J@nkinjo Posted February 24, 2009 Posted February 24, 2009 Nabavio sam si nove felge i sada me zanima imali razlike između ove dvije dimenzije stare felge su bile 7x17 ET37 a nove su 8x17 ET35! Kolika bi razlika bila kada se to svavi na auto??
kutija Posted February 24, 2009 Posted February 24, 2009 Nova felga ce ti bit vani vise za 15mm ,a unutra vise za 10mm...
Veki Posted February 24, 2009 Posted February 24, 2009 ove nove više van za 1,5 cm ? bubnuo pa možda ostanem živ :lol:
the-rider Posted February 24, 2009 Posted February 24, 2009 kutija said: Nova felga ce ti bit vani vise za 15mm ,a unutra vise za 10mm... :thumbsup:
Luky Posted February 24, 2009 Posted February 24, 2009 dal nebi trebala bit samo 2 mm van u odnosu na staru? a unutra 20+mm? ako sam fulao, moze netko rec zasto onda tako?
Veki Posted February 24, 2009 Posted February 24, 2009 zato jer se ET mjeri od "sredine" felge..a nova felga je 1" šira pa se sredina pomiče za polovicu toga..dakle 1,27 cm ..+ još ova 2 mm..
Luky Posted February 24, 2009 Posted February 24, 2009 Veki said: zato jer se ET mjeri od "sredine" felge..a nova felga je 1" šira pa se sredina pomiče za polovicu toga..dakle 1,27 cm ..+ još ova 2 mm.. zahvaljujem..
dcrnic Posted February 24, 2009 Posted February 24, 2009 koji je et kada na felgi ne piše et, tj piše samo et i pored ništa... prokleti talijani, ništa nemogu napraviti kako spada... :lol:
Bagi Posted February 24, 2009 Posted February 24, 2009 http://felgen.net/einpresstiefe.html ne da mi se prevoditi, ali se sa slike kuži, a bilo već 100x
Luky Posted February 24, 2009 Posted February 24, 2009 (edited) dcrnic said: koji je et kada na felgi ne piše et, tj piše samo et i pored ništa... prokleti talijani, ništa nemogu napraviti kako spada... :lol: ma to mora da je u kini pravljeno.. :lol: i kad je ET i pored njega nista onda je nula.. :rofl: al evo bagi te rijesio muka.. samo metar u ruke i mjeri.. Edited February 24, 2009 by Luky
dcrnic Posted February 24, 2009 Posted February 24, 2009 Ovdje utipkavaš sve podatke i sam računa... čak mislim da i sliku/skicu izbaci... http://www.carbibles.com/tyre_bible_pg2.html
13snc Posted February 24, 2009 Posted February 24, 2009 http://www.1010tires.com/WheelOffsetCalculator.asp
speljac Posted February 28, 2009 Posted February 28, 2009 Da se nadovežem na temu. Serijske 17" na mom autu imaju ET 35. Dal ja mogu stavit 17" felge sa ET 40 gore?
Lovrek Posted February 28, 2009 Posted February 28, 2009 mozes, vjerojatno ti nista nece strugati unutra, jer ce ti te felge biti 5mm manje izbacene prema van....
speljac Posted February 28, 2009 Posted February 28, 2009 Zato i pitam, znam da će biti više prema unutra. Morat ću isprobat prije kupnje. Tnx
