mislav Posted July 1, 2010 Author Share Posted July 1, 2010 Majslave, ajd saznaj nešto više o ovome: UR-LA2-510 720 kn -20% :naughty: naručeno je Link to comment Share on other sites More sharing options...
GoranE46 Posted July 1, 2010 Share Posted July 1, 2010 You are the king... Pogledat cu to i ako mi pase, we have a deal... Link to comment Share on other sites More sharing options...
mislav Posted July 1, 2010 Author Share Posted July 1, 2010 You are the king... Pogledat cu to i ako mi pase, we have a deal... no frx. kad dođe, lako probamo stavit po meni problem može biti jedino M airbox Link to comment Share on other sites More sharing options...
Exfreerider Posted July 1, 2010 Share Posted July 1, 2010 Ima li šta za polo 9N3 od strutova i anti rool? Link to comment Share on other sites More sharing options...
mislav Posted July 1, 2010 Author Share Posted July 1, 2010 Ima li šta za polo 9N3 od strutova i anti rool? nažalost baš ništa. slabi su sa VW :huh: Link to comment Share on other sites More sharing options...
Zlaya Posted July 1, 2010 Share Posted July 1, 2010 Si počeo dilat Ultra Racing robu..? Možeš mi na pm poslat cijene za ovo; Code : UR-AR19-002 Code : UR-TW2-061 Code : UR-RE2-059 Code : UR-LA4-165 Hvala. Link to comment Share on other sites More sharing options...
meshin Posted July 1, 2010 Share Posted July 1, 2010 Mislav, koje su najmekše opruge koje mogu dobiti na D2 stražnjim coiloverima ?! Šfra ti je T08, samo stražnje. Daj i cifru odmah baci ako ti se da, samo za stražnje. Link to comment Share on other sites More sharing options...
TheNT Posted July 1, 2010 Share Posted July 1, 2010 Dobro čuješ, naručena je prva velika tura Ultra Racing strutova i anti roll-ova Alii...anti roll zasad jedino za kocku ima :huh: A nemoj zezat pa to su moji jel imas ovoga: UR-AR23-003 il jos uvijek samo za kocku stvari... Link to comment Share on other sites More sharing options...
FlashBack Posted July 1, 2010 Share Posted July 1, 2010 Mislave, ima li kaj novoga? Mitsubishi Eclipse Link to comment Share on other sites More sharing options...
mislav Posted July 1, 2010 Author Share Posted July 1, 2010 Si počeo dilat Ultra Racing robu..? Možeš mi na pm poslat cijene za ovo; Code : UR-AR19-002 Code : UR-TW2-061 Code : UR-RE2-059 Code : UR-LA4-165 Hvala. Code : UR-AR19-002 1.800 Code : UR-TW2-061 510 Code : UR-RE2-059 510 Code : UR-LA4-165 870 -20% Mislav, koje su najmekše opruge koje mogu dobiti na D2 stražnjim coiloverima ?!Šfra ti je T08, samo stražnje. Daj i cifru odmah baci ako ti se da, samo za stražnje. poslao sam im mail sad, ne piše mi u katalogu. inače su opruge 500 -10% za par A nemoj zezat pa to su moji jel imas ovoga: UR-AR23-003 il jos uvijek samo za kocku stvari... nemam taj broj u katalogu :huh: Mislave, ima li kaj novoga? Mitsubishi Eclipse sutra te zovem čim dođe kamion. za vikend slažeš, nemaš brige Link to comment Share on other sites More sharing options...
@Dodo@ Posted July 1, 2010 Share Posted July 1, 2010 Može cijena? UR-AR19-104 UR-FD3-353 Thanx Link to comment Share on other sites More sharing options...
meshin Posted July 1, 2010 Share Posted July 1, 2010 poslao sam im mail sad, ne piše mi u katalogu. inače su opruge 500 -10% za par Odlično, hvala . Samo koliko su kompletne gewinde, ali samo stražnje? Link to comment Share on other sites More sharing options...
Medic Posted July 1, 2010 Share Posted July 1, 2010 Fender bar....kaj sve neće smislit da dignu lovu. Malo žešća nepotrepština Link to comment Share on other sites More sharing options...
@Dodo@ Posted July 1, 2010 Share Posted July 1, 2010 ako postoji, I must have it.... Link to comment Share on other sites More sharing options...
Zlaya Posted July 1, 2010 Share Posted July 1, 2010 Code : UR-AR19-002 1.800 Code : UR-TW2-061 510 Code : UR-RE2-059 510 Code : UR-LA4-165 870 -20% Thx..., ovo je zaista brzi odgovor, daj mi reci kakva je opcija s karticama, rate i popust, kolko bi se čekalo na isporuku:thumbsup: Link to comment Share on other sites More sharing options...
TheNT Posted July 2, 2010 Share Posted July 2, 2010 nemam taj broj u katalogu :huh: pfuuu a jel ima mozda ovaj tanji od 19mm? UR-AR19-002 a provjeri odma i ovog od 16mm mada mislim da je i serijski tu negdje pa... UR-AR16-001 a i ovo mi provjeri molim te UR-LA4-165 Link to comment Share on other sites More sharing options...
mislav Posted July 2, 2010 Author Share Posted July 2, 2010 Može cijena? UR-AR19-104 UR-FD3-353 Thanx UR-AR19-104 1.980 kn UR-FD3-353 1.080 kn -20% Odlično, hvala .Samo koliko su kompletne gewinde, ali samo stražnje? hm, 3/4 cijene kompleta kažu tajvanci. znači 4.320 s popustom. iskreno, nismo još naručivali pola paketa Fender bar....kaj sve neće smislit da dignu lovu. Malo žešća nepotrepština jel ti to provociraš? hoćeš da sad zovem Antu? Thx..., ovo je zaista brzi odgovor, daj mi reci kakva je opcija s karticama, rate i popust, kolko bi se čekalo na isporuku:thumbsup: imamo sve kartice. za kartice je -10% forumski popust. cca 20 dana pfuuu a jel ima mozda ovaj tanji od 19mm?UR-AR19-002 a provjeri odma i ovog od 16mm mada mislim da je i serijski tu negdje pa... UR-AR16-001 a i ovo mi provjeri molim te UR-LA4-165 UR-AR19-002 1.800 kn UR-AR16-001 nema UR-LA4-165 870 kn -20% Link to comment Share on other sites More sharing options...
mislav Posted July 2, 2010 Author Share Posted July 2, 2010 Otvorio sam novu temu za Ultra Racing da ovu ne zatrpavamo :thumbsup: Link to comment Share on other sites More sharing options...
meshin Posted July 2, 2010 Share Posted July 2, 2010 hm, 3/4 cijene kompleta kažu tajvanci. znači 4.320 s popustom. iskreno, nismo još naručivali pola paketa O mamicu im.. Tjeraju me na komplet, a prednje mi ne pašu. Aj samo javi koje su opcije po pitanju tvrdoča opruga, koje sve tvrdoče isporučuju. Link to comment Share on other sites More sharing options...
mislav Posted July 2, 2010 Author Share Posted July 2, 2010 O mamicu im.. Tjeraju me na komplet, a prednje mi ne pašu. Aj samo javi koje su opcije po pitanju tvrdoča opruga, koje sve tvrdoče isporučuju. pa ti možeš iscrtati prednje prema tvorničkim mjerama i oni će napraviti nove prihvate i sl. bez nadoplate javim još za tvrdoće opruga. Link to comment Share on other sites More sharing options...
Medic Posted July 2, 2010 Share Posted July 2, 2010 jel ti to provociraš? hoćeš da sad zovem Antu? Ma neeeee.:lol: Baš sam ga neki dan pitao jeste proslavili stoti rođendan ove vaše alfa-fiat-zastava grupacije:lol: pa je bio ljut :lol::thumbsup: Link to comment Share on other sites More sharing options...
SVEN Posted July 19, 2010 Share Posted July 19, 2010 Nakon 107 dana čekanja amortizeri su na autu. Učenje strpljenju je rezurtiralo plodom.. Link to comment Share on other sites More sharing options...
ZOD Posted July 19, 2010 Share Posted July 19, 2010 Kaj sam starim amortizerima? Link to comment Share on other sites More sharing options...
golfijaner Posted July 19, 2010 Share Posted July 19, 2010 osjećaš li se i dalje oštećenim i povrijeđenim? je li ti se dogodilo što dok si čekao? Link to comment Share on other sites More sharing options...
KA2001MR Posted July 19, 2010 Share Posted July 19, 2010 ja sam isto pokupio amortizere, al još nisam smontirao, danas ili sutra. hvala mislavu na dobroj volji što je pristao zamijenit amortizere koje po garanciji i nije trebao. javim ti se da ti vratim stare kad ove razmontiram Link to comment Share on other sites More sharing options...
