vesko Posted August 16, 2020 Posted August 16, 2020 Pozdrav,tko bi mi mogao nabaviti turbo Holset he221w sa obavezno ispušnim kućištem 6mm,hvala.Neki kontakt ,ili firmu koja radi sa Holsetom ,hvala.
vesko Posted August 16, 2020 Author Posted August 16, 2020 photo sharing free Takav turbo mi treba,svaka informacija dobrodošla.
vesko Posted August 16, 2020 Author Posted August 16, 2020 4 hours ago, Hic said: Samo novi Da, samo novi i tražim.
Boro Posted August 17, 2020 Posted August 17, 2020 Na kleineanzigen jedino 2 komada sa 7cmJa sam tamo naletio na 6cm i imam ga na 300td om606Sent from my LYA-L29 using Tapatalk
vesko Posted August 17, 2020 Author Posted August 17, 2020 1 hour ago, Boro said: Na kleineanzigen jedino 2 komada sa 7cm Ja sam tamo naletio na 6cm i imam ga na 300td om606 Sent from my LYA-L29 using Tapatalk 6cm tražim
Boro Posted August 18, 2020 Posted August 18, 2020 Kolika razlika moze biti izmedju 6 i 7? Sent from my LYA-L29 using Tapatalk
vesko Posted August 18, 2020 Author Posted August 18, 2020 (edited) 17 hours ago, Boro said: Kolika razlika moze biti izmedju 6 i 7? Sent from my LYA-L29 using Tapatalk Na 1.6 motoru je osjetna razlika Edited August 18, 2020 by vesko
vesko Posted August 19, 2020 Author Posted August 19, 2020 5 hours ago, kutija said: jel ti igra 5.5 kuciste? Imaš 2 komada možda?
