Lonewolf Posted September 5, 2011 Report Share Posted September 5, 2011 Ne mogu upalit auto,pa prije nego se odlucim na placanje slepe i prepreskupog elektricara,da pitam ovdje,mozda je tko imao slican problem.... Na prvi zub sve stima,pale se lampice na tabli,na drugi zub(kontakt) se na tabli sve pali,ali nema nekih stvari koje inace dolaze s kontaktom,tipa upali se display na klimi i slicno,kao da je kontakt polovican kad okrenem kljuc do kraja,nista se ne dogadja :huh::huh: Osiguraci svi pregledani,nijedan nije pregorio:drink: Link to comment Share on other sites More sharing options...
semper Posted September 5, 2011 Report Share Posted September 5, 2011 jel se čuje pumpa goriva da zazuji dok daš kontakt? Link to comment Share on other sites More sharing options...
lavic_st Posted September 5, 2011 Report Share Posted September 5, 2011 pogledaj kleme na bateriji, i probaj spojit preko kabela auto pa upalit, al probaj da su kabeli sto deblji! Link to comment Share on other sites More sharing options...
Lonewolf Posted September 5, 2011 Author Report Share Posted September 5, 2011 S akumulatorom sve stima,struje ima...pumpa zuji Auto uopce ne vrti ni ista,okrenem kljuc do kraja,NISTA se ne dogodi Link to comment Share on other sites More sharing options...
lavic_st Posted September 5, 2011 Report Share Posted September 5, 2011 pogledaj ispod haube imas jos jedan plus, provjeri ga malo, i pogledaj mase na motoru imas koliko znam dvije! Link to comment Share on other sites More sharing options...
lavic_st Posted September 5, 2011 Report Share Posted September 5, 2011 a da probas na guranje? Link to comment Share on other sites More sharing options...
pacey Posted September 5, 2011 Report Share Posted September 5, 2011 meni slicno bilo na z3-u, samo je moj verglao...pumpa i sve radila...uglavnom izgubio se kod kljuca..1000kn mi uzelo za uparivanje koda Link to comment Share on other sites More sharing options...
lavic_st Posted September 5, 2011 Report Share Posted September 5, 2011 meni slicno bilo na z3-u, samo je moj verglao...pumpa i sve radila...uglavnom izgubio se kod kljuca..1000kn mi uzelo za uparivanje koda to nije sigurno jer auto ne vergla, da nema kod verglao bih! Link to comment Share on other sites More sharing options...
Jopa Posted September 5, 2011 Report Share Posted September 5, 2011 po ovome sta si napisao, problem je u bravi.. provjeri bravu sa unimjerom dali uopce radi 2. i 3. pozicija Link to comment Share on other sites More sharing options...
Minga Posted September 5, 2011 Report Share Posted September 5, 2011 Ili baterija slaba ili te jebe brava,pokušaj ga upalit na guranje ... Link to comment Share on other sites More sharing options...
francuz Posted September 5, 2011 Report Share Posted September 5, 2011 meni slicno bilo na z3-u, samo je moj verglao...pumpa i sve radila...uglavnom izgubio se kod kljuca..1000kn mi uzelo za uparivanje koda Meni isto zvuči kao kod ključa. Jesi možda rastavljao ključ? Link to comment Share on other sites More sharing options...
lavic_st Posted September 5, 2011 Report Share Posted September 5, 2011 Meni isto zvuči kao kod ključa.Jesi možda rastavljao ključ? 100% nije kod kljuca.... znam pogotovo za ovo auto posto kada smo spajali struju novog motora koji je sada unutra nismo prebacili novi modu kod kluca to je bijeli modul iza pretinca od suvozaca, i auto je verglalo, sve bilo super al nije palilo, dvije baterije smo ispraznili dok nismo dokucili sto je. Link to comment Share on other sites More sharing options...
Lonewolf Posted September 5, 2011 Author Report Share Posted September 5, 2011 Kljuc nisam rastavljao,jedino sto mi pada na pamet jest da sam rastavljao plastiku ispod volana prije par dana pa se par kabela potezalo,tj cijeli onaj veliku bunt kablova pregledao sam sve konektore ispod,sve je spojeno kako treba Struje ima dovoljno,nije do toga,svjetla rade,muzika se moze pojacat na max,nista ne steka... Link to comment Share on other sites More sharing options...
semper Posted September 5, 2011 Report Share Posted September 5, 2011 može bit uložak kontakt brave (ako benve ima to? :huh: ) Link to comment Share on other sites More sharing options...
Lonewolf Posted September 5, 2011 Author Report Share Posted September 5, 2011 Takodjer,auto ima lampicu kod mjenjaca koja bljeska kad se auto zakljuca,kao alarm ili sto vec sad se ne pali dok je auto zakljucan Link to comment Share on other sites More sharing options...
Lonewolf Posted September 5, 2011 Author Report Share Posted September 5, 2011 Sto se kontakt brave tice,sve se okrece normalno,do kraja,i onaj metalni dio,i onaj plasticni sto ga metalni okrece,sa zicama Link to comment Share on other sites More sharing options...
pacey Posted September 5, 2011 Report Share Posted September 5, 2011 ako nije kod... na e39 kada mi je otisao akumulator, mada je sve lampice pali...nije htio zaverglat..nego samo cujes tipicni za bmw ck ck...ako je akumulator, najlakse ga spojit na kablove i vidit oce upalit.. Link to comment Share on other sites More sharing options...
Lonewolf Posted September 5, 2011 Author Report Share Posted September 5, 2011 Ima li tko shemu za EWS,za slucaj da je do njega? iz njega ide kabel za antenu,koja se nalazi kod brave,a na njega idu tri kabela,pokusao bi spojit EWS direkt na 12V,da vidim jel mozda greska negdje izmedju njega i akumulatora? Link to comment Share on other sites More sharing options...
SvenDaMan Posted September 5, 2011 Report Share Posted September 5, 2011 probaj mrdat ključ u bravu, možda je negdje slab kontakt jer i meni zvuči ko da je problem u bravi kad kod ključa ne valja onda auto vergla ali ne pali Link to comment Share on other sites More sharing options...
IvanST Posted September 5, 2011 Report Share Posted September 5, 2011 Anlaser??? Link to comment Share on other sites More sharing options...
Tochka Posted September 5, 2011 Report Share Posted September 5, 2011 il brava il anlaser Link to comment Share on other sites More sharing options...
Lonewolf Posted September 5, 2011 Author Report Share Posted September 5, 2011 Nije brava,pregledao sam je kompletno,a nije ni anlaser,jer nije samo da vrti,nego ne pali ni pola stvari sto bi se trebale upalit kod kontakta.... odustao sam,slepa dosla po njega....dalje cemo vidjet Link to comment Share on other sites More sharing options...
Minga Posted September 6, 2011 Report Share Posted September 6, 2011 pa jel problem provat upalit na guranje? Link to comment Share on other sites More sharing options...
Pale Posted September 6, 2011 Report Share Posted September 6, 2011 trebo si probat drito dovest pobudu na anlaser da vidis dali ce onda, jel po tvojem posto uopce ne vrti anlaser nema pobude na njega Link to comment Share on other sites More sharing options...
djzuka Posted September 6, 2011 Report Share Posted September 6, 2011 EWS iliti kod kljuc, auti s original EWS-om ne verglaju ak kod zafrkava Link to comment Share on other sites More sharing options...
