share Posted April 25, 2012 Znači tražim nekog ko zna isključit dnevna kratka svijetla na Toyoti RAV4 2.2 D-cat,automatik, najjača oprema sa senzorom za mrak iz 2010 godine. U sevisu to ne mogu napravit jer na testeru nema te opcije. (bar su mi tako rekli) Poželjno da to bude na području ZG-VŽ. lp Javi se na 098/900-8344, pa budemo pogledali kaj se da srediti. Dijagnostikom se ne moze, ali ima releje za to, pa treba izbaciti pravi relej. Kako to iskljucit na novom Polu 6R, dize mi tlak to automatsko paljenje, autom imam dva mj, vec su crkle zarulje...da ne govorim po zimi kad pocne ubijat akumulator... Na prekidacu svijetla treba jednu zicu precvikat. Radio sam to vec par puta. na polu izvuces prekidac i zicu TFL precvikas ili vag com ako netko ima VagCom-om na tom Polu ne moze. Jer, ima H4 zarulje i ne bi vijerovao, ali kratkta svijetla ne idu preko CentralElectronics, nego drito sa prekidaca. A, CentralElectronics pali pozicije i duga. Malo su cundo to slozili. Al, da se to sve rijesiti. Link to comment Share on other sites More sharing options...
stealth Posted April 26, 2012 Report Share Posted April 26, 2012 Ja imam dva puta H7 u faru a ne H4 Link to comment Share on other sites More sharing options...
Tihi Posted April 26, 2012 Report Share Posted April 26, 2012 Ok, ne bitno. Ili VagCom ako ide, ako ne, onda zica cvak. Link to comment Share on other sites More sharing options...
Dario Posted April 26, 2012 Report Share Posted April 26, 2012 TFL precvikas/istekas i to je to ,stvarno 2 min posla Link to comment Share on other sites More sharing options...
