Tomica93 Posted January 9, 2014 Report Share Posted January 9, 2014 znaci imam problem s ovakvim ležajem, niko nema tu dimenziju šta ja tražim, pa ako netko zna di bi se to moglo naci, trebam samo dio sa iglicama, proizvođač je ako se nevaram Nachi ležaj je za getribu Mitsubishi Galant 2.0 4G63 5 brzina, 81.god dimenzije su ove 40mm vanjska širina(po kojoj se iglice vrte(pošto je ta stijenka iz jednog komada sa zupčanikom) 30mm unutarnja širina(po kojoj se iglice vrte po ovom cilindru) 29,7mm je visina ležaja znači ova slika je od sva 3 dijela i sami ležaj Link to comment Share on other sites More sharing options...
zivac Posted January 9, 2014 Report Share Posted January 9, 2014 To ces tesko nac, ja sam uzeo cijelu getribu zbog tog lezaja Link to comment Share on other sites More sharing options...
riceburner Posted January 9, 2014 Report Share Posted January 9, 2014 nece biti jeftino... http://www.lohmann-gleitlager.de/ dok sam se ja bavio lezajevima preko njih se nabavljalo NACHI... Link to comment Share on other sites More sharing options...
Boxer Posted January 9, 2014 Report Share Posted January 9, 2014 http://www.tvrtke.com/expino-d-o-o,PID-8,MF-15023.aspx Link to comment Share on other sites More sharing options...
Marko Posted January 9, 2014 Report Share Posted January 9, 2014 29.7 ti je vjerojatno pojedena mjera od 30 postoje 30x40x30 iglicni lezajevi npr of skf-a K 30x40x30 sto ima u svakom ducanu Link to comment Share on other sites More sharing options...
Tomica93 Posted January 9, 2014 Author Report Share Posted January 9, 2014 Nije pojedeno al ima mjesta i za 30, sutra zovem, skf bi bio dobar za getribu? Link to comment Share on other sites More sharing options...
Marko Posted January 9, 2014 Report Share Posted January 9, 2014 0.3 mm mozes i izbrusit s kaveza s smirglom i isprat lezaj poslje , al cemu ako ima mjesta. Link to comment Share on other sites More sharing options...
dvoracek Posted January 10, 2014 Report Share Posted January 10, 2014 Lager commerce autodijelovi.. ima na stanju KOYO. Ako hoćeš samo nazovi i provjeri. 83 kn MPC Link to comment Share on other sites More sharing options...
Tomica93 Posted January 10, 2014 Author Report Share Posted January 10, 2014 Bio u lager commerce dva puta i rekli mi da nema. Sad kome vjerovat haha Link to comment Share on other sites More sharing options...
dvoracek Posted January 10, 2014 Report Share Posted January 10, 2014 Cek sekundu da mi se kolega javi. Imamo k 30x40x30 od koya ali ima neku oznaku "H" u sifri i nisam siguran sto to tocno znaci jer ja bas i nemam doticaja sa lezajima. Link to comment Share on other sites More sharing options...
Tomica93 Posted January 10, 2014 Author Report Share Posted January 10, 2014 Ajde ga slikaj jos i odozgora/sa strane Link to comment Share on other sites More sharing options...
dvoracek Posted January 10, 2014 Report Share Posted January 10, 2014 Evo sad sam razgovarao sa kolegom. To je to. evo i slike za sekundu Link to comment Share on other sites More sharing options...
dvoracek Posted January 10, 2014 Report Share Posted January 10, 2014 (edited) Imamo ga u Kovinskoj 3 komada Sesvetama 5 komada Gorici 1 komad Edited January 10, 2014 by dvoracek Link to comment Share on other sites More sharing options...
Tomica93 Posted January 10, 2014 Author Report Share Posted January 10, 2014 Uff sry gledam da je poprilicno veci od mog i vidim da sam stavio krivu dimenziju Unutarnji je 35mm Znaci treba mi 35x40x30 Link to comment Share on other sites More sharing options...
dvoracek Posted January 10, 2014 Report Share Posted January 10, 2014 (edited) Moze ovakav proci? I još je stavljen na neto cijenu tako da košta nevjerojatnih 30 kn. Svakako dobro dimenzije provjeri da se točno zna što se traži Edited January 10, 2014 by dvoracek Link to comment Share on other sites More sharing options...
Tomica93 Posted January 10, 2014 Author Report Share Posted January 10, 2014 Zvao sam i ove iz cakovca i oni imaju isto samo takve dvoredne u katalogu E sad posto su to lezajevi getribe dali su ovo dovoljno kvalitetni lezajevi da mi se ne rasipa cijela getriba jos na kraju? Link to comment Share on other sites More sharing options...
dvoracek Posted January 10, 2014 Report Share Posted January 10, 2014 Kvaliteta je neupitna al pitanje je dal su to te mjere dobre tj dali je to baš za tu namjenu. Jesi siguran da je 35x40x30? Koja je dimenzija kućišta gdje ulazi ta piksa i koja je dimenzija osovine ? Tj ako je 35 unutarnji od tog igličastog, dal je vanjska od ove pikse 40 ? Više mi se čini da bi bila 45. jesi dolazio sa uzorkom do nas ili si po dimenzijama tražio ? Kolega je još napomenuo da bi bilo dobro da se dođe sa uzorkom pa da onda provjerimo te dimenzije. a ako je ležaj dimenzija 35x45x30 onda ga stvarno nemamo Link to comment Share on other sites More sharing options...
Tomica93 Posted January 10, 2014 Author Report Share Posted January 10, 2014 Te dimenzije su sigurno vidis i po slici da je to to Kosuljica koja dolazi na osovinu(njen vanjski promjer je 35mm) U zupcanik je u jednom komadu(njegov unutarnji promjer je 40mm) Stari ce dofurat kompletnu getribu do mene dns popodne jer bi trebalo biti jos takvih malih lezaja pa da vidimo jesu li i iste dimenzije I ako je kvaliteta odlicna mislim da ne bi trebalo bit problema onda, a svakako ce se doc sa uzorkom do ducana Hvala ti puno Link to comment Share on other sites More sharing options...
dvoracek Posted January 10, 2014 Report Share Posted January 10, 2014 np taj 35x40x30 imamo u kovinskoj i gorici Link to comment Share on other sites More sharing options...
Marko Posted January 10, 2014 Report Share Posted January 10, 2014 E sad posto su to lezajevi getribe dali su ovo dovoljno kvalitetni lezajevi da mi se ne rasipa cijela getriba jos na kraju? od tog lezaja koji spaja 2 vratila aksijalno ti se sigurno nece raspast getriba... i ovi novi lezajevi imaju barem 30% vecu nosivost od onih proizvedenih u 1981. godini i prije.... tolko od mene , sretno sa sastavljanjem... Link to comment Share on other sites More sharing options...
Tomica93 Posted January 10, 2014 Author Report Share Posted January 10, 2014 To sam si i mislio da su unaprijedeni, hvala na odgovoru Link to comment Share on other sites More sharing options...
jura93 Posted January 10, 2014 Report Share Posted January 10, 2014 od tog lezaja koji spaja 2 vratila aksijalno ti se sigurno nece raspast getriba...i ovi novi lezajevi imaju barem 30% vecu nosivost od onih proizvedenih u 1981. godini i prije.... tolko od mene , sretno sa sastavljanjem... Jesi siguran? Link to comment Share on other sites More sharing options...
