ulje za servo volana?
Meni kad je servo-pumpa na Cliu sport bila prozujala - nije pomogla promjena ulja. Inače...neko Motul-ovo smo bili stavili. Uglavnom kad god sam htio staviti neko "bolje" ili "najbolje" ulje negdje - na kraju bi se uvijek stavio neki Motul...bilo u kočnice, motor, servo itd...
ma prozuji samo kod težeg gaženja, čim se malo smirim :D za par minuta prestane
Navodno ekipa ugrađuje od Mondea MK2 hladnjak ulja i zamijene ulje.
What you need is:
The Oilcooler
I got mine from the scrapyard cost 10euro ^^
Then you need some hose...
The ones i use are regular fuel hose and the dimensions are inner diameter 9.5mm outer diameter 15.5mm i bought 3meters cost 10euro
Then you need a metal adapter for the old and the new hose.
All you have to do is to get the cooler between the power steering and the pas tank.
Pull the hose from the pas tank off mount the adapter then the new hose from to the cooler and then back from the cooler to the pas tank.
Thats all.
Fit the hose ecactly to the car and thats it
And change the old fluid
http://www.fordfiestast.co.uk/showflat.php?Cat=0&Number=336314&page=0&fpart=all&vc=1
E, da...ide ti unutra ATF Dextron III.
Nešto tipa ovo:
CASTROL TRANSMAX DEX III MULTIVEHICLE
(previously known as ATF TQ DIII)
General purpose mineral based automatic transmission and power steering fluid.
Can be used in place of ATF Dex II Multivehicle.
