SEGI Posted January 12, 2009 Share Posted January 12, 2009 kako se ponistava servisni interval na polu 6n 2000god? znam kako ide na golfu ali na polu to ne funkcionira;) Link to comment Share on other sites More sharing options...
dcrnic Posted January 12, 2009 Share Posted January 12, 2009 Kupiš od Akule dijagnostiku za 1200kn i možeš na 90% automobila na tržištu raditi dijagnostiku i resetirati greške, servise itd... Link to comment Share on other sites More sharing options...
Roman Posted January 12, 2009 Share Posted January 12, 2009 Evo da ti ja ustedim 1200 kn... -(with the ignition off and keys out) press and hold the mile reset button -turn ignition on -wait until the display goes like '--' -turn ignition off and keys out and release button viola Link to comment Share on other sites More sharing options...
SEGI Posted January 12, 2009 Author Share Posted January 12, 2009 ma nije to tako komplicirano,ima fora sa kontakt bravom i tipkom za kilometrazu, samo treba znat sta stisnut i koliko drzat i kad dat kontakt...tako je bna cetvorci:) Link to comment Share on other sites More sharing options...
SEGI Posted January 12, 2009 Author Share Posted January 12, 2009 Evo da ti ja ustedim 1200 kn... -(with the ignition off and keys out) press and hold the mile reset button -turn ignition on -wait until the display goes like '--' -turn ignition off and keys out and release button viola prestigao si me:P hvala:thumbsup: Link to comment Share on other sites More sharing options...
dcrnic Posted January 12, 2009 Share Posted January 12, 2009 2 segi: Ma znam da postoji način... ali ovako napravim uslugu akuli, a i tebi... Napraviš par čišćenja greški po 200kn... I na kraju imaš diagnostiku gratis... i svaka iduća dijagnostika ti je zarada... :lol: Link to comment Share on other sites More sharing options...
WD40 Posted January 12, 2009 Share Posted January 12, 2009 Vec su rekli caku al dobro.. P.S. Pa nevozi Oplo da ima toliko grešaka tak da se neisplati diagnostika Link to comment Share on other sites More sharing options...
dcrnic Posted January 12, 2009 Share Posted January 12, 2009 Opel vozi i sa greškama, samo lampicu van i gas... Link to comment Share on other sites More sharing options...
filip00 Posted January 12, 2009 Share Posted January 12, 2009 moze da ne otvara tred, isto pitanje za passata 2002....kako ide za service reset ako ima postupak... hvala Link to comment Share on other sites More sharing options...
WD40 Posted January 12, 2009 Share Posted January 12, 2009 Ovak na pamet cu pokusat... Stisni desnu tipku.. daj kontakt.... pusti tipku i stisnu ljevu tipku.... Ako neide onda samo izmjeni zadnji korak pa ljevu stisnut i okrenut u desno... Jbg... kad sjednam za volan onda ruke same rade Link to comment Share on other sites More sharing options...
filip00 Posted January 12, 2009 Share Posted January 12, 2009 Ovak na pamet cu pokusat...Stisni desnu tipku.. daj kontakt.... pusti tipku i stisnu ljevu tipku.... Ako neide onda samo izmjeni zadnji korak pa ljevu stisnut i okrenut u desno... Jbg... kad sjednam za volan onda ruke same rade hvala, probam Link to comment Share on other sites More sharing options...
Kadett Posted January 12, 2009 Share Posted January 12, 2009 ajd da i ja ne otvaram topik Kak ide na A4 1.9TDi '97 ?? Link to comment Share on other sites More sharing options...
SEGI Posted January 13, 2009 Author Share Posted January 13, 2009 ajd da i ja ne otvaram topik Kak ide na A4 1.9TDi '97 ?? probaj ove kombinacije,ne mozes nista sjebat,ako ne sljaka pogledam u manual od golfa,vjerovatno je isto,al se nemogu sjetit ovako....a trenutno je prehladno da izlazim u dvoriste:D Link to comment Share on other sites More sharing options...
WD40 Posted January 14, 2009 Share Posted January 14, 2009 (edited) Ja sam se malo shebal.. U svezi Passat-a je ipa ona druga shema.... Dakle ljevu treba okrenut a ne stisnut U pon sam radio Passat-a pa sam malo osvježio pamćenje Kod Audija... hm... Naci cemo nesto... Edited January 14, 2009 by WD40 Link to comment Share on other sites More sharing options...
WD40 Posted January 14, 2009 Share Posted January 14, 2009 "The administrator has specified that you can only edit messages for 15 minutes after you have posted. This limit has expired, so you must contact the administrator to make alterations on your message." Tak da vise nemogu uredit prosli post al evo... našao sa ovo... za A4 The service interval display can also be reset using the following procedure: ‒ Switch off ignition. ‒ Press the reset key for the trip recorder on the dash panel insert and at the same time switch on the ignition. The trip recorder display will now read: Service OIL". ‒ Pull out the clock adjuster knob on the dash panel insert and hold in position until the message "Service OIL" is cancelled. The trip recorder display will now read: "Service - - -". ‒ Press the trip recorder reset key again to call up the next service message. The trip recorder display will now read: "Service INSP". ‒ Pull out the clock adjuster knob on the dash panel insert and hold in position until the message "Service INSP" is cancelled. The trip recorder display will now read: "Service - - -". ‒ Switch off ignition. :thumbsup: Link to comment Share on other sites More sharing options...
Rain Posted January 14, 2009 Share Posted January 14, 2009 2 segi: Ma znam da postoji način... ali ovako napravim uslugu akuli, a i tebi... Napraviš par čišćenja greški po 200kn... I na kraju imaš diagnostiku gratis... i svaka iduća dijagnostika ti je zarada... :lol: 200kn? hebote, u Renault servisu je dijagnostika 150kn Link to comment Share on other sites More sharing options...
