Axa Posted November 22, 2010 Share Posted November 22, 2010 (edited) Ovako imam problem na Toledu 2003 godina.Brisači jednostavno stanu nakon pokretanja i neće da se pokrenu dok god ih ne spustim rukom u početni položaj.Imam osječaj koda je priašnji vlasnik preforsirao motorić brisača.Najbolje rade na 3 brzini i onada rijetko zacvikaju ali na intervalu vrlo često. To mi se događa pri vlažnom vremenu. Ako je imao netko sličnih problema neka mi javi što bi trebalo proijeniti. Edited November 22, 2010 by Axa Link to comment Share on other sites More sharing options...
Trojan Posted November 22, 2010 Share Posted November 22, 2010 Skini onu plastiku ispod šajbe i provjeri škare, možda samo treba malo zglobove podmazat. Link to comment Share on other sites More sharing options...
Axa Posted November 22, 2010 Author Share Posted November 22, 2010 Već skidano jednom škare su bile ok i podmazane su sve je iz provjeravano i sve je radilo ali imam osjećaj koda motorić kada ostane u jednom polžaju nema snage pokrenut brisače. Link to comment Share on other sites More sharing options...
PUGI Posted November 22, 2010 Share Posted November 22, 2010 onda su cetkice na motoru Link to comment Share on other sites More sharing options...
Axa Posted November 22, 2010 Author Share Posted November 22, 2010 znači novi motorić i to je to? Link to comment Share on other sites More sharing options...
Tihi Posted November 22, 2010 Share Posted November 22, 2010 Moze biti da cetkice na motoricu zezaju ili da mu zeza prekidac u motoricu (senzor polozaja brisaca). Sve od toga se moze popraviti. Link to comment Share on other sites More sharing options...
Axa Posted November 22, 2010 Author Share Posted November 22, 2010 taj motorić je zatvorenog tipa i kaže frend da se nemogu promijeniti četkice. Link to comment Share on other sites More sharing options...
Hic Posted November 22, 2010 Share Posted November 22, 2010 sve se moze, samo ga otvori. tako sam ja i ventilatoru s klime koji je NEMOGUCE popraviti promjenio cetkice i jos veselo radi.... Link to comment Share on other sites More sharing options...
Tihi Posted November 22, 2010 Share Posted November 22, 2010 Ajd, mozda je stvarno tako. Ili se nekome ne da raditi. Mislim, meni na A4 je ventilator kilera isto zatvorenog tipa, pa sam promjenio cetkice bez nekih problema. Treba vidjet. Link to comment Share on other sites More sharing options...
Axa Posted November 22, 2010 Author Share Posted November 22, 2010 nisam stručan u tome tako da se neću miješat možda se i može promijenit četkice.Koliko bi opće koštalo mjenjanje četkica? Link to comment Share on other sites More sharing options...
Tihi Posted November 22, 2010 Share Posted November 22, 2010 Cetkice su 30-etak kn. Ali, posao tu kosta. Jer, treba ga skinuti, a na vecini auta je to malo zeznuto. + treba ga rastaviti. E, sad, kolko bude majstor uzeo, to je pitanje. Recimo, ja bih to za kojih 300kn sredio. Link to comment Share on other sites More sharing options...
