bojan25 Posted December 24, 2010 Posted December 24, 2010 (edited) naručio bi ASA AR1 u 17x9 ET30 za svojeg mk4 ali nisam siguran oče mi to gdje strugati...zna neko možda jel ide to na auto bez brige da se ne zajebem ps.spušten je oprugama 35 ovo mi baci na nekom tire calculatoru usporedim 195 65 15 i 215 40 17 Package is 12 mm (0.5'') closer to suspension/brakes components. Acceptable for most cars. Fenders Package will stick out 28 mm (1.1'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset. Wheelwells 100% clear (leaves even more room than OEM) Edited December 24, 2010 by bojan25
jady Posted December 25, 2010 Posted December 25, 2010 ja sam imao 9x17et20 sa 215/45/17 iza i nije strugalo ...sa gewindama
stipa Posted December 25, 2010 Posted December 25, 2010 http://www.miata.net/garage/tirecalc.html probaj ovdje... pokazuje da je 195/65/15 veća u odnosu na 215/40/17, ali je ova šira, e sad ne znam koliki je ET kod mk4 ali mislim da nije puno veći od tog na felgama, mislim da nebi trebao imati problema...
Mexx Posted December 25, 2010 Posted December 25, 2010 (edited) 17x8 naprid...sa et 30 ce bit odlicno.... a nazad imas mista i za 9ku na etu 15 mozes slobodno ic na 215 45 r17 --- a ako naprid ides isto na 9 onda obavezno 205 45 da budes siguran da nece dirat blatobrane. evo ti tema sa offsetima za mk4 http://forums.motivemag.com/showthread.php?3938426 Edited December 25, 2010 by Mexx
Mexx Posted December 25, 2010 Posted December 25, 2010 ajd da mi je i to vidjet od bojana :rofl::rofl::rofl: ajde polako đava odnia prišu
bojan25 Posted December 25, 2010 Author Posted December 25, 2010 poslije nove godine idem u SLO po njih....evo ih čekaju me
bravo-ri Posted December 25, 2010 Posted December 25, 2010 uzimaš ih polovne ili nove?koje gume budeš stavio gore?
bojan25 Posted December 25, 2010 Author Posted December 25, 2010 polovne su ali malo korištene(2 tjedna) za gume se još nisam odlučio ali vjerojatno bi išao na 215 45 to je u sloveniji roba...zato se raspitujem za moguće probleme jer kad ih kupim je prekasno
bojan25 Posted December 25, 2010 Author Posted December 25, 2010 to će mi biti 8 komplet na autu.....
