rura gsi Posted August 19, 2013 Report Share Posted August 19, 2013 Ovako..frend je mjenjao volan na golfu 4 i raspala se ona trakica di se kopča air bag,i sad mu svijetli lampica... Ima tehnički za par dana pa se boji da ne padne,pa bi izvadio osigurač od jastuka dok ne nabavi taj dio... Znači di se nalazi osigurač od Air Bag-a na golfu 4 1999 god. Link to comment Share on other sites More sharing options...
Zoka RS Posted August 19, 2013 Report Share Posted August 19, 2013 kad izvadi osigurac opet ce svijetlit lampica.. Link to comment Share on other sites More sharing options...
Zoka RS Posted August 19, 2013 Report Share Posted August 19, 2013 sa otpornikom bi se dalo nesto riješit...mozda... Link to comment Share on other sites More sharing options...
rura gsi Posted August 19, 2013 Author Report Share Posted August 19, 2013 A jebemu...znaci nista da krepa lampica a izvaditi zarulju iz sata jel postoji mogucnost za to? Link to comment Share on other sites More sharing options...
Uros Posted August 19, 2013 Report Share Posted August 19, 2013 Treba samo otpornik stavit,sad od koliko ohma ne znam,al znat ce autoelektricar Link to comment Share on other sites More sharing options...
Zoka RS Posted August 19, 2013 Report Share Posted August 19, 2013 A jebemu...znaci nista da krepa lampica a izvaditi zarulju iz sata jel postoji mogucnost za to? to moze....valjda nije zalemljena... Link to comment Share on other sites More sharing options...
Snake Posted August 19, 2013 Report Share Posted August 19, 2013 (edited) A jebemu...znaci nista da krepa lampica a izvaditi zarulju iz sata jel postoji mogucnost za to? da ne vadis lampicu skines sat stavis izlirku crnu preko lampice i kad prode tehnicki skines. @Zoka RS - 4-oka ima zalemljene Edited August 19, 2013 by Snake Link to comment Share on other sites More sharing options...
Dac Posted August 19, 2013 Report Share Posted August 19, 2013 Ak ti nije hitno,ja se iduci ponedjeljak vracam s mora i imam otpornik Kosta te sve to jednu kavu;) i naravno pobrisemo gresku Link to comment Share on other sites More sharing options...
rura gsi Posted August 19, 2013 Author Report Share Posted August 19, 2013 Super Dac! Budem ti se javio ako nešto ne uspijemo iskemijati Link to comment Share on other sites More sharing options...
Bushido Posted August 19, 2013 Report Share Posted August 19, 2013 A da spoji auto na dijagnostiku i jednostavno ugasi AirBag lampicu (upozorenje)? Jednostavno, brzo i jeftino... Link to comment Share on other sites More sharing options...
Petar001 Posted August 19, 2013 Report Share Posted August 19, 2013 deaktivirat preko vagcom ali ce blicat prvih 15 sekundi ili otpornik stavit 4,7ohm ako se ne varam Link to comment Share on other sites More sharing options...
Tihi Posted August 19, 2013 Report Share Posted August 19, 2013 Otpornik 2.2 ohma i pobrisat gresku. A, mozda ti i imam i zavojnicu, pa slozis sve kako se spada odmah. Lampicu ne mozes ugasiti vadenjem osiguraca, ni bilo cega drugog. Link to comment Share on other sites More sharing options...
Bushido Posted August 20, 2013 Report Share Posted August 20, 2013 deaktivirat preko vagcom ali ce blicat prvih 15 sekundi ili otpornik stavit 4,7ohm ako se ne varam Deaktivacija preko Vagcom-a radi i nema nikakavog blicanja kojeg spominjes... (barem nije bilo u mom slucaju) Link to comment Share on other sites More sharing options...
Petar001 Posted August 21, 2013 Report Share Posted August 21, 2013 Deaktivacija preko Vagcom-a radi i nema nikakavog blicanja kojeg spominjes... (barem nije bilo u mom slucaju) nema ako deaktiviras suvozacev, a vozacev onda blica, barem meni na polu Link to comment Share on other sites More sharing options...
Beli Posted August 21, 2013 Report Share Posted August 21, 2013 Preko diagnostike se moze deaktivirati samo ako je tabla sa gateway-om.. Link to comment Share on other sites More sharing options...
Petar001 Posted August 21, 2013 Report Share Posted August 21, 2013 Preko diagnostike se moze deaktivirati samo ako je tabla sa gateway-om.. o čem ti pričaš ? polo 2001 nema CAN i moze se Link to comment Share on other sites More sharing options...
Beli Posted August 21, 2013 Report Share Posted August 21, 2013 (edited) Kako nema gateway interni u tabli.., Nisi pratio na nastavi... ha? Da si proucavao table, znao bi na novije genercije iza 2000 te godine imaju interni gateway Dok kod starrijih samo sibas signale sa table od abs-a, esp-a, airbaga na masu i lampice se pogase.. I u tvom postu se osjeti negativsn stav I edit.. ovdje pricamo o golfu 4 Edited August 21, 2013 by Beli Link to comment Share on other sites More sharing options...
Petar001 Posted August 22, 2013 Report Share Posted August 22, 2013 Kako nema gateway interni u tabli.., Nisi pratio na nastavi... ha? Da si proucavao table, znao bi na novije genercije iza 2000 te godine imaju interni gateway Dok kod starrijih samo sibas signale sa table od abs-a, esp-a, airbaga na masu i lampice se pogase.. I u tvom postu se osjeti negativsn stav I edit.. ovdje pricamo o golfu 4 kakve veze ima spajanje na masu i deaktivacija ! i neznam čemu da gubim vrijeme proučavajući ? samo ti proučavaj kakve veze o čem pričamo ja sam napomeno NA POLU jer blica kad se deaktivira Link to comment Share on other sites More sharing options...
Beli Posted August 22, 2013 Report Share Posted August 22, 2013 čovjek želi ugasiti lampicu... a lampica se može na x načina ugasiti.. a pričaš i o CAN-u, ali vidim da nisi skužio moj post i o čemu sam pisao... ja sam odasd ovdje off :thumbsup: Link to comment Share on other sites More sharing options...
Petar001 Posted August 22, 2013 Report Share Posted August 22, 2013 ja sam odasd ovdje off :thumbsup: super . Link to comment Share on other sites More sharing options...
Mexx Posted August 22, 2013 Report Share Posted August 22, 2013 (edited) Svaki airbag se da zamjeniti sa otpornikom iod 2.2 ohma. Edited August 22, 2013 by Mexx Link to comment Share on other sites More sharing options...
rura gsi Posted August 23, 2013 Author Report Share Posted August 23, 2013 Kao sto je Beli napisao ja bi samo ugasio lampicu a airbag mi opce ne treba! Link to comment Share on other sites More sharing options...
Dac Posted August 23, 2013 Report Share Posted August 23, 2013 Mozemo i to ako se da,nisam probao,al ako je netko ko hoce na tehnickom to gledat neces proc Javi se u nedjelju,ak se moze tak ugasit 2 min posla i picis dalje! Link to comment Share on other sites More sharing options...
rura gsi Posted August 23, 2013 Author Report Share Posted August 23, 2013 Dac-ma briga mene za auto i airbag tak i tak jedno i drugo ne vrijedi ništa!! meni je samo da ne svijetli lampica i da mi na bc ne izbacuje airbag fault!! Daj mi na p.m svoj broj pa se čujemo Link to comment Share on other sites More sharing options...
