killuminati Posted September 8, 2014 Report Share Posted September 8, 2014 znam da ima yatour, grom, xcarlink, ali me interesira je li moguće povezati 4 pina s USB-a na 16-pinski CD changer port? kak su te kutijice složene, ima još kaj nutra ili je dovoljno ono zdravoseljački povezat napajanje, uzemljenje i data+/- s USB-a na bus ili..? pokušavam iskopat pinout recimo yatour kabla, ali zasad ništa.. :no2: ako tko ima koju pametnu.. :thumbsup: Pin Application A Power Ground B System Mute C Right Input+ D Right Input- E Left Input+ Red/Black F Left Input- Violet/White G Signal Ground H N/C I N/C J N/C K Bus- L Bus+ M AUX N N/C O Power ACC P Power B+ AUX već imam, ovo je cilj, dodati samo USB port.. zadnja opcija je yatour.. malo mi je blesavo dat 1500 kn za par žica.. :no2: http://phwt.mazda.hr/hr/hr/M6F2/9/AccessoryDetails/133ee72d-85e8-4bbe-83ed-6779d312ad44 Link to comment Share on other sites More sharing options...
frx1 Posted September 8, 2014 Report Share Posted September 8, 2014 mislim da nemoes jer data na usbu nije isto sto i k bus na auxu. ovo ti treba? http://www.ebay.com/itm/Mazda-CX7-Replaces-C860V6572B-iPhone-iPod-USB-3-5mm-Aux-Cable-replacement-/131025560491 Link to comment Share on other sites More sharing options...
killuminati Posted September 9, 2014 Author Report Share Posted September 9, 2014 (edited) to je samo zamjenski kabel za naknadno sprovedenu instalaciju.. yatour se spaja na cdc port, onda valjda emulira signal da bi usb šljakao.. ili signal ide kroz usb bus device driver chip.. makar data+ i data- nisu odvojeni, to je jedan signal, možda bi ga mogao upiknut na aux na cdc portu.. Edited September 9, 2014 by killuminati Link to comment Share on other sites More sharing options...
