Bartol Posted November 12, 2013 Posted November 12, 2013 Trebam napraviti jedan zupcanik puznog prenosa, onaj veci. U orginalu je taj zupcanik od plastike, a ja bi rade mozda da je od mesinga ili bronce.. Mozda bi se mogao i na 3D printeru napravit Evo i slike
fire Posted November 12, 2013 Posted November 12, 2013 Somek ti to moze napraviti, samo nece biti jeftino.
Misek_Chipsy Posted November 12, 2013 Posted November 12, 2013 woo bi mozda mogao to napravit 3d model i isprintat na 3D printeru ak bi bilo dovoljno cvrsto. p.s. citam ti signature, nemozete si to sami napravit metalno?
Bartol Posted November 12, 2013 Author Posted November 12, 2013 Ovo je neka plastika kao poliamid neki Bas zupcanike ne radimo
Misek_Chipsy Posted November 12, 2013 Posted November 12, 2013 pise sve sto mozete zamisliti jbg Vidi s woo-om pa vidi sta ce ti on rec za to znam da je vec radio zupcanike neke.
Nicol Posted November 12, 2013 Posted November 12, 2013 Bartol said: Birt vjerojatno nekome nosi.. birt ti moze napraviti ziher, ne nosi nikome. poliuretan.
Alfaludak Posted November 12, 2013 Posted November 12, 2013 napravi metalno, kakva plastika te spopala martine
Marko Posted November 12, 2013 Posted November 12, 2013 DarioB said: Čegec u Zelini radi zupčanike http://www.tractorpro.hr/ rade glodanje i brusenje "in-house" samo toplinsku salju van, mogu ti postic kvalitetu 5 ak ti to ista znaci u zivotu
ZOD Posted November 13, 2013 Posted November 13, 2013 Alfaludak said: napravi metalno, kakva plastika te spopala martine Zašto je u originalu plastika? Po onome za što je taj dio namjenjen i sa čime se uparuje biraš materijal.
TheFog Posted November 13, 2013 Posted November 13, 2013 Nicol said: birt ti moze napraviti ziher, ne nosi nikome. poliuretan. malo da uletim s OT: birt onda moze napravit komplet PU selene (po uzorcima originalnih gumenih)? tko bi to jos mogao u hr napravit, a da prodjem jeftinije od powerflexa?
ZOD Posted November 13, 2013 Posted November 13, 2013 Pa bilo koji tokar, glavno da materijal možeš pribavit. Imaš i strongflex i još firmi kaj ih proizvodi.
Hic Posted November 13, 2013 Posted November 13, 2013 Pa powerex bas i nije skup, dapace ako ne cijena visa ja uvijek dam popust barem 20%
Nicol Posted November 13, 2013 Posted November 13, 2013 TheFog said: malo da uletim s OT: birt onda moze napravit komplet PU selene (po uzorcima originalnih gumenih)? tko bi to jos mogao u hr napravit, a da prodjem jeftinije od powerflexa? gotovo sigurno da može, JosipuZG je radio selene na amortizerima, meni je radio nosač motora.... Najbolje da nazoveš i provjeriš direktno ili pitaš Mavericka tu s foruma, to mu je sin btw ja sam oduševljena sa svime kaj mi je g.Birt napravio i sa svime što sam vidla/probala da je radio drugima.....svaka preporuka!!
TheFog Posted November 13, 2013 Posted November 13, 2013 ZOD said: Pa bilo koji tokar, glavno da materijal možeš pribavit. Imaš i strongflex i još firmi kaj ih proizvodi. kod nikog drugog nisam nasao cijeli set Hic said: Pa powerex bas i nije skup, dapace ako ne cijena visa ja uvijek dam popust barem 20% e ovo je hvale vrijedno! znaci, na cijenu s njihovog weba mogu racunat 20% rabata?
Koren Posted November 13, 2013 Posted November 13, 2013 (edited) DarioB said: Čegec u Zelini radi zupčanike Traktor pro se zove firma edit: nisam vidio da je Marko vec napisao... Edited November 13, 2013 by Koren
TheFog Posted November 13, 2013 Posted November 13, 2013 ja bi jos malo ot-cario ako smem......ovaj traktorpro bi onda mogao i ovako nesto napravit (ili imate jos nekog za preporucit?):
Logic Posted November 13, 2013 Posted November 13, 2013 U Rijeci imas BROSS d. i Jlm-perkovic da rade zupcanike i slicne stvari
Kress Posted November 13, 2013 Posted November 13, 2013 Imate u Blatu, g.Šćukanec Silvio, radi godinama samo zupčanike...
Bela Posted November 13, 2013 Posted November 13, 2013 Bartol said: A onaj neki u Buševcu kod Gorice? Ovaj je meni slagao reduktor, radi i zupčanike 091 5650 898 Željko
