mariotdi Posted November 25, 2010 Author Posted November 25, 2010 daj msporis, sta m inemozes preko neke stele rijesit MAF s popustom ako je otisao?
msporis Posted November 25, 2010 Posted November 25, 2010 Prvo utvrdi sa sigurnošću kaj je krepalo a onda bumo dalje rješavali :thumbsup:
mariotdi Posted November 26, 2010 Author Posted November 26, 2010 Auto bio kod majstora...crijeva,i to sve ureddno, turbina uredna...maf uredan, otisao senzor tlaka punjenja zice se pojele, nazuljale...doslo do kratkg spoja, senzor otiso u lovista,a tad se check engine upalila sad su zice spojene, sve ispitano, lampica ne gori ali auto neide. senzor u banani INFO...kolko je novi taj senzor? cijena?
KIMI_1.8T Posted November 27, 2010 Posted November 27, 2010 03C 906 051 .........oko 55€ vani. Kod nas dodas jos cca 35 - 40%
mariotdi Posted November 27, 2010 Author Posted November 27, 2010 neznam bare sad i to, nerazumijem se u to..kolko je originalan tolko @kimi 1.8T - e too me zanimalo. svaka cast idem sad kod majstora
Mad-bertone Posted November 27, 2010 Posted November 27, 2010 mariotdi said: Auto bio kod majstora...crijeva,i to sve ureddno, turbina uredna...maf uredan, otisao senzor tlaka punjenja zice se pojele, nazuljale...doslo do kratkg spoja, senzor otiso u lovista,a tad se check engine upalila sad su zice spojene, sve ispitano, lampica ne gori ali auto neide. senzor u banani INFO...kolko je novi taj senzor? cijena? Kao sto sam i rekao MAP...mogu ti srediti novi za 50€
mariotdi Posted November 28, 2010 Author Posted November 28, 2010 po etki je 44 eura senzor ALI bacio je sad neku drugu gresku, nisam zapamtio...prestalo me zanimat:D cak sam se i priviknuo na sdi snagu:D sutra ide u servis, u osijek
mariotdi Posted November 29, 2010 Author Posted November 29, 2010 Bio u servisu,u osijeku, kod onog izgorenog getroa dvije greske MAP - nesto nije signal plauzbilian i MAF - nesto nedovoljno radi I sta je posebno. upalim ga, ide super iako check engine svjetli ugasim ga neide opet nakon paljenja ide, pa nakon gasenja neide jel moguce onaj n75 ventil da nevalja?
mariotdi Posted November 30, 2010 Author Posted November 30, 2010 da javim i zadnji post nadam se u ovoj temi, taj ventil n75 je otisao pa nekad radi nekad ne napokon ide punom snagom sad mogu rec da za 105 konja ide jako lijepo i po ovoj kisi snijegu je neupotrebljiv,samo proklizava
Gabre Posted November 30, 2010 Posted November 30, 2010 nemaš traction control ni ESP? ja sa ljetnim gumama sam vrtio svugdje u prazno, ali zato sa zimskima imam gripa po kiši kao da je suho
