Drag_steer Posted April 24, 2013 Report Share Posted April 24, 2013 Imam sarafe za zadnji most/glavcina. duzi su 5 mm nego sto trebaju, i dao bi ih kratit kod tokara. zanima me da li se tim vijcima smanjuje cvrstoca kod rezanja, jer je vjerojatno temperatura dosta visoka dok ga pile.. 10.9 je vijak. idu 4 na svaki kotac. valjda ce bit ok kad se skrate, sto se tice cvrstoce itd? Link to comment Share on other sites More sharing options...
robert Posted April 24, 2013 Report Share Posted April 24, 2013 mislis kratiti przonjere, to kratis samo tako.....bas je tkaci kad przonjere van Link to comment Share on other sites More sharing options...
Drag_steer Posted April 24, 2013 Author Report Share Posted April 24, 2013 (edited) ne njih, nego spoj izmedju mosta i glavcine. na most ide glavcina i disk i tad tek idu przonjere. stavljam distancu tamo pa mi trebali duzi sarafi, koju su predugi nazalost Edited April 24, 2013 by Drag_steer Link to comment Share on other sites More sharing options...
Newbie Posted April 24, 2013 Report Share Posted April 24, 2013 (edited) to su przonjeri? mislim, serafi na koje idu matice za kotace? svaki tokar ce ti to dobro odradit, bez brige budi sto se tice cvrstoce... nebude im nista... edit: e jbg, u isto vrijeme pisali... tokar ti to bez problema rijesi... Edited April 24, 2013 by Newbie Link to comment Share on other sites More sharing options...
ZOD Posted April 24, 2013 Report Share Posted April 24, 2013 Škripac, fleks. Nikakva nauka. Link to comment Share on other sites More sharing options...
Koren Posted April 24, 2013 Report Share Posted April 24, 2013 Škripac, fleks. Nikakva nauka. Evo, čovjek ti je sve rekao. A ako hoćeš da ti srce bude na mjestu, poslije flekse ih baci u vodu. Link to comment Share on other sites More sharing options...
Drag_steer Posted April 24, 2013 Author Report Share Posted April 24, 2013 ne radi se o przunjerama, nego o vijcima koji spavaju glavcinu i most. przunjere idu tek poslje, iz glavcine. probao sam u skrip i rucna pila, ali je vijak 10.9, i valjda zato neide bas lako. zanima me da li gubi svojstva ako ga se "pregrijava" ili izlaze temperaturi... trebam neko strucno misljenje, jer ako puknu naje*** sam Link to comment Share on other sites More sharing options...
Logic Posted April 24, 2013 Report Share Posted April 24, 2013 Nece nista puknut.. nije sad da kad rezes s fleksom da dolazi do nekih visokih temperatura pa da utjece na svojstva Koliko sam shvatio ti si ubacio "distancu" izmedju mosta i glavcine.. jesi usput i camber malo prilagodio? Link to comment Share on other sites More sharing options...
Drag_steer Posted April 25, 2013 Author Report Share Posted April 25, 2013 da, distanca je tamo stavljena. bit ce original distance od forda sa racing pume, ravne su skroz.. mozda dam napravit malo drugaciju distancu za sad ce bit ravne.. Link to comment Share on other sites More sharing options...
Marko Posted April 25, 2013 Report Share Posted April 25, 2013 Nece nista puknut.. nije sad da kad rezes s fleksom da dolazi do nekih visokih temperatura pa da utjece na svojstva ma jok. a tamo di rezes promijeni 5 nijansa boje.... odrezes na rucnu ili tracnu pilu i miran si.... Link to comment Share on other sites More sharing options...
vrcy Posted April 25, 2013 Report Share Posted April 25, 2013 ja sam isto ima nedavno takvu situaciju i da tokaru da napravi jer ti kad sa pilom doma ih odrizes nemozes napravit da su na vrhu malo uzi da se lakse vidaju ka sta tvornicki budu a tokar to napravi na stroju,10 sarafa 60 kn i ja miran Link to comment Share on other sites More sharing options...
Drag_steer Posted April 26, 2013 Author Report Share Posted April 26, 2013 (edited) ma jok. a tamo di rezes promijeni 5 nijansa boje.... odrezes na rucnu ili tracnu pilu i miran si.... da , tog me strah . odnio sma tokaru, rekao mu za to, kaze on da ce bit sigurno ok da nisu velike temperature.. iako je to mozda ono lako cemo. uglavnom skraceni su, neznam na koji nacin, radio ih tokar koji inace izradjuje zupcanike i osovine. izgledaju ok, idu 4 komada po kotacu, 10.9 su, stegnuti na 70 Nm. Ja se nadam da ce to izdrzat Edited April 26, 2013 by Drag_steer Link to comment Share on other sites More sharing options...
Newbie Posted April 26, 2013 Report Share Posted April 26, 2013 sekiras se bezveze naravno da ce izdrzat.. Link to comment Share on other sites More sharing options...
