riceburner Posted February 27, 2009 Share Posted February 27, 2009 slika prikazuje kaj se desilo. auto je 2005 godina i ima 15 000km. da li je ovo moglo nastati tako da je neki kamencic ili nekaj upalo izmedju diska i pakne ili je neka mozda tvornicka greska? :huh::blink: Link to comment Share on other sites More sharing options...
woo Posted February 27, 2009 Share Posted February 27, 2009 kaj god da je, ja bi to hitno mijenjao Link to comment Share on other sites More sharing options...
Burnout Posted February 27, 2009 Share Posted February 27, 2009 jel se osjeti ris kada prstom prelazis preko diska?! Link to comment Share on other sites More sharing options...
Mille Posted February 27, 2009 Share Posted February 27, 2009 Puknut disk , .. ni prvi ni zadnji ! Link to comment Share on other sites More sharing options...
riceburner Posted February 27, 2009 Author Share Posted February 27, 2009 jel se osjeti ris kada prstom prelazis preko diska?! je, rupa je cca milimetar i pol... Link to comment Share on other sites More sharing options...
riceburner Posted February 27, 2009 Author Share Posted February 27, 2009 Puknut disk , .. ni prvi ni zadnji ! od cega je moglo puknut? auto se vozi full penzionerski i tesko da se moglo pregrijati. Link to comment Share on other sites More sharing options...
Mille Posted February 27, 2009 Share Posted February 27, 2009 od cega je moglo puknut? auto se vozi full penzionerski i tesko da se moglo pregrijati. serijki je bio u banani ... loši ljev ... može biti sto stvari ... zamjeni ga i gotovo . Link to comment Share on other sites More sharing options...
Alfaludak Posted February 27, 2009 Share Posted February 27, 2009 ako mislis na ove crte okomite na disk to je od plocica i to je normalno a ako mislis na ovu brazdu ukrug cijelog disla sa gornje strane to je ili losa plocica ili je upao kamencic ili tako nesto skini plocicu i vidi sta je, ja sam u jednoj imao nebo vjerovao SERAF i samo sam ga izvadio i vozi dalje nije to nista alarmantno Link to comment Share on other sites More sharing options...
Mille Posted February 27, 2009 Share Posted February 27, 2009 ako mislis na ove crte okomite na disk to je od plocica i to je normalno a ako mislis na ovu brazdu ukrug cijelog disla sa gornje strane to je ili losa plocica ili je upao kamencic ili tako nesto skini plocicu i vidi sta je, ja sam u jednoj imao nebo vjerovao SERAF i samo sam ga izvadio i vozi dalje nije to nista alarmantno nebi reko da je to otisak od pločice , jer ne izgleda tak ... a kad se pločica ocrta , onda je baš onak ko čitava pločica tj rub . Link to comment Share on other sites More sharing options...
Auto-Robi Posted February 27, 2009 Share Posted February 27, 2009 ovo je puknut disk od pregrijavanja, nista drugo! Link to comment Share on other sites More sharing options...
Burnout Posted February 27, 2009 Share Posted February 27, 2009 napukao je disk i bilo bi ga dobro promijenit iako kao sto ludi alfa kaze nije alarmantno. vozi dalje dok ne skupis novce a onda promjena i to je to bilo je i puno gorih diskova od ovoga pa je trajao jos dosta dugo. Link to comment Share on other sites More sharing options...
riceburner Posted February 27, 2009 Author Share Posted February 27, 2009 aaa, vidim da ste svi zapeli za ovo crno, to je otisak plocice koji prstom ide dolje, bitna je samo ova brazda koja ide ukrug, okomitih crta nema nikakvih, sutra ako bude lepo vreme cu to probat raskopat, ne treba nikakav specijalni alat za skinut plocice, pa cu videt kaj je... Link to comment Share on other sites More sharing options...
riceburner Posted February 27, 2009 Author Share Posted February 27, 2009 napukao je disk i bilo bi ga dobro promijenit iako kao sto ludi alfa kaze nije alarmantno. vozi dalje dok ne skupis novce a onda promjena i to je to bilo je i puno gorih diskova od ovoga pa je trajao jos dosta dugo. ma auto se jako malo vozi, 5 godina, a ima 15 000 km preko zime uopce neide van, sad sam neki dan stavio novi akumulator i isao napravit krug, danas sam trebal nekaj iz garaze pa ga izvadio van i htel ga prat pa sam to videl... Link to comment Share on other sites More sharing options...
Burnout Posted February 27, 2009 Share Posted February 27, 2009 a joj ako je samo ta brazda onda se nista ne brni ako hoces mozes to potokarit ako ne vozi dalje, sve je to dobro Link to comment Share on other sites More sharing options...
Japanac Posted February 27, 2009 Share Posted February 27, 2009 nebi reko da je to otisak od pločice , jer ne izgleda tak ... a kad se pločica ocrta , onda je baš onak ko čitava pločica tj rub . pa otisak je od pločice, pogle lijevi rub slike, vidi se simetričan otisak ko i desno, samo se ne vidi cijeli jer je tak slikano! Ova brazda nije niš preopasno ak disk ima još mesa... eventualno potokarit Link to comment Share on other sites More sharing options...
Ivek Posted February 27, 2009 Share Posted February 27, 2009 samo vozi dalje, nije to nist Link to comment Share on other sites More sharing options...
Mille Posted February 27, 2009 Share Posted February 27, 2009 onda oke ak je od pločice ... ja sam mislio da on pita za to , a ne za brazdu .. hebeš brazdu .:doh: Link to comment Share on other sites More sharing options...
riceburner Posted February 27, 2009 Author Share Posted February 27, 2009 pa otisak je od pločice, pogle lijevi rub slike, vidi se simetričan otisak ko i desno, samo se ne vidi cijeli jer je tak slikano! Ova brazda nije niš preopasno ak disk ima još mesa... eventualno potokarit sutra bum videl,ajd da auto ima 150 000km, nego ima 15 000 Link to comment Share on other sites More sharing options...
Veki Posted February 27, 2009 Share Posted February 27, 2009 ma nekaj je zapelo bilo i napravilo ris..niš strašno... Link to comment Share on other sites More sharing options...
woo Posted February 27, 2009 Share Posted February 27, 2009 ja mislil da je napukel isto ovo nije nikaj.samo teraj Link to comment Share on other sites More sharing options...
riceburner Posted February 28, 2009 Author Share Posted February 28, 2009 evo uspio ja raskopat auto ovi kreteni francuski stavili neki petokraki kljuc koji naravno nemam pa sam moral skinut cijele celjusti dole... evo kad se maknu celjusti da se vidi kolko je duboka brazda... i na pakni nema nis, nekaj je ocito bilo, dal kamen ili nekaj drugo neznam, uglavnom to ne zgleda lose, malo cu prosetat po ducanima da vidim kolko su novi diskovi i plocice pa nek bude novo kad je auto jos ko novi Link to comment Share on other sites More sharing options...
riceburner Posted February 28, 2009 Author Share Posted February 28, 2009 btw, nek neko veli da opel hrdja, kaj je onda renault??? :huh::doh: auto ima 15000km, nije vidio snijega i soli pa sve ovako hrdjavo, ostao neuogodno iznenadjen kad sam serafil :blink::blink::blink: Link to comment Share on other sites More sharing options...
Renda Posted February 28, 2009 Share Posted February 28, 2009 I na pločici je taman štrafta na tom dijelu... Složi natrag i vozi dalje! Potpuno nepotrebno mijenjat po meni... Btw. ja sam isto mislio da pitaš za "puknuće" diska... Link to comment Share on other sites More sharing options...
Japanac Posted February 28, 2009 Share Posted February 28, 2009 btw, nek neko veli da opel hrdja, kaj je onda renault??? :huh::doh:auto ima 15000km, nije vidio snijega i soli pa sve ovako hrdjavo, ostao neuogodno iznenadjen kad sam serafil :blink::blink::blink: zato što se ne vozi Link to comment Share on other sites More sharing options...
riceburner Posted February 28, 2009 Author Share Posted February 28, 2009 zato što se ne vozi garaza je suha, prozracna, dole je gumena izolacija pa mi nikak nije jasno da auto za 4 godine tako hrdjav ajd da se vozi preko zime jos bi razmel, al ovak :doh: Link to comment Share on other sites More sharing options...
