kreza Posted March 1, 2009 Share Posted March 1, 2009 znači triba mi pomoć hitno ovako na autu su felge 8*18 et 42. dosta ljudi mi govori kad se stavljaju gewinde ako felga nije tvornička onda trebaju se stavljat distance. zanima me dali na moju dimenziju felge trebaju ić distance jer ako trebaju onda mi otpada varijanta gewindi jer auto se neće moć ni 3 cm spustit. Link to comment Share on other sites More sharing options...
Cokolino Posted March 1, 2009 Share Posted March 1, 2009 zasto distance? mislis da ce ti strugati iznutra?:huh: Link to comment Share on other sites More sharing options...
kreza Posted March 1, 2009 Author Share Posted March 1, 2009 tako su rekli... aj čekamo ove šta su već stavljali da vidimo šta oni kažu. Link to comment Share on other sites More sharing options...
Veki Posted March 1, 2009 Share Posted March 1, 2009 pa koja je serijska dimenzija felgi na gti-u ..jel manja od 8x18 ? i koji ET Link to comment Share on other sites More sharing options...
niknejm Posted March 1, 2009 Share Posted March 1, 2009 imho, gewinde imaju manji fi od opruga kroz koje prolaze amortizeri.. tako da mi nije logicki.. moguce da sam u krivu naravno Link to comment Share on other sites More sharing options...
kreza Posted March 1, 2009 Author Share Posted March 1, 2009 ne znam jel 7,8 ili 8 *18 al et je mislim od 48-52 Link to comment Share on other sites More sharing options...
matija0311 Posted March 1, 2009 Share Posted March 1, 2009 manji je fi gewindi..bar je na mojima... Link to comment Share on other sites More sharing options...
Luky Posted March 1, 2009 Share Posted March 1, 2009 manji fi je.. al meni je npr. na golfu 3 strugala malo zadnja guma po oprugi od gewinde.. al mislim da tebi nebi trebalo strugat.. nazad ti je odvojen amortizer i opruga.. a naprijed je opruga šira od gewinde.. Link to comment Share on other sites More sharing options...
Cokolino Posted March 1, 2009 Share Posted March 1, 2009 (edited) imho, gewinde imaju manji fi od opruga kroz koje prolaze amortizeri.. tako da mi nije logicki.. moguce da sam u krivu naravno kod golfa 5 ionako zada nisu opruge na amontizeru, a naprijed koliko mi se cini ima vise prostora:) cut ce se za par dana Edited March 1, 2009 by Cokolino Link to comment Share on other sites More sharing options...
DarioB Posted March 1, 2009 Share Posted March 1, 2009 kod golfa 5 ionako zada nisu opruge na amontizeru, a naprijed koliko mi se cini ima vise prostora:) cut ce se za par dana nije vrag da i ti ides na gewinde? Link to comment Share on other sites More sharing options...
Cokolino Posted March 2, 2009 Share Posted March 2, 2009 nije vrag da i ti ides na gewinde? kud svi tud i mali mujo:D Link to comment Share on other sites More sharing options...
bravo-ri Posted March 2, 2009 Share Posted March 2, 2009 Meni su sutrugale naprijed,morao sam staviti 1 cm distance... Link to comment Share on other sites More sharing options...
megane Posted March 2, 2009 Share Posted March 2, 2009 nije vrag da i ti ides na gewinde? opet laže :lol: Link to comment Share on other sites More sharing options...
DarioB Posted March 2, 2009 Share Posted March 2, 2009 opet laže :lol: ma nije on takav :lol: Link to comment Share on other sites More sharing options...
13snc Posted March 2, 2009 Share Posted March 2, 2009 kreza.. na leonu je idealan ET 45 ako je felga 8.5.. bar tako Lovrek tvrdi... ja isto gledam neke felge sa 42 ET ali su 8 sirina tako da ce to bit taman.. mislim da ne bi trebalo strugat s unutarnje strane.. di uzimas gewinde? kad? mozes na PM Link to comment Share on other sites More sharing options...
WD40 Posted March 2, 2009 Share Posted March 2, 2009 Meni su sutrugale naprijed,morao sam staviti 1 cm distance... I meni isto prednje..... Tj. nisam mogao spustit koliko sam htjeo. Distanca 8mm je rjesila problem:thumbsup: Link to comment Share on other sites More sharing options...
matija0311 Posted March 2, 2009 Share Posted March 2, 2009 jedno pitanje... spustio sam auto na cca 2cm od kraja navoja..možda malo manje...i nije niš extra pao i ne drži ko prije...al fakat..mekani je dost..nemojte mi sad one sheme gewinde su banana ovo ono jer je sve bilo super prije...možda neš drugo otišlo? Link to comment Share on other sites More sharing options...
WD40 Posted March 2, 2009 Share Posted March 2, 2009 Koje gewinde su u pitanju. Ja imam jeftine i jedini je problem sto kad su na najvisem razini onda je auto tvrdo i uopce nefederira posto je opruga dosta napregnuta. Tako ispada da sto ga vise spustim da je sve udobniji.... Sprijeda imam jos 5cm straga 7 Link to comment Share on other sites More sharing options...
Luky Posted March 2, 2009 Share Posted March 2, 2009 Koje gewinde su u pitanju. Ja imam jeftine i jedini je problem sto kad su na najvisem razini onda je auto tvrdo i uopce nefederira posto je opruga dosta napregnuta. Tako ispada da sto ga vise spustim da je sve udobniji.... Sprijeda imam jos 5cm straga 7 a dal nebi trebalo bit sto je nizi da je tvrđi? :huh: al kod gewinde je opruga uvijek jednako nategnuta.. jer se samo navoj pomiče.. a kad ide nize amortizer ima manje hoda i treba bit tvrđe.. barem ja tako mislim.. Link to comment Share on other sites More sharing options...
WD40 Posted March 2, 2009 Share Posted March 2, 2009 (edited) Vjerovatno jest kod boljih al kod mene je sistem da sto vise gewindas prema gore auto se podisava al opruga se stisce i onda je auto tvrđe zbog opruge. Kad je zgewindana skorz gore onda je ova mala opruga sitnuta Edited March 2, 2009 by WD40 Link to comment Share on other sites More sharing options...
zizz Posted March 2, 2009 Share Posted March 2, 2009 e tak je i kod mene, sto je auto visi to je tvrdi.... a ovo da ne ide nize, to nemam problema, da ti nije nesto leglo na nesto i da nema vise mjesta.... Link to comment Share on other sites More sharing options...
matija0311 Posted March 2, 2009 Share Posted March 2, 2009 wd ima istu stvar ko i ja vidim ok...znači nisam ja niš sjebal moram još povezatt vilice dole i to bu to Link to comment Share on other sites More sharing options...
Luky Posted March 2, 2009 Share Posted March 2, 2009 e tak je i kod mene, sto je auto visi to je tvrdi.... a ovo da ne ide nize, to nemam problema, da ti nije nesto leglo na nesto i da nema vise mjesta.... kod mene na trojci je bio spusten dosta i nije bio mekan.. i kad je dignut, mislim da je bio malo meksi.. al nista strasno.. matija: jos moras par sipkica stavit i to ce bit to.. Link to comment Share on other sites More sharing options...
matija0311 Posted March 2, 2009 Share Posted March 2, 2009 išel bu sad do kraja navoja sam da kiša stane..ja sam mislil da sam sjebal neke al vidim da je sve ok:D Link to comment Share on other sites More sharing options...
WD40 Posted March 2, 2009 Share Posted March 2, 2009 (edited) To kad je zavidan do kraja moguce da je tvrđi jer je hod bio ograničen onim odbojnim gumama pa je zato bio tvrđi. Jbg nemam stelanje tvrdoće a to bi onda rjesilo stvar Meni nemoze nize zbog kotača vs blatobran a ak bi to rjesio onda bi bio problem s optikom..trebalo bi tokarit sarafe na rukavcu... Edited March 2, 2009 by WD40 Link to comment Share on other sites More sharing options...
