Brklja Posted January 9, 2009 Posted January 9, 2009 Po ko zna koji put tražim nešto za frendove.. Ovaj put bi trebao cd sa Hr mapama (može i okolnih zemalja) za vw passat 2003, ima onaj "radio" sa LCD displayem, navigacija itd.. ugl na vrhu radia piše "RADIO NAVIGATION SYSTEM MFD" Gdje to nabavit, koja je procedura za ubacivanje, itd..? hvala
Brklja Posted January 9, 2009 Author Posted January 9, 2009 Da li paše "Eastern Europe 2008" od VDO-a? To mi može Jens nabavit.. Hvala
mariotdi Posted January 9, 2009 Posted January 9, 2009 mora biti Blaupunkt DX eastern europe 2007 Robert media zagreb. ja zvao za sebe i cd je 1250 kn:thumbsup: btw. trazim to vec godinama po torentima i jos nisam nasao
Misek_Chipsy Posted January 9, 2009 Posted January 9, 2009 nadjete par ljudi da trazi i podjelite troskove i copy
toc Posted January 9, 2009 Posted January 9, 2009 U Touaregu imam Blaupunkt navigaciju... ajde ako neko nabavi karte HR ja sam zainteresiran za kopijicu...
Renda Posted January 9, 2009 Posted January 9, 2009 Brklja - pitao ja dečka koji ima kao dosta tih karat i veli samo za Passat >2007.g. Toc - pitam sad i za tebe (možda bi onda mogao imati)!:thumbsup:
msporis Posted January 9, 2009 Posted January 9, 2009 jel ih treba crackat ak se sprže? ak ne treba crack, skupite si svi zajedno pa kupite i kopirajte ak treba crack probajte prvo nać njega na netu... a onda gornji postupak
toc Posted January 9, 2009 Posted January 9, 2009 Brklja - pitao ja dečka koji ima kao dosta tih karat i veli samo za Passat >2007.g. Toc - pitam sad i za tebe (možda bi onda mogao imati)!:thumbsup: :naughty::notworthy:
mariotdi Posted January 9, 2009 Posted January 9, 2009 Brklja - pitao ja dečka koji ima kao dosta tih karat i veli samo za Passat >2007.g. Toc - pitam sad i za tebe (možda bi onda mogao imati)!:thumbsup: Jle mozes priupitat za tip Blaupunkt Travelpilot E ? thnx
ante_st Posted January 9, 2009 Posted January 9, 2009 evo što kažu u blaupunktu Blaupunkt TravelPilot E cd's can not be copied due to the TAGES Copy Protection scheme. You will never find any files on Usenet or Rapidshare since posting is useless. You will have to obtain an original, that is the only solution kazu za sve njihove mape su predobro zaštićene da se nemogu kopirati.
Renda Posted January 9, 2009 Posted January 9, 2009 Evo broj od čovjeka pa ga pitajte... 0959107722 Miroslav Samo recite da vam je Renda sa Seat Cluba dao broj...
msporis Posted January 9, 2009 Posted January 9, 2009 evo što kažu u blaupunktu Blaupunkt TravelPilot E cd's can not be copied due to the TAGES Copy Protection scheme. You will never find any files on Usenet or Rapidshare since posting is useless. You will have to obtain an original, that is the only solution kazu za sve njihove mape su predobro zaštićene da se nemogu kopirati. samo se nitko nije dovoljno potrudio, od onih koji znaju... ako provale windowse onda mogu i ovo... sumnjam da microsoft manje ulaže u zaštitu od blaupunkt navigacije samo što windowse krene crackat 150 ljudi čim izađu a ovo nikad nitko ni ne pogleda... inače bi windowsi koristili ovaj sustav zaštite just my point of view... nažalost, ne znam crackat tak da nisam od pomći
t.m. Posted January 9, 2009 Posted January 9, 2009 ..poslušaj Rendu, ja imam navigaciju orginal u autu i Zubak me htio oženiti za DVD koji košta 1800 kn, a Miroslav mi ga nabavi za 50 eura i to najnovije izdanje..njemu se definitivno obrati!
Brklja Posted January 10, 2009 Author Posted January 10, 2009 znači taj Miroslav bi trebao moć nabavit kartu i za ovog passata (2003.) ili?
biciklist Posted January 10, 2009 Posted January 10, 2009 znači taj Miroslav bi trebao moć nabavit kartu i za ovog passata (2003.) ili? http://myhraweb.com/showpost.php?p=67968&postcount=6
Brklja Posted January 10, 2009 Author Posted January 10, 2009 http://myhraweb.com/showpost.php?p=67968&postcount=6 možda nije pitao tog Miroslava, iako sam pretpostavljao da je. Znači "nemoguće" je nabavit za 2003.g, al za najnoviji je moguće..?
13snc Posted January 10, 2009 Posted January 10, 2009 da ne otvaram novi topic... postoji li hrvatska za BMW e90 navigaciju?
Renda Posted January 10, 2009 Posted January 10, 2009 da ne otvaram novi topic... postoji li hrvatska za BMW e90 navigaciju? Zovi Miroslava, meni rekao da ima za 90% BMW-a...:thumbsup: Brklja - :doh:
Brklja Posted January 10, 2009 Author Posted January 10, 2009 Brklja - :doh: Drugi put kad ti vidim auto... :lol:
Jens Posted January 11, 2009 Posted January 11, 2009 Da ne otvaram novi topic; koje mape trazit za Opela :bag:? Rijec je o Signumu '05 sa VDO SIEMENS NCDC2015 multimedijalnom jedinicom? VDO NAVTEQ karte mu ne pasu. One idu na CD70/90 modele. hvala!
Robi555 Posted January 14, 2009 Posted January 14, 2009 http://www.gpsunderground.com/forums/index.php Pogledajte na ovom forumu,ima jako puno mapa i ostalih stvari vezanih uz navigaciju!:thumbsup:
