Ive_HF Posted February 14, 2012 Posted February 14, 2012 Zanima me za dijagnostiku auta, znan da sada vecina auta novjih ima obd izlaz, ili obd II kolko sam skuzio, e pa recimo na koje aute aute pase obd?? Jer znan da recimo na starije talijane ide posebni kabel, i di se to najvise isplatit uzet??? GLedo po ebay al osim obd nisan naso bas nista konkretnog...hvala
Petar001 Posted February 14, 2012 Posted February 14, 2012 Imam ti ja sa obd na fiat adapter ako trebas
marek1 Posted February 14, 2012 Posted February 14, 2012 Taj adapter odgovara na bilo koji obd? Ili ima neka caka da mora biti za fiat... Dali su svi obd isti ili za svaku marku je drugaciji? Jel ima netko bas za fiat?
Petar001 Posted February 14, 2012 Posted February 14, 2012 Adapter je sa OBD na Fiat e sad ja mislim da mozes ustekat bilo koji OBD i ocitat greske nisam probo na fiatu stoji mi to doma
Ive_HF Posted February 15, 2012 Author Posted February 15, 2012 talijani imaju vecinom 4 pinski, pa zato
KIMI_1.8T Posted February 15, 2012 Posted February 15, 2012 http://www.ebay.de/itm/Fiat-3-pin-16-pins-OBD2-adapter-connector-kabel-OBD1-/320831711299?pt=Elektroger%C3%A4te&hash=item4ab30f6843 Plus neki interface, recimo ovaj: http://www.ebay.de/itm/ALFA-LANCIA-FIAT-DIAGNOSE-OBD-OBD2-USB-INTERFACE-/170779736469?pt=Elektroger%C3%A4te&hash=item27c343f995
killercivic Posted February 15, 2012 Posted February 15, 2012 skoro svi auti od 2000+ imaju standardni 16 pinski obd-2 konektor, mislim da to čak po zakonu mora bit tak. za univerzalnu diagnostiku a da nekošta puno ti je najbolje uzet elm327 kabel, ili vag-com a za fiat imaš besplatan fiatecuscan, čuda radi
Petar001 Posted February 15, 2012 Posted February 15, 2012 e takav je imam adapter ko sto je kimi stavio ako netko treba eto 100kn hehe
