rio_cyber Posted February 11, 2009 Posted February 11, 2009 to se ne tokari nek brusdi ak bas ocete pravi posao napraviti... ali ajde proalzi i tokarilica ako radi netko tko zna sta radi..
J.J Posted February 11, 2009 Posted February 11, 2009 Poglečte smajliče papci ....... buahahahahahah C2 je ovak i onak mali pa stane na stol cijeli A i ne pusim da je dobro i precizno kao na stolu .....
Dado_666 Posted February 11, 2009 Posted February 11, 2009 Dado_666 said: ti si bar strojar, i ne znaš vid mrcine :rofl: hm.. slika mi se ne vidi.... http://lh5.ggpht.com/_3e0TmlTDLeg/Ryvl7O259rI/AAAAAAAAA1Q/Ad_4zqIjflY/Pump_Trip_095.JPG
rio_cyber Posted February 11, 2009 Posted February 11, 2009 hm, nemoj sad da vas zahebem i posaljem u koncar gledati tokaraski koji na suportu ima kabinu i sic i sjedis si na tome,a alat vozi jednu stotu cjeli dan u jednom smjeru, a bez viljusakra 5 tona nemres alat zmenitn nikak,, ja bi nasel nacim da cjeli c2 zvrtim u amerikaneru ;P ak bas treba..
J.J Posted February 11, 2009 Posted February 11, 2009 Ne vidi se opet papak....hahaha 2 Rio> pa ima ih koji bi to i mogli !! hahaha
Rajmond Posted February 12, 2009 Posted February 12, 2009 Ivsa said: Ja u Mazdinom servisu gledao kako tokare disk na autu, skine gumu i umjesto nje nasarafi nekakav strojcek s nozem i sve radi na aut bez skidanja diskova! Točno tako...auto na dizalicu i lagano tokare.
puki Posted February 12, 2009 Author Posted February 12, 2009 Ivsa said: Ja u Mazdinom servisu gledao kako tokare disk na autu, skine gumu i umjesto nje nasarafi nekakav strojcek s nozem i sve radi na aut bez skidanja diskova! dali se sjecas u kojem je to servisu bilo ??
Dado_666 Posted February 12, 2009 Posted February 12, 2009 J.J said: Ne vidi se opet papak....hahaha glupi gugl!! :rofl: ko kaže da na ovo nebi stao C2 :punk:
Seb Posted February 12, 2009 Posted February 12, 2009 Dado_666 said: jel to cijena za tokarenje na autu ili ako skine disk :rofl: skinuti disk ima stroj za tokarenje na autu ali kad gledaš kolko ti treba da njega smontiraš da potokari disk prije skineš disk i metneš na stroj
Dado_666 Posted February 12, 2009 Posted February 12, 2009 ma nemoj mene slušat ja zajebajem samo nego sad ozbiljno, a kak taj stroj tokari unutarnju stramu diska, naprimjer zadnjeg, ja imam nekakav pleh koji štiti disk valjda od vode i prekriva ga cijelog..
rura gsi Posted February 13, 2009 Posted February 13, 2009 Ja na poslu svako malo tokarim diskove,i sve 5 samo mi na stroj mogu diskovi do 300mm! A cjena tokarenja kod mene je 2x2l löwenbrau:drink:
Ivsa Posted February 13, 2009 Posted February 13, 2009 2Puki: Ja sam takvo tokarenje vidio u Mazdi Vranić-Vukšič u Sl. Brodu. To su radili na nekih 60 000 km. Ali vjerujem da to imaju svi Mazdini servisi jer koliko sam skuzio to im je normalna procedura prije izmjene plocica...
Dinac Posted December 2, 2009 Posted December 2, 2009 se mogu tokariti ovakvi diskovi : uzeo sam nove plocice, jer ove TAROX za "track day " mi vise po hladnom ne koce kak spada a i cvile dok se ne zagriju posteno Isao bi kod ovih u Siget di imaju tokarilice gdje se nemoraju skidati diskovi
Auto-Robi Posted December 2, 2009 Posted December 2, 2009 (edited) http://www.rondodoo.hr/site/mad/mad-8700 Edited December 2, 2009 by Auto-Robi
Risbo Posted December 3, 2009 Posted December 3, 2009 A mislim da se mogu tokariti, ali treba puno pažljiviji biti
ND4SPD Posted December 3, 2009 Posted December 3, 2009 Dinac said: se mogu tokariti ovakvi diskovi : uzeo sam nove plocice, jer ove TAROX za "track day " mi vise po hladnom ne koce kak spada a i cvile dok se ne zagriju posteno Isao bi kod ovih u Siget di imaju tokarilice gdje se nemoraju skidati diskovi Kaj ti tresu diskovi? Mozda je do sloja koji su plocice ostavili na disku ... Stavi neke druge plocice, pa probaj raskociti... Quote evo jedna prica koja ide pod kategoriju "putting your money where you mouth is.." suprotno uvrijezenom misljenju da se diskovi pigaju samo tak i onda tresu, oduvijek sam bio proponent teorije da se diskovi ne pigaju (u principu) vec da tresnja dolazi od krivo raskocenih diskova, neravnomjernih slojeva materijala s plocica na disku..... te da je tresnja vecinom posljedica nesrazmjera izmedju stila voznje i plocica koje se koriste.. e, sad.. nedavno sam naletio na decka koji je kupio EVO 8.. on je imal gore skupe DBA diskove i ferodo ds2500 plocice (plocice samo naprijed... straga ATE..)... Uglavnom, njemu je to strasno treslo.. On je to pripisao losim diskovima/pranju vrucih kocnica... itd... Uglavnom skinul ih je dole i zamijenio cijeli set.. sad je happy s EBC bremzama.. Uglavnom kupil sam taj cijeli set kaj je treso, platio koliko je trazio... i iso probat teoriju... Naime, na EVOima je ds2500 poznata kao plocica koja voli ostavljat neravnomjerne naslage na disku i dost cesto uzrokuje tresnju diskova.. Ideja je bila da uzmem diskove i bez ikakvog tokarenja probam ih dovest u red koristeci plocice koje inace preferiram a to je Carbotech XP10... Kako sam taman potrosio set, zmontirao sam na auto DBA sa ferodo plocicama koje su dosle s njima.. dakle ovima koje su tresle... Ideja je bila da ih probam raskocit na grobniku, jer cu ih tam moc zgrijat kak spada.. uglavnom... auto je fakat grozno treso.. Na grobniku pogotovo.. kocenje u onaj S poslje rijeckog je trgal volan iz ruku.... Uglavnom, fakat koma.. jasno mi je zakaj je to hitil s auta... no, doso noi set XP10.... hitil sam to na auto i isprva je naravno treslo, no nakon dva seta jakih raskocavanja (kocenje 160 - 80 km/h vise puta dok se bremze skoro pa pregriju..) uz pravilno lagano hladjenje poslje...+ jedno sljeme mogu rec da sam ipak uspio.... Auto vise uopce ne trese, jedino je zamjetno lagano podrhtvanje pri jako laganom kocenju... no to ce postepeno otic.. Da sam eventualno potokario diskove mozda bi si malo ubrzao ovaj postupak no samo tokarenje bez promjene plocica nebi rjesilo stvar... pouka: 1. diskovi se ne pigaju 2. ako konstantno tresu, promijeni plocice i raaskoci auto kak spada.. 3. ak se vozis lagano, onda kupi obicne plocice 4. nikad ne ostani lezat na bremzi nakon sto si naglo stao, nikad ne ostati stisnutih bremzi ako su iste vruce . . .
Dominik Posted December 3, 2009 Posted December 3, 2009 puki said: dali se sjecas u kojem je to servisu bilo ?? imas to u sigetu, kod tehnickog pregleda, ja radio vise puta, sve 5
