Ja koristim eagle one za čišćenje, i to prvo namažem eagle one, obrišem, namažem opet ako je prljavije i opet obrišem. Pričekam malo da se posuši i onda gliptone namažem i pričekam da se posuši
  • Replies 156
Meguiars gold class je vrhunski..
Mene zanima koje su maramice za kozu najbolje?
Sonaxove nisu bas nesto pa ako je netko probao neke odlicne nek napise
Taj sonax je po meni skroz bezveze.
Meni se puno boljim pokazao Armor all Gel
meni je taj Armor all gel katastrofa. Koža se sjaji poslje za popizdit.
procita sam uputsva ali me cisto zanima kako su ostali radili sa gliptoneom
ima ovaj gentle cleaner i conditioner
očistiš siceve od prašine i bilo kakve šporkece; naneseš cleaner na aplikator i namažeš po sicevima. Ostaviš da djeluje i onda prebrišeš. A conditioner nemoj stavljat dok se ovo potpuno ne osuši
EDIT: conditioner također namažeš s aplikatorom
Leather Master cleaner i conditioner, nakon tretmana koža izgleda kao iz tvornice i full je matt i auto miriši kao novi, tj na kožu :D
našao na drugom forumu pa se sjetio topica:
It's called Swissvax Leather Healer.
This product is specially mixed to match the exact color of the factory leather at the swissvax factory. Each bottle takes 3-4 weeks to receive from Switzerland.
We applied it to the Coral red Boston leather found in this BMW 135i we recently detailed.
Full Detail Writeup:
Swissvax'ed: The Shiniest Sapphire Black 135i you've ever seen, with Blau-Weiss wax! - BMW 3-Series (E90 E92) Forum - E90Post.com
The application process is pretty simple, and leaves the seats looking new!
See for yourself...
Products Used:
Swissvax Leather Cleaner
Swissvax Leather Brush
Swissvax Leather Grinding Pad
Swissvax Leather Glaze (Leather Sealant)
Here's how the seat looked before:
Cleaning the leather first:
First we cleaned the surface to be treated and grinded the frayed leather using the grinding pad. then applied the Leather Healer. We ended up applying about 5 coats with about 30 min between each coat.
And the finished result!
Swissvax je vrhunska kozmetika, al kostaaaaaaa
A ovaj gore primjer što si stavio s tim BMWom s crvenom kožom to si promašio temu.
Ovdje se priča o sredstvima za njegu i održavanje kože, s kojima koža postaje mekana, otpornija, miriše itd. I s time se ne mogu popravljati oštećenja na koži.
A to gore što si stavio su sredstva za retuširanje, kompletno nova boja. Lik nije išao u detalje, al proces za to je dosta kompliciraniji. Da se napravi kako treba, prvo ide brušenje kože i skidanje postojećeg sloja, pa čišćenje od svih organskih ostataka, pa priprema za retuširanje i onda nanošenje nove boje
Jel radi tko u hrvatskoj tako nešto? Meni je sic od suvozača jako izjeban, a nova navlaka za sjedeći dio, odnosno ta koža, košta 2500 kn :lol:
Imaš raznih ljudi što to "rade" po HR, al ja moje siceve u njihove ruke ne bi dao ni da oni meni plate. Jer svi takvi s kojima sam se susreo misle da to znaju radit, a rezultati su totalno uništena koža (recimo http://www.carat.hr il tako nekako)
Preporučio bi ti da se staviš jedan dan, uzmeš DW 'u ruke', proučiš sve detalje i sam se baciš na posao, al prije toga testiraš na nekom uzorku kože. A nije isto za svu kožu, radi se drugačije, ovisno o vrsti i boji kože.
čuo sam da jedan čovjek radi to odlično kod nas (Željko se zove), negdje iza antunovića mu je garaža...
ne znam da li netko ima iskustva s njim
znaci taj carat nije baš za preporuku?
Minđa pa koliko se ja sjećam od onda kad smo Rudy i ja bili u St koža u tvom BMW-u je do jaja što bi ti sad čačko mečku :D
i koja je cijena tretmana?
ajd Borna ispitaj to malo bolje :)
za popravak ošteenja sličnom ovom na crvenoj koži od Bmw-a sa fotki je cca 300kn...auto je kod njega cijeli dan i noć, i drugi dan ga pokupiš
djeluje mi da zna kaj radi, a i vidio sam na jednom bmw-u kako je napravio i niš se ne kuži
Daj probaj saznati gdje točno ili neki kontakt. Da je i 1000 kn popravak jeftinije mi je od nove navlake
091/5282592 Željko
nalazi se iza Antunovića
