Hic Posted November 14, 2008 Share Posted November 14, 2008 isprogramira se postojeci ecu iz prve (bez stage 1 2 i sl.) da radi sa hardwerom koji auto posjeduje (ispuh, usis i sl). Link to comment Share on other sites More sharing options...
mr_G Posted November 14, 2008 Share Posted November 14, 2008 Baš. Jeste ograničeni, pa nemaju GSI i OPC različite ECU-e nego samo različite mape... Ako su pak i turbine jednake i IC-i jednaki, ispuh se lako riješi i otvori... Link to comment Share on other sites More sharing options...
huzek Posted November 14, 2008 Share Posted November 14, 2008 Ja sam se naučio da nema lakšega puta. Uvijek nažalost ima neka caka :sly: Link to comment Share on other sites More sharing options...
CitiuS Posted November 14, 2008 Share Posted November 14, 2008 A CitiuS šta kažeš za Gubića jel on dobro radi chip i to???:thumbsup: Cemu ovakva pitanja? Link to comment Share on other sites More sharing options...
Hic Posted November 14, 2008 Share Posted November 14, 2008 bas, ovo je trik pitanje Link to comment Share on other sites More sharing options...
CitiuS Posted November 14, 2008 Share Posted November 14, 2008 Pa nemam ja 19god da odgovaram na trik pitanja. Goran i ja smo OK i ne mislim tu davati svoje misljenje o njemu, bez obzira na to tko pita i zasto. Link to comment Share on other sites More sharing options...
CitiuS Posted November 14, 2008 Share Posted November 14, 2008 GSi ima isti motor ko i OPC sve isto samo šta je na ispuhu malo zagušeniji GSi i naravno softwer Da, taj auto mozemo dici na isto KS kao i OPC, ali se MORA mijenjati auspuh Link to comment Share on other sites More sharing options...
