Pedja Posted December 21, 2018 Share Posted December 21, 2018 Trebam to obaviti u blizoj buducnosti pa me zanima kako, gdje i na sto paziti (i ostalo). Svaki savjet je dobrodosao... Znaci rijec je golfu 5 gti i presao bi na brembo 345mm diskove i boxster 4klipne celjusti. Diskovi su novi, celjusti rabljene. Takoder, ugradio sam nove gewinde pa zanima i ta procedura (dobio sam s njima tvornicki certifikat). Lokacija, Zg i okolica gdje god je lakse to obaviti. PS: da li pri atestaciji gledaju i druge stvari na autu (katalizator, usis...)? HvalaLpp Sent from my CLT-L29 using Tapatalk Link to comment Share on other sites More sharing options...
Exfreerider Posted December 21, 2018 Share Posted December 21, 2018 Ja bi samo gewinde atestirao, 300kn mini atest i bok Link to comment Share on other sites More sharing options...
Pedja Posted December 21, 2018 Author Share Posted December 21, 2018 Neki lik koji radi u STP mi je rekao 870kn samo za gewinde Sent from my CLT-L29 using Tapatalk Link to comment Share on other sites More sharing options...
krule Posted December 21, 2018 Share Posted December 21, 2018 19 minutes ago, Pedja said: Neki lik koji radi u STP mi je rekao 870kn samo za gewinde Sent from my CLT-L29 using Tapatalk reko ti je cijenu velikog atesta, mini atest od 300 kn vrijedi samo za kotače Link to comment Share on other sites More sharing options...
Exfreerider Posted December 21, 2018 Share Posted December 21, 2018 Nedavno sam se raspitivao za gewinde što spada pod mini atest a cijena za mini atest je cca 300kn ako bi atestirao i drugu dimenziju guma uz gewinde 300+300 Link to comment Share on other sites More sharing options...
Pedja Posted December 21, 2018 Author Share Posted December 21, 2018 Ok hvala. To se obavlja u STP? Sent from my CLT-L29 using Tapatalk Link to comment Share on other sites More sharing options...
Exfreerider Posted December 21, 2018 Share Posted December 21, 2018 Da svaka bolja STP govorim za ZG Link to comment Share on other sites More sharing options...
Pedja Posted December 21, 2018 Author Share Posted December 21, 2018 Ok tnxSent from my CLT-L29 using Tapatalk Link to comment Share on other sites More sharing options...
Kic Posted December 21, 2018 Share Posted December 21, 2018 45 minutes ago, Exfreerider said: Nedavno sam se raspitivao za gewinde što spada pod mini atest a cijena za mini atest je cca 300kn ako bi atestirao i drugu dimenziju guma uz gewinde 300+300 Ako nije opet neka novina uvedena gewinde spadaju pod veliki atest. Ako ovijes ima TUV i spusten je kako je u tom dokumentu navedeno ne bi trebalo biti problema osim ako nemas neke ogrome kotace ili neodgovarajuci ET. Jedan strazni kotac ide na navoz od cca 20 cm i gleda se dali je naprijed kotac ima min 8mm "lufta" unutar blatobrana pod punim lock-om. Za kocnice bez TUV ili KBA nisam cuo da je netko uspio atestirati, pogotovo ne sa plivajucim diskom. Gleda se KOMPLETAN auto... meni popisivao homologacijske brojeve sa šajbi npr. Link to comment Share on other sites More sharing options...
Pedja Posted December 21, 2018 Author Share Posted December 21, 2018 Đizus... Znaci ako nemam katalizator i imam gljivu na usisu mogu se slikati... Sent from my CLT-L29 using Tapatalk Link to comment Share on other sites More sharing options...
Dario Posted December 21, 2018 Share Posted December 21, 2018 44 minutes ago, Kic said: Ako nije opet neka novina uvedena gewinde spadaju pod veliki atest. Gleda se KOMPLETAN auto... meni popisivao homologacijske brojeve sa šajbi npr. naravno da su uveli jedna komponenta - mini atest vise komponenta - normalni atest novost kod opruga i gewindi / ispis sa špura(optike) a tebi je gledo kompletan auto jer nije vjerovo da nije na oplu strunulo meni na atestu su i napred i nazad jedan kotac stavljali na navoz i slikali i mjerili ja sam atestirao SVE odjednom i bok, miran sam Link to comment Share on other sites More sharing options...
Pedja Posted December 21, 2018 Author Share Posted December 21, 2018 Znaci Darac po tebi je najbolje da odjednom odradim i kocnice i gewinde? Sent from my CLT-L29 using Tapatalk Link to comment Share on other sites More sharing options...
Dario Posted December 21, 2018 Share Posted December 21, 2018 pa odradis sve odjednom i miran si auspuh usis sve sto mozes upises Link to comment Share on other sites More sharing options...
Pedja Posted December 21, 2018 Author Share Posted December 21, 2018 Ok, jedino me brine kaj nemam kat....Sent from my CLT-L29 using Tapatalk Link to comment Share on other sites More sharing options...
Dario Posted December 21, 2018 Share Posted December 21, 2018 vrati serijski DP i atestiraj katback Link to comment Share on other sites More sharing options...
Kic Posted December 21, 2018 Share Posted December 21, 2018 Bez papirologije (TUV, KBA, potvrda proizvođaća) don`t bother. @Dario Good one! Ali za felge bez KBA/TUV nisu niti trepnuli (odobrena dimenzija od GM-a) ? Link to comment Share on other sites More sharing options...
Kevin Posted December 22, 2018 Share Posted December 22, 2018 dakle, ako ides stavit gewinde koje imaju TUV za taj auto, gledaju ti i pregledavaju CIJELI auto?? zasto?? Link to comment Share on other sites More sharing options...
Dario Posted December 22, 2018 Share Posted December 22, 2018 (edited) pa pitaj njih , od kud mi znamo Edited December 22, 2018 by Dario Link to comment Share on other sites More sharing options...
