Ivek Posted February 17, 2009 Posted February 17, 2009 dal ide? netko veli da ide, netko veli da nejde...kaj vi kazete
Misek_Chipsy Posted February 17, 2009 Posted February 17, 2009 ide unutra kak ne....ide sve sta curi unutra,al dal ce kola ic...e to mislim da nece
Xman Posted February 17, 2009 Posted February 17, 2009 ide sigurno ali radis si stetu..sve ovisi kolko dugo mislis to tocit
Lacko Posted February 17, 2009 Posted February 17, 2009 Ja znam jednog sta je vozio i vozi jos 156-icu JTD na lozu iskljucivo Onda je imala 80.000km - sad nemam pojma Sigurno je da steti autu i s vremenom ce sigurno taj sumpor sjebat stijenku (common) rail-a ali to je izdrzljiv motor jako - podnosi svasta
mariotdi Posted February 17, 2009 Posted February 17, 2009 za tdi je bolji plavi od loze provjereno:thumbsup: evo sad se vec toci 20tkm plavi diz.u tdi pd 115 i nema problema
dux Posted February 17, 2009 Posted February 17, 2009 a bas i mene zanima za taj jtd... a plavi dizel bi trebo bit identican eurodieselu ili ne?! samo boja druga il ima jos u sastavu razlika?
Blade Posted February 17, 2009 Posted February 17, 2009 a bas i mene zanima za taj jtd... a plavi dizel bi trebo bit identican eurodieselu ili ne?! samo boja druga il ima jos u sastavu razlika? eurodizel u koji se ljeva boja da se razlikuje zbog cijene...sam di u zg ima plavog za kupit??
killercivic Posted February 17, 2009 Posted February 17, 2009 ide plavi i loža bez problema, još i bolje radi nego na naftu .. provjereno
Ivek Posted February 17, 2009 Author Posted February 17, 2009 eurodizel u koji se ljeva boja da se razlikuje zbog cijene...sam di u zg ima plavog za kupit?? na benzinskoj prije velike gorice;)
Blade Posted February 17, 2009 Posted February 17, 2009 hm... mislis na velikogorickoj?? inina benzinska??
dux Posted February 17, 2009 Posted February 17, 2009 al pa nemres doc tam i to trpat u auto?! il mozes? te moze ko prijavit?!
Cokolino Posted February 17, 2009 Posted February 17, 2009 al pa nemres doc tam i to trpat u auto?! il mozes? te moze ko prijavit?! u pravilu nemos, isko ko ni lozu neg u kanister pa vozi kuci i prilijevaj:doh: u biti plavi dizel nemos ni uzet ako nemas poljoprivrednju knjizici gdje imas odredjen broj litara koji mozes uzet;)
vjeko Posted February 17, 2009 Posted February 17, 2009 drkat će te senzori i elektronika to ti iz vlastitog iskustva kad tak sigurno govoris? inace znam covjeka cija alfa 159 2.4 JTD nije cula za dizel, a kamo li eurodizel... nikakvih problema covjek nije imal do sad...
platinum Posted February 17, 2009 Posted February 17, 2009 Ma toci i vozi Loza je obican dizel sa crvenom bojom u sebi
Ivsa Posted February 17, 2009 Posted February 17, 2009 Moj stari dropi Mazdu 3 vec dvije godine na plavi dizel i nikakvih problema.
Blade Posted February 17, 2009 Posted February 17, 2009 ja nemam nikakvih problema ,sam kaj nije najnovi dizel...
Duma Posted February 17, 2009 Posted February 17, 2009 to ti iz vlastitog iskustva kad tak sigurno govoris?inace znam covjeka cija alfa 159 2.4 JTD nije cula za dizel, a kamo li eurodizel... nikakvih problema covjek nije imal do sad... ne ali znam da je frend imao sranja sa stilom kad je kupio dizel od nekog tipa pa mu počelo sranja pokazivat
Ujo Posted February 17, 2009 Posted February 17, 2009 kolega s posla toči u 1.9 jtd i plavi i ložu i tako već 2g bez problema. zanima me kako stoji plavi i loža u mjet, i pumpa duse motore?!
Stipe385 Posted February 17, 2009 Posted February 17, 2009 kolega s posla toči u 1.9 jtd i plavi i ložu i tako već 2g bez problema.zanima me kako stoji plavi i loža u mjet, i pumpa duse motore?! znam par ljudi kaj toče u fabie pumpa duse, bez ikakvih problema
