Vila Posted August 18, 2024 Posted August 18, 2024 kupija san to malo čudo od 3 eura, al ne mogu se spojit nikako.na multimediji u autu iman Torque aplikaciju koja mi traži da se spojim po defaultu na wifi ili BT, a ne pronalazi mi ga. btw. crvena lampica svijetlia na mobu san diga onaj car scanner app, on se spoji uredno s njim al kasnije se ne može spojit sa ECUom.jesan možda krivi protokol stavija? ovaj default san odabra.
Puh Posted August 18, 2024 Posted August 18, 2024 Meni baš jučer došao, probao s tom car scanner aplikacijom i spojio se bez problema, doduše bemvej.
Vila Posted August 19, 2024 Author Posted August 19, 2024 očito moran i ja na propelerca .proba san i ostale protokole, ma nema šanse. ne znan šta radin krivo
Iggy_R Posted August 19, 2024 Posted August 19, 2024 48 minutes ago, Vila said: ne znan šta radin krivo Voziš dizela? 😛
Kegalj Posted August 22, 2024 Posted August 22, 2024 Torque i mene zna zajebavat cesto. Carista radi puno bolje sto se tice dijagnostike i otkljucavanja pizdarija po autu, ali se placa.
Gabre Posted August 24, 2024 Posted August 24, 2024 On 8/22/2024 at 11:13 AM, Kegalj said: Torque i mene zna zajebavat cesto. Carista radi puno bolje sto se tice dijagnostike i otkljucavanja pizdarija po autu, ali se placa. skines crackani APK, radi kao da placas pretplatu, ja caristu imam godinama, spasila me masu puta
Vila Posted September 5, 2024 Author Posted September 5, 2024 spoje se elm i aplikacija, al nikako se ne može spojit sa ecu-om. u car scanneru i u torque-u. ima li ko ideju zašto?Sent from my SM-S921B using Tapatalk
Vila Posted September 10, 2024 Author Posted September 10, 2024 [mention=166]Vila[/mention] wifi ili BT?BT, na wifi mi ga ne nalaziSent from my SM-S921B using Tapatalk
Vila Posted September 11, 2024 Author Posted September 11, 2024 ma da. jedini problem je ubiti šta ovo govance se ne može spojit sa ecu-om, sve živo san proba i ne bi bog.Sent from my SM-S921B using Tapatalk
Kegalj Posted September 13, 2024 Posted September 13, 2024 On 9/11/2024 at 12:22 PM, Vila said: ma da. jedini problem je ubiti šta ovo govance se ne može spojit sa ecu-om, sve živo san proba i ne bi bog. Sent from my SM-S921B using Tapatalk Probaj spojit svoj obd na neki drugi auto. Ako i dalje ne radi vjerojatno je riknut. Mozes probat i posudit ELM od nekog
Vila Posted September 13, 2024 Author Posted September 13, 2024 ma spoijo ga na fabiu od starog, radi ko sat. nije do njega, to san odma proba.proba san čak i sa drugim ELMom, ista stvar.na guglu nema jednog jedinog topica sličnog problema.fak it.Sent from my SM-S921B using Tapatalk
