Ciki Posted October 13, 2011 Share Posted October 13, 2011 Sad imam 195/45/16 ET25 ( i distance 20mm ali mislim da to nije bitno) Ako stavim drugu felgu sa gumom 185/55/14 ET34, da li ce to biti uvuceno unutra ili strsati van? probao one kalkulatore, ali nije to za mene :doh::drink: Link to comment Share on other sites More sharing options...
Pavo Posted October 13, 2011 Share Posted October 13, 2011 uvućeno unutra... trebat će ti distanca od 35mm Link to comment Share on other sites More sharing options...
Ciki Posted October 13, 2011 Author Share Posted October 13, 2011 ok, znaci i sa ovom distancom od 20mm ce biti u banani Hvala Link to comment Share on other sites More sharing options...
Coupe VD Posted October 13, 2011 Share Posted October 13, 2011 Ako su felge jednako široke (6J, 7J...) onda je ta nova felga 9 mm uvucenija od stare felge...dakle, s ovom distancom koju imaš će biti 9 mm više unutra nego što je sada. Pavo ti je dao površan odgovor pošto nije uopće pitao za širinu felge, što je jako bitno kad se računa ET, izbačaj, distance itd. Nije svejedno jel nova felga 6J ET34 ili 7J ET34 ili 8,5J ET34... Link to comment Share on other sites More sharing options...
Kevin Posted October 13, 2011 Share Posted October 13, 2011 probao one kalkulatore, ali nije to za mene :doh::drink: probaj ovaj! http://www.rimsntires.com/specs.jsp Link to comment Share on other sites More sharing options...
Mexx Posted October 13, 2011 Share Posted October 13, 2011 daj sirine felgi... Link to comment Share on other sites More sharing options...
Ciki Posted October 13, 2011 Author Share Posted October 13, 2011 Mislim da je 6,5 Link to comment Share on other sites More sharing options...
_DEX_ Posted October 13, 2011 Share Posted October 13, 2011 Mislim da je 6,5 Je Znakovi Link to comment Share on other sites More sharing options...
Pavo Posted October 13, 2011 Share Posted October 13, 2011 (edited) Pavo ti je dao površan odgovor pošto nije uopće pitao za širinu felge e jbg sad... pa s obzirom da stavlja profil 55 sigurno ga neće navlačit na 9J felgu... Edited October 13, 2011 by Pavo Link to comment Share on other sites More sharing options...
Mexx Posted October 13, 2011 Share Posted October 13, 2011 6,5 su obe? felga ko felga ce bit ubacenija unutra 29mm bez distancera. ako stavis 20mm distancer onda ce bit 9 mm ubacenija nego ova sada Link to comment Share on other sites More sharing options...
Ciki Posted October 13, 2011 Author Share Posted October 13, 2011 Kaos jebote Fala decki, volim vas! Link to comment Share on other sites More sharing options...
cone4u Posted October 13, 2011 Share Posted October 13, 2011 ajde kada je već otvoreno i friško auto pug 307 felge trenutne 7,5 j 17 et 42 i distanca 16mm a frenda zanima dali će 16 x 9 j et 15 stat pod blatobrane. koliko bi trebale biti vani više od ovih, hvala Link to comment Share on other sites More sharing options...
Mexx Posted October 13, 2011 Share Posted October 13, 2011 31 mm izbacenije Link to comment Share on other sites More sharing options...
Vlado206 Posted October 13, 2011 Share Posted October 13, 2011 Ciki: 14" i et34 da nije celicna od 206? Tako ona ima i 5.5 je siroka. Btw ja prodao decku na vtsa i na onap je isla. Link to comment Share on other sites More sharing options...
Coupe VD Posted October 13, 2011 Share Posted October 13, 2011 e jbg sad... pa s obzirom da stavlja profil 55 sigurno ga neće navlačit na 9J felgu... A moze bit 6 ili 6ipo ili 7...a ako ne uzmes u obzir sirinu felge - uzalud ti izracun. Link to comment Share on other sites More sharing options...
cone4u Posted October 13, 2011 Share Posted October 13, 2011 31 mm izbacenije uff a prednji blatobrani su plastični:lol::lol: ako oće to naautu morat će biti i "feniranja" Link to comment Share on other sites More sharing options...
