entuzijast Posted September 15, 2017 Posted September 15, 2017 (edited) Poreč - 28. - 30.09.2017. http://rally-croatia.com/hr/ Bodovanje: FIA Europski reli trofej za vozače i suvozače (koef. 3) FIA ERT2 trofej (ERT2) za vozače i suvozače FIA ERT3 trofej (ERT3) za vozače i suvozače FIA ERT junior trofej (ERTJ) za vozače FIA Prvenstvo Centralno Europske Zone Prvenstvo Hrvatske Državno Prvenstvo Republike Slovenije u reliju Raspored: Ceremonijalni start u četvrtak 28.09. u 20:01 ------------------- 29.09. --------------------- Shakedown 12:00 - 15:00 Start rallya - 17:01 Start BI Fuškulin 1 - 17:26 Start BI Fuškulin 2 - 19:22 ------------------- 30.09. --------------------- Start BI Cerovlje 1 - 9:59 Start BI Boljun 1 - 10:42 Start BI Cerovlje 2 - 12:05 Start BI Boljun 2 - 12:48 Start BI Butoniga 1 - 15:56 Start BI Sovinjak 1 - 16:24 Start BI Butoniga 2 - 17:32 Start BI Sovinjak 2 - 18:00 Program za gledatelje: http://rally-croatia.com/wp-content/uploads/2016/07/CR2016-Program-za-gledatelje.pdf Posebni pravilnik: http://rally-croatia.com/wp-content/uploads/2016/07/CR2017-Posebni-pravilnik.pdf Karte: Event: Edited September 15, 2017 by entuzijast
TheFog Posted September 27, 2017 Posted September 27, 2017 ide ko sutra/preksutra dolje iz zg da moze povest 2 trkaca sica?
Rallye VR6 Posted September 27, 2017 Posted September 27, 2017 On 27. 09. 2017. at 18:49, TheFog said: ide ko sutra/preksutra dolje iz zg da moze povest 2 trkaca sica?Nosis mi siceve? Bas si srce micek Poslano sa mog SM-J510FN koristeći Tapatalk
Nicol Posted September 28, 2017 Posted September 28, 2017 Krvavi brzinci bome ove godine... Ko prezivi, pricat ce Poslano sa mog Power koristeći Tapatalk
Seb Posted October 2, 2017 Posted October 2, 2017 44 Croatia Rally BI 1 https://youtu.be/epfshDyj7W8 BI 2 https://youtu.be/HKpc22KDr28 BI 3 https://youtu.be/_SLs-rb7FC8 BI 4 https://youtu.be/NyIffssptOI BI 5 https://youtu.be/f0p5FYntNYA BI 6 https://youtu.be/xL-fCwrmwXE BI 7 https://youtu.be/UCCrjIlkz1A BI 8 https://youtu.be/3LcJzuGmdJ8 BI 9 https://youtu.be/UCe2l54LjKo BI 10 https://youtu.be/zbuNfJQsfPY shakedown 1 https://youtu.be/_QHiVDc_BA4 shakedown 2 https://youtu.be/w69vnQFEltM Kratki rezime: Prvi dan 44. Croatia rally prošo sa standardnim pehovima. I na 1. i 2. brzincu nam je napola odpao zaštitni pleh ispod motora. Dva jača haklanja, skok i opet hakl i išupah vijke sa L strane. Na drugom opet isti dio brzinca ali sada sa desne strane. Imali smo 45 min, nešto sam improvizirao, zavario i završili smo! Kočnice sa kojima smo došli i nisu nikako radile ajde još pomozi Bože, nekako su radile mada su bile nestabilne i nisam mogao sa sigurnošću pogodit točke kočenja. Giht mi rasturao L nogu tako da sam etape šaltao bez kvačila. I tak! Drugi dan su se pehovi nastavili. Na 4. brzincu su kočnice otkazale na 20%. Zaštitni pleh sam opet odvalio. Uspio sam otkinut i komplet auspuh di je ionako težak i nejak auto izgubio još x ks. Sve složimo osim auspuha, na 8. brzincu na prvoj trećini otkaže kuplung cilindar. Složim sve i završimo na kraju 4. sa, mislim, 14 sec zaostatka za 3. Usporedivši 8. i 10. brzinac koji su isti, 10. smo bili brži 27 sec. Znaci možda bi bili 3. da nije bilo problema sa kuplungom. Ispred su R2 automobili nedostižni za našu staru baku Alfu a i dečki za volanima R2 auti se ipak malo bolje voze od mene! Čestitam im! Zadovoljan što smo u cilju i sa vožnjom s obzirom na sve ali plasman mi nije baš! 1
Risbo Posted October 9, 2017 Posted October 9, 2017 Jel ima šta da niste strgali I čestitke na završetku s obzirom na sve probleme
Seb Posted October 23, 2017 Posted October 23, 2017 On 09. 10. 2017. at 10:10, Risbo said: Jel ima šta da niste strgali I čestitke na završetku s obzirom na sve probleme Expand noge hvala
