kreza Posted July 30, 2009 Share Posted July 30, 2009 imam sljedeći problem. odjednom klima je prestala hladit. znači nije bilo da povremeno slabije i slabije hladi nego odjednom samo puše vrući zrak. stavljen je novi plin ali nije do njega. kompresor dobija struju i crijevo od njega je čisto. prvo su mi rekli u servisu nakon toga da nije do kompresora sad ipak govore DA BI MOGLO BIT. zanima me dali je neko ima takvo iskustvo odnosno znali neko u čemu bi moga bit problem Link to comment Share on other sites More sharing options...
InSaNe Posted July 30, 2009 Share Posted July 30, 2009 Jel kompresor pali ili ne pali Link to comment Share on other sites More sharing options...
IvanSX Posted July 30, 2009 Share Posted July 30, 2009 Mozda ti negdje lajtunzi pustaju...tak je meni bilo...i svejdeno ti puse vruce... Link to comment Share on other sites More sharing options...
Guba Posted July 30, 2009 Share Posted July 30, 2009 Filter klime? Link to comment Share on other sites More sharing options...
Duba Posted July 30, 2009 Share Posted July 30, 2009 (edited) ...dobro jel se kompresor vrti ili ne??? ..mislim može bit svašta..premalo si informacija dao... Edited July 30, 2009 by Duba Link to comment Share on other sites More sharing options...
Mexx Posted July 30, 2009 Share Posted July 30, 2009 1.pali li kompresor(mozes ga cut pod haubom ili primjetit na rpm da su ti pali malo ako se on pali) 2.kada upalis klimu ventilatori kilera se moraju pocet vrtit,tj ukljuce.... Link to comment Share on other sites More sharing options...
Fox Posted July 30, 2009 Share Posted July 30, 2009 otidji napravi test nepropusnosti klime... meni je nekidan nakon tri godine ponestalo malo plina i kod ubrzanja i pretjecanja mi se gasila... falilo plina a test nepropusnosti bio OK... sad je sve OK... Link to comment Share on other sites More sharing options...
Guest diablo Posted July 30, 2009 Share Posted July 30, 2009 meni kad klima nije radila promjenili mi neki otpornik klime , doduse otpornik je bio mrcina i kosto je faking 100 € , al od tada radi... Link to comment Share on other sites More sharing options...
Cajo Posted July 30, 2009 Share Posted July 30, 2009 može biti da je presostat. Link to comment Share on other sites More sharing options...
kreza Posted July 30, 2009 Author Share Posted July 30, 2009 a ipak je kompresor. stavljen novi i klima radi........ Link to comment Share on other sites More sharing options...
Mexx Posted July 30, 2009 Share Posted July 30, 2009 koliko te izasa kompresor Link to comment Share on other sites More sharing options...
Hans Posted July 30, 2009 Share Posted July 30, 2009 Unazad 3-4 godine kompresori klime Delphi koji se ugrađuju na nove aute svih marki su pali kvalitetom podosta....kompresori na autima s kraja 80-ih još rade dan danas dok za ove nove nije uopće čudno ako crkne. Link to comment Share on other sites More sharing options...
kreza Posted July 31, 2009 Author Share Posted July 31, 2009 novi je 7500 kn za moj auto. još sam u nekim pregovorima al ispod 6k kn neće ić Link to comment Share on other sites More sharing options...
Hans Posted July 31, 2009 Share Posted July 31, 2009 Pa koliko ti je star Golf? Link to comment Share on other sites More sharing options...
filip00 Posted July 31, 2009 Share Posted July 31, 2009 Unazad 3-4 godine kompresori klime Delphi koji se ugrađuju na nove aute svih marki su pali kvalitetom podosta....kompresori na autima s kraja 80-ih još rade dan danas dok za ove nove nije uopće čudno ako crkne. to je stvarno u kurcu. eto njemackO Hauto imam s kraja 1990e, kompresor originalan i radi najnormalnije... Link to comment Share on other sites More sharing options...
brba Posted July 31, 2009 Share Posted July 31, 2009 nabijem ih na 7.5 tkn http://cgi.ebay.de/Klimakompressor-VW-Golf-5-1-9-2-0-Klima-Kompressor_W0QQitemZ220402266523QQcmdZViewItemQQptZAutoteile_Zubeh%C3%B6r?hash=item3350ffb19b&_trksid=p3286.c0.m14 http://cgi.ebay.de/VW-Golf-5-Jetta-Klimakompressor-1K0-820-803-R-Klima_W0QQitemZ350171137456QQcmdZViewItemQQptZAutoteile_Zubeh%C3%B6r?hash=item5187d385b0&_trksid=p3286.c0.m14 http://cgi.ebay.de/KLIMA-KOMPRESSOR-VW-CADDY-3-III-EOS-GOLF-V-5-ZEXEL-AB03_W0QQitemZ370236577086QQcmdZViewItemQQptZAutoteile_Zubeh%C3%B6r?hash=item5633d1d53e&_trksid=p3286.c0.m14 http://cgi.ebay.de/KLIMA-KOMPRESSOR-VW-GOLF-5-V-1-9-2-0-SDI-GTD-TDI-16V_W0QQitemZ140336133869QQcmdZViewItemQQptZAutoteile_Zubeh%C3%B6r?hash=item20acaf76ed&_trksid=p3286.c0.m14 Link to comment Share on other sites More sharing options...
kreza Posted July 31, 2009 Author Share Posted July 31, 2009 prvo će se prominit presostat cca 400 kn. ako bude do njega to će bit sramota za ovlašteni servis!!!!! Link to comment Share on other sites More sharing options...
Hans Posted July 31, 2009 Share Posted July 31, 2009 prvo će se prominit presostat cca 400 kn. ako bude do njega to će bit sramota za ovlašteni servis!!!!! Ha ha....znači svi su servisi isti samo je vani druga tabla (VW,Renault...i svi ostali redom) :doh: Link to comment Share on other sites More sharing options...
Mexx Posted July 31, 2009 Share Posted July 31, 2009 zasto kako sta Link to comment Share on other sites More sharing options...
Mexx Posted July 31, 2009 Share Posted July 31, 2009 Ha ha....znači svi su servisi isti samo je vani druga tabla (VW,Renault...i svi ostali redom) :doh: a vidi prigode za opravdat se.. stari svi su isti ali su vaši posebni! :thumbsup: Link to comment Share on other sites More sharing options...
Hans Posted July 31, 2009 Share Posted July 31, 2009 a vidi prigode za opravdat se..stari svi su isti ali su vaši posebni! :thumbsup: Sve su to isti ljudi,tvoji i moji poznanici,susjedi,sugrađani,samo jedan se zaposlio kod Jose,a drugi kod Pave... Link to comment Share on other sites More sharing options...
bojan25 Posted August 7, 2009 Share Posted August 7, 2009 još jedan od razloga zašto moj golf nije vidio ovlaštene servise. 2kreza:su ti dali kakvo objašnjenje radi čega je točno otišo kompresor? Link to comment Share on other sites More sharing options...
