GoranE46 Posted October 6, 2013 Posted October 6, 2013 Za cca 400€ si mogao imati remap s 210-220ks, Bez sistema koji vara rail senzore i slicno.. Nego pravi remap
SVEN Posted October 6, 2013 Posted October 6, 2013 upravo sam to pitao gore u postu...valjda nisam dovoljno jasno pitao
fire Posted October 6, 2013 Posted October 6, 2013 Bas bi bilo zanimljivo staviti takav remap na valjke.
Mislaf Posted October 6, 2013 Posted October 6, 2013 Dobro je i dobio s time, neki su znali dobivat po 6 ks s tim sranjem
fire Posted October 6, 2013 Posted October 6, 2013 Mislaf said: Dobro je i dobio s time, neki su znali dobivat po 6 ks s tim sranjem Neki su znali i gubiti s slicnim stvari. Jedan golf 6 1.6 dizel je izgubio preko 10HP s time. A i ozzy je isto s nekim drugim izgubio snagu.
Raptor6767 Posted October 6, 2013 Posted October 6, 2013 (edited) Drahi na Astri GTC 1.9CDTI je dobio gotovo 40ks ako se dobro sjećam sa PBoxom. I auto je išao kao stock Clio 197. Edited October 6, 2013 by Raptor6767
fire Posted October 6, 2013 Posted October 6, 2013 Cim je noviji auto, manja je sansa da takva varalica radi.
Ozy Posted October 6, 2013 Author Posted October 6, 2013 (edited) GoranE46 said: Za cca 400€ si mogao imati remap s 210-220ks,Bez sistema koji vara rail senzore i slicno.. Nego pravi remap daj mi molim te reci da si ziher u to što pišeš i ja ti odmah dam tih 400eur ali još jednom pročitaj red ispod ovoga TOYOTA DENSO je ECU pa ti reci sad još jednom jesi li siguran u to što si gore naveo? ako jesi, eto mene odmah sutra ujutro kod tebe. edit: ovo je mjereno sa chip-box tip CBRS a evo ti sa tip CBD1 na lvl4 (+16%) RUN1 = CBD1 RUN3 = serijala Edited October 6, 2013 by Ozy
GoranE46 Posted October 6, 2013 Posted October 6, 2013 Mislio sam da je tvoj 2.0 bmw 177ks, ali provjerim ti ujutro.. Nesto je skuplje za denso jer se radi drugim uredjajem.. Slicnim kao i evo x, nissani itd..
Ozy Posted October 6, 2013 Author Posted October 6, 2013 ajde ajde, ako je tako neka je i skuplje ali izvuci mi bulletproof mapu za 2231ccm serijala boost je 1.6bar
Uros Posted October 6, 2013 Posted October 6, 2013 GoranE46 said: Mislio sam da je tvoj 2.0 bmw 177ks, ali provjerim ti ujutro.. Nesto je skuplje za denso jer se radi drugim uredjajem..Slicnim kao i evo x, nissani itd.. Drndak daj ti neku mapu za f30 3,0 d izmisli odnekud
TomiTraktor Posted October 6, 2013 Posted October 6, 2013 ja sam sa reacechip.de boxom dobio 29ks na 2.0 d-4d u safe varijanta, bez engine check, manja potrosnja modu ECU - Toyota Denso, DPf gore, 5. injektor, Euro 5 norma mjereno kod kikija na valjcima pri preko 30°C. Frendu megane sa superchipom pokazao taj dan 275ks, a inače ima 295 mjereno u SLO. Mjerio je 5 minuta nakon mene. moj se pbox još mogao dosta na jači setting podesiti, ali jednom kada sam ga otvorio za 4 "stupnja" više mi je ušao u safe mode na autoputu pa sam ga vratio na ovaj setting koji daje 29ks. Po tome sudeći rekao bih da ti je taj pbox sranje jer sam ja svoj platio 129€
TomiTraktor Posted October 6, 2013 Posted October 6, 2013 Uros said: Drndak daj ti neku mapu za f30 3,0 d izmisli odnekud ti vjerojatno imaš isti EDC17C59 kao i ja u Insigniji i jednom kada se "otvori" moci ce ti ga svi bolji chiperi remapirati - znaci i sedox i skn i drndak i svi
GoranE46 Posted October 6, 2013 Posted October 6, 2013 Tako je, kad dodje protokol kod CMD-a svi ce ga prekopirat, jedina prednost je sto cemo mi koji imamo cmd imati to medju prvima
Uros Posted October 6, 2013 Posted October 6, 2013 GoranE46 said: Tako je, kad dodje protokol kod CMD-a svi ce ga prekopirat, jedina prednost je sto cemo mi koji imamo cmd imati to medju prvima A jel zna netko kad ce to biti?
Ozy Posted October 6, 2013 Author Posted October 6, 2013 TomiTraktor said: ja sam sa reacechip.de boxom dobio 29ks na 2.0 d-4d u safe varijanta, bez engine check, manja potrosnja moduECU - Toyota Denso, DPf gore, 5. injektor, Euro 5 norma mjereno kod kikija na valjcima pri preko 30°C. Frendu megane sa superchipom pokazao taj dan 275ks, a inače ima 295 mjereno u SLO. Mjerio je 5 minuta nakon mene. moj se pbox još mogao dosta na jači setting podesiti, ali jednom kada sam ga otvorio za 4 "stupnja" više mi je ušao u safe mode na autoputu pa sam ga vratio na ovaj setting koji daje 29ks. Po tome sudeći rekao bih da ti je taj pbox sranje jer sam ja svoj platio 129€ daj link od tog chipa da vidim koji je model. ja sam svoj chip-box dobio, samo sam kabel platio 300kn.
Raptor6767 Posted October 7, 2013 Posted October 7, 2013 fire said: Zelna je stock, crvena bez dpd-aI ono zanimljivo, auto ne daje deklarirane konje niti moment. Skoro kao 99% novih s dpd filterom. Vidiš, istina. :thumbsup:
