StormRS13 Posted December 16, 2011 Posted December 16, 2011 trenutacno na fiesti 1.1i imam gume 155/70R13, a imam jebenu ponudu za 175/65R14 kotače po tire calculatoru ispada da su 14ice 6.6% većeg opsega Specification Sidewall Radius Diameter Circumference Revs/km Difference 155/70-13 108mm 274mm 547mm 1719mm 582 0.0% 175/65-14 114mm 292mm 583mm 1832mm 546 6.6% sta mislite kako ce se to odraziti na vozna svojstva ? zanemarimo potrosnju i ubrzanja, i tak se 99% vremena vozim u gradu po ogranicenjima... cisto me zanima jel postoji kakva losa posljedica stavljanja 6% vecih guma
rimA Posted December 16, 2011 Posted December 16, 2011 Samo meći, nemaš beda Jedino tehnički i ti spike bi mogao pasti
charger Posted December 16, 2011 Posted December 16, 2011 vozna svojstva na fiesti 1.1 :lol: nezajebavaj razbojniče
Alfaludak Posted December 16, 2011 Posted December 16, 2011 ma to se on zajebava ja bi tebi stavio jednom u pak
malawi Posted December 16, 2011 Posted December 16, 2011 StormRS13 said: cisto me zanima jel postoji kakva losa posljedica stavljanja 6% vecih guma Ako je opseg veći 6%, onda će ti kilometar sat pokazivat 94km/h kad se po gps-u vozis 100km/h.. tako da ogranicenja brzine uzimas s rezervom :lol: to je najbitnija razlika na takvim kotacima, a usudio bi se reci i jedina :lol:
StormRS13 Posted December 16, 2011 Author Posted December 16, 2011 to je to onda... jer sad kad mi sat pokazuje 100kmh idem realnih 94kmh
Vlado206 Posted December 16, 2011 Posted December 16, 2011 sad se voziš cca 140 po satu a realno 130 onda ćeš se vozit cca 120 po satu a realno 130 tako je meni bilo kad sam stavio 205/45/17 nakon 195/50/15, kontra je pokazivalo...
Gringo Posted December 16, 2011 Posted December 16, 2011 Pa ako ćeš gledat ubrzanje kalendarski(sat nije dovoljan) do božića si na 130km/h i sa novim i većim gumama će ti nova godina prije doć!!!
Misek_Chipsy Posted December 16, 2011 Posted December 16, 2011 (edited) lol....koje nebuloze.....stavi i peglaj. Ak sam na svoj govnu od kie mogo imat 205,55,14 (i cak sam upisao u knjizicu, i tehnicki i sve bez ikakvog problema) sa standardnih 165,70,13 i vozit normalno, bome mos i na ovakvoj razlici Edited December 16, 2011 by Misek_Chipsy
chorawac Posted December 16, 2011 Posted December 16, 2011 E, da ne otvaram novi thread imam pitanje: Q: Idu li na Renault Clio II gume 195/50/15??? :huh: Naime, kupio sam alu felge širine 7,5 jota i čine mi se malčice preširoke za Clio. Zanima me jel ima tko iskustva s tom širinom guma na Cliu... Bojim se da ne bi prednji kotači bili na knap sa blatobranima... ili se strugali. :dontgetit:
Vlado206 Posted December 16, 2011 Posted December 16, 2011 Guma ko guma ide, veći je problem 7.5" felga i ovisno koji je ET. Inače da bud guma normala gore u 195 širini stavljaju 6.5 ili 7" felge, al da može i 7.5" ali moraš vidjet koji je ET da ne bi virila van ili pak bila previše unutra.
Misek_Chipsy Posted December 16, 2011 Posted December 16, 2011 problem "presiroko" ti je u 7.5j felgama a ne u gumama, na 6.5j mislim da ti je normalno, ovo je malo 2much za clio po mom misljeju ako nije ET dosta uvucen
killuminati Posted December 17, 2011 Posted December 17, 2011 chorawac said: E, da ne otvaram novi thread imam pitanje: Q: Idu li na Renault Clio II gume 195/50/15??? :huh: Naime, kupio sam alu felge širine 7,5 jota i čine mi se malčice preširoke za Clio. Zanima me jel ima tko iskustva s tom širinom guma na Cliu... Bojim se da ne bi prednji kotači bili na knap sa blatobranima... ili se strugali. :dontgetit: guma stane bez beda, imao ja na 1.4 16V, ali bitan ti je offset felge pošto je ista dosta široka..
