pacey Posted June 6, 2011 Share Posted June 6, 2011 (edited) Imam u autu tv i odkada je preslo na digitalni signal, banana... sada gledam sto uzet, mislio sam da trebam reciver... a sto je ovo, jel bi to radilo? ili je to samo za reciver antena? kakve su cijene kod nas? http://cgi.ebay.com/Premium-Car-Digital-TV-Booster-Amplifier-Antenna-DVB-T-/330572856999?pt=AU_Car_Parts_Accessories&hash=item4cf7ad7ea7 savjete molim radi se o e39 sa OEM tv om i tim "đinđam minđam" Edited June 6, 2011 by pacey Link to comment Share on other sites More sharing options...
Ciki Posted June 6, 2011 Share Posted June 6, 2011 Ako zelis max kvalitetu skupo ces je platiti. Pogotovo da ti lovi u voznji ili sl. Link to comment Share on other sites More sharing options...
gandi Posted June 7, 2011 Share Posted June 7, 2011 to sa linka ti je samo antena. kupi scart stick DVB-T receiver, izvuci audio i video signale i spoji na taj oem TV. Naravno, ako ima AV ulaze. Link to comment Share on other sites More sharing options...
pacey Posted June 7, 2011 Author Share Posted June 7, 2011 Ako zelis max kvalitetu skupo ces je platiti. Pogotovo da ti lovi u voznji ili sl. ma nije mi bitno u voznji ionako ju gasi kada auto krene... vidio sam na ebay-u reciver za cca 60$ to sa linka ti je samo antena.kupi scart stick DVB-T receiver, izvuci audio i video signale i spoji na taj oem TV. Naravno, ako ima AV ulaze. ehh ne kuzim se ja bas toliko, al na kompu od tv-a nema onih crven,zut,bijel nego ima neki bmw konektor, pa se uzme bmw adapter za reciver samo me zanimalo jel ova antena ujedno i reciver hvala decki na odg:thumbsup: Link to comment Share on other sites More sharing options...
Nicko Posted June 7, 2011 Share Posted June 7, 2011 Antenu ne moraš drugu kupovati, dobra će biti i ova stara. Samo receiver moraš uzet Link to comment Share on other sites More sharing options...
Misek_Chipsy Posted June 7, 2011 Share Posted June 7, 2011 kak izvuc A/V signale iz scarta? Link to comment Share on other sites More sharing options...
Pavo Posted June 7, 2011 Share Posted June 7, 2011 iz onih pinova.. imao sam shemu Female connector seen from the front Pin 1 Audio output (right) Pin 2 Audio input (right) Pin 3 Audio output (left/mono) Pin 4 Audio ground Pin 5 RGB Blue ground (pin 7 ground) Pin 6 Audio input (left/mono) Pin 7 RGB Blue up S-Video C down[a] Component PB up Pin 8 Status & Aspect Ratio up[c] 0–0.4 V → off 5–8 V → 16:9 9.5–12 V → on/4:3 Pin 9 RGB Green ground (pin 11 ground) Pin 10 Clock / Data 2[d] Control bus (AV.link) Pin 11 RGB Green up Component Y up Pin 12 Reserved / Data 1[d] Pin 13 RGB Red ground (pin 15 ground) Pin 14 Data signal ground (pins 8, 10 & 12 ground) Pin 15 RGB Red up S-Video C up Component PR up Pin 16 Blanking signal up RGB-selection voltage up 0–0.4 V → composite 1–3 V → RGB Pin 17 Composite video ground (pin 19 & 20 ground) Pin 18 Blanking signal ground (pin 16 ground) Pin 19 Composite video output S-Video Y output Pin 20 Composite video input S-Video Y input Pin 21 Shell/Chassis[e] ali evo s NET-a Link to comment Share on other sites More sharing options...
cyberphere Posted June 7, 2011 Share Posted June 7, 2011 Ili jednostavno ovo Link to comment Share on other sites More sharing options...
dcrnic Posted June 7, 2011 Share Posted June 7, 2011 ja sam uzeo u chipoteci neki običan dvbt 200kn i do nekih 40kmh ima signala... frend je kupio neki jači oko 600kn je platio i vozili smo se 120kmh i nije bilo smetnji... Link to comment Share on other sites More sharing options...
Misek_Chipsy Posted June 7, 2011 Share Posted June 7, 2011 Cyber - u suprotnu stranu treba crnic lol jebes ili? ja doma ak antenu pomaknem pomrčina na telki :lol: Link to comment Share on other sites More sharing options...
dcrnic Posted June 7, 2011 Share Posted June 7, 2011 Budem snimio jednom prilikom... Link to comment Share on other sites More sharing options...
Misek_Chipsy Posted June 7, 2011 Share Posted June 7, 2011 aj link koji si uzeo Link to comment Share on other sites More sharing options...
pacey Posted June 7, 2011 Author Share Posted June 7, 2011 evo jedan jeftin a ok cini mi se + usb http://cgi.ebay.com/NEW-DVB-T-Digital-TV-Receiver-Cars-MPEG-2-DVB-510-/110690767889?pt=LH_DefaultDomain_0&hash=item19c5af1411 i jedan skuplji da pitam kada Hr predje na mpeg 4, gasi se 2 ili ostaje? http://cgi.ebay.com/Car-FreeView-HDTV-DVB-T-Receiver-Tuner-Mpeg-4-Mpeg-2-/280689758350?pt=LH_DefaultDomain_0&hash=item415a69d08e Link to comment Share on other sites More sharing options...
Misek_Chipsy Posted June 7, 2011 Share Posted June 7, 2011 gasi se al mpeg 4 cita i 2 i 4 tako da najbolje odma uzet mpeg4 i amen Link to comment Share on other sites More sharing options...
Goertosing Posted June 7, 2011 Share Posted June 7, 2011 Nemojte preporučavat stvari koje niste probali zato što sve to na ebayu izgleda divno i krasno a kad probaš ono k* Prijatelj je probao par komada tako na "preporuku" pa ono hvata signal slabije nego moj analogni Link to comment Share on other sites More sharing options...
pacey Posted June 7, 2011 Author Share Posted June 7, 2011 ima jedan decko na bmw forumu na e38, samo ne znam koji uredaj...uglavnom zadovoljan je, 99% da je mpeg2 znaci ode 100 eura za 4ku lol jebeno ajde neka neko preporuci neki koji je isproban, napominjem auto gasi kada se krene, tako da mi ne treba neki za obaranje rekorda...necu odkodirat tv da radi u voznji, jer bi vjerojatno vise tu buljio neg po cesti.. Link to comment Share on other sites More sharing options...
