toc Posted July 2, 2016 Posted July 2, 2016 Koje dizne mi trebaju za 2.0tdi, PD, BKD? Stavio sam danas veliku turbinu, pa mi fali nafte Dali se mogu pripasati neki drugi ulosci ili bas moram dati 400e za one neke trkace +120%?
fire Posted July 2, 2016 Posted July 2, 2016 Koje dizne mi trebaju za 2.0tdi, PD, BKD?Stavio sam danas veliku turbinu, pa mi fali nafte Dali se mogu pripasati neki drugi ulosci ili bas moram dati 400e za one neke trkace +120%? Serijske su ti dosta za 250-260HP. Na kolko ciljas?
Dac Posted July 3, 2016 Posted July 3, 2016 Uff volim kad ti fire komentira,jaooo kad ce se to uglazbit da vidimo kaj to je ??
Luky Posted July 3, 2016 Posted July 3, 2016 ne pristajem na ništa ispod 300 Malo si preoptimistican..
DaracRS Posted July 3, 2016 Posted July 3, 2016 Ja bi ti preporucio da ides na max ks kolko mogu dat seriske dizne.
toc Posted July 3, 2016 Author Posted July 3, 2016 Ja bi ti preporucio da ides na max ks kolko mogu dat seriske dizne. Razlog?
toc Posted July 3, 2016 Author Posted July 3, 2016 Aaa ok onda....na kolko tlaka mislis ic max? Ja ti se u to ne kužim. Meni je bitno da ide Turbo je od a6 3.0 TDI, GT2260
Lovrek Posted July 3, 2016 Posted July 3, 2016 Ajde da i jedan bkd bude slozen kod nas... Steta da sam svog prodao ako ti sto pomaze, gledaj http://www.darksidedevelopments.co.uk Oni su ja mislim bkd u jetti nasvirali na 300ks...
toc Posted July 3, 2016 Author Posted July 3, 2016 Ajde da i jedan bkd bude slozen kod nas... Steta da sam svog prodao ako ti sto pomaze, gledaj http://www.darksidedevelopments.co.ukOni su ja mislim bkd u jetti nasvirali na 300ks... Vidio imaju sve, al su i cijene paprene.
toc Posted July 4, 2016 Author Posted July 4, 2016 Jel mi treba drugi map senzor? Ako da koji i od cega mi pase?
Hic Posted July 4, 2016 Posted July 4, 2016 Trebas drugi turbo ili ovaj hibridizirati. Ne bi bilo lose map od 4bara, i firadice, ali kalibrirane! U setu!
toc Posted July 4, 2016 Author Posted July 4, 2016 Trebas drugi turbo ili ovaj hibridizirati. Ne bi bilo lose map od 4bara, i firadice, ali kalibrirane! U setu! Recimo do bi za sada ostao na turbu takav kakav je... Ajmo malo o ciframa, kolko kosta taj set?
Hic Posted July 4, 2016 Posted July 4, 2016 Iskreno ne znam, ali mogu pogledati i javiti ti. Za npr. 311ks treba ti hibridni turbo sa pravim usisom, bregasta i dizne. Ne bi mozda bilo lose promjeniti srafe na klipnjacama, ali to je samo predostroznosti radi.
toc Posted July 4, 2016 Author Posted July 4, 2016 Ma nebi dirao turbo, nek bude i 280ks za prvu ruku. Ajd vidi cijene pa javi, ako ti nije problem.
Luky Posted July 4, 2016 Posted July 4, 2016 Kazem ti preoptimistican si.. 260 ks ako budes imas s tim turbom da traje budi zadovoljan..
