Alfaludak Posted September 5, 2012 Share Posted September 5, 2012 Pozdrav, imam opet pitanje za strucnjake Napravio sam napred camber/toe ploce na amortizere i sad hocu stavit uniballe gore. Kupio sam u lagerkomercu (ovakav slican kao na slici) i uprešao u nosac ali bojim se da je to govno i da ce se raspast kad u prvu ruku ruknem I jucer smo slagali drugu stranu i kod upresavanja se naravno, raspao Koji da kupim a da DRZI sva ta opterecenja????? Jel to neki specijalni treba? Link to comment Share on other sites More sharing options...
fire Posted September 5, 2012 Share Posted September 5, 2012 Reci koje ti dimenzije trebaju. Link to comment Share on other sites More sharing options...
Alfaludak Posted September 5, 2012 Author Share Posted September 5, 2012 ovaj sada je bio unutarnja rupa 15mm a vanjski promjer mislim da 35, ali mogu stavit max do cca 40 vanjski bitno da je kvalitetan jer mi se to ne mjenja svaka 3 dana Link to comment Share on other sites More sharing options...
fire Posted September 5, 2012 Share Posted September 5, 2012 ovaj sada je bio unutarnja rupa 15mm a vanjski promjer mislim da 35, ali mogu stavit max do cca 40 vanjski bitno da je kvalitetan jer mi se to ne mjenja svaka 3 dana Ma nije problem kvalitete, to znam di ima. Dosta ekipe voze na takvima na brdu vec 2+godine i nitko nema problema. Samo se trebas odluciti na tocne dimenzije. Link to comment Share on other sites More sharing options...
Alfaludak Posted September 5, 2012 Author Share Posted September 5, 2012 daj mi ponudi unutarnja mora biti minimalno 15mm vanjska nije bitna Link to comment Share on other sites More sharing options...
fire Posted September 5, 2012 Share Posted September 5, 2012 (edited) evo kataloga http://www.fluro.de/index.php/en/products/rod-ends/87-dgasw http://www.fluro.de/index.php/en/products/rod-ends/89-dgaxsw Skuzi da ti trebas zapravo sferni lezaj. http://www.fluro.de/index.php/en/products/spherical-plain-bearings/1014-dgxsw-ms http://www.fluro.de/index.php/en/products/spherical-plain-bearings/1015-dgxow-ms http://www.fluro.de/index.php/en/products/spherical-plain-bearings/1018-dgxo-ms Edited September 5, 2012 by fire Link to comment Share on other sites More sharing options...
Dominik Posted September 5, 2012 Share Posted September 5, 2012 Ma nije problem kvalitete, to znam di ima. Dosta ekipe voze na takvima na brdu vec 2+godine i nitko nema problema.Samo se trebas odluciti na tocne dimenzije. lezaj ima svoj standard i nosivost, kako dinamicku po smjerovima tako i staticku , bez obzira na dimenziju ti trebas tu uniball pomogucnosti bez zracnosti sto vece nosivosti, znaci ne mos ga rukom vrtjeti marke schaublin i onda nemas brige Link to comment Share on other sites More sharing options...
Alfaludak Posted September 5, 2012 Author Share Posted September 5, 2012 uzeo sam od Kressa iste kakve on ima na skodi pa cu njih stavit da probam Link to comment Share on other sites More sharing options...
Risbo Posted September 6, 2012 Share Posted September 6, 2012 A na koju tolerancu si ga uprešavao? jer ako je preveliki preklop zacvika.... I kako ti se raspao kod uprešavanja ? Pa nisi valjda gurao na kuglu? Link to comment Share on other sites More sharing options...
Alfaludak Posted September 6, 2012 Author Share Posted September 6, 2012 Nemam pojma, u biti nije se raspao nego je dobio lufta valjda 1mm a samo sam bacio auto dolje na pod sa metar visine Link to comment Share on other sites More sharing options...
