tomica Posted July 17, 2016 Share Posted July 17, 2016 znaci auto ne prima gas i trokira ima gresku na vcds 000024-Bank2:CMP Sens 2(G163) /Engine Speed Sensor (G28) P0018-002-Incorrect Correalation Dal je imao ko ovakav slucaj? Link to comment Share on other sites More sharing options...
KIMI_1.8T Posted July 17, 2016 Share Posted July 17, 2016 Moze biti brdo toga, senzor radilice, senzor bregaste, ozicenje istih , elektroventil zakretanja bregaste/ih, neki problem s lancem / natezacem lanca,........ Link to comment Share on other sites More sharing options...
bojan25 Posted July 17, 2016 Share Posted July 17, 2016 znaci auto ne prima gas i trokira ima gresku na vcds 000024-Bank2:CMP Sens 2(G163) /Engine Speed Sensor (G28) P0018-002-Incorrect Correalation Dal je imao ko ovakav slucaj? jesi iz zg? Link to comment Share on other sites More sharing options...
tomica Posted July 17, 2016 Author Share Posted July 17, 2016 Jesam zasto? Link to comment Share on other sites More sharing options...
tomica Posted July 17, 2016 Author Share Posted July 17, 2016 Na auto je promjenjen lanac auto je u fazi svi senzori su ispravni jedino sumnjamo na variator ispusne bregaste koji kosta 3600kn a nedaje mi se bezveze ako nije to. Link to comment Share on other sites More sharing options...
Jopa Posted July 17, 2016 Share Posted July 17, 2016 Imao sam takav problem na jednom drugom autu. Dijagnostika mi je iste greške pokazivala. Trigger wheel je bio odsarafljen, nije mogao ispasti nego je šetao cca 15 stupnjeva sim-tam. Ne znam kako je izveden trigger na r32 ali možda ti pomogne Link to comment Share on other sites More sharing options...
tomica Posted July 17, 2016 Author Share Posted July 17, 2016 Imao sam takav problem na jednom drugom autu. Dijagnostika mi je iste greške pokazivala. Trigger wheel je bio odsarafljen, nije mogao ispasti nego je šetao cca 15 stupnjeva sim-tam. Ne znam kako je izveden trigger na r32 ali možda ti pomogne Kaj se je dogadalo sa autom? Link to comment Share on other sites More sharing options...
vesko Posted July 17, 2016 Share Posted July 17, 2016 Na auto je promjenjen lanac auto je u fazi svi senzori su ispravni jedino sumnjamo na variator ispusne bregaste koji kosta 3600kn a nedaje mi se bezveze ako nije to. To ti se počelo dešavat nakon promjene lanca? Link to comment Share on other sites More sharing options...
tomica Posted July 17, 2016 Author Share Posted July 17, 2016 To ti se počelo dešavat nakon promjene lanca? Ne bilo je i prije. Link to comment Share on other sites More sharing options...
Beli Posted July 17, 2016 Share Posted July 17, 2016 Greska je da ti nije u fazi.. Krenite s tim.. Znam da nije bas minuta posla.. Ali radi varijatora ti nece na niskim trokati.. Poslano sa mog Lenovo A7000-a koristeći Tapatalk Link to comment Share on other sites More sharing options...
tomica Posted July 18, 2016 Author Share Posted July 18, 2016 Greska je da ti nije u fazi.. Krenite s tim.. Znam da nije bas minuta posla.. Ali radi varijatora ti nece na niskim trokati.. Poslano sa mog Lenovo A7000-a koristeći Tapatalk Kaj se dogada kad varijator rikne jesi imao kad slucaj? Link to comment Share on other sites More sharing options...
Beli Posted July 18, 2016 Share Posted July 18, 2016 Nije da rikne, nego ne zakrene visim okretajima bregastu.. Pa ili se zaleti u visom gusi.. Ili ako je kontra ostalo, u nizim bude ler gas veci i siromasnija smjesa Poslano sa mog Lenovo A7000-a koristeći Tapatalk Link to comment Share on other sites More sharing options...
tomica Posted July 18, 2016 Author Share Posted July 18, 2016 Da sve se to dogada. Link to comment Share on other sites More sharing options...
Jopa Posted July 18, 2016 Share Posted July 18, 2016 Kaj se je dogadalo sa autom? Oprostim zaboravio sam ti odgovoriti Evo ti filmic da cujes kako je radio.. uglavnom stalno je nacukavao, trokirao.. Link to comment Share on other sites More sharing options...
tomica Posted July 18, 2016 Author Share Posted July 18, 2016 Da to se i meni dogada. Link to comment Share on other sites More sharing options...
tomica Posted July 18, 2016 Author Share Posted July 18, 2016 Dejan dimitrijevic je stavljao auto u fazu tak da nevjerujem da nije u fazi. Link to comment Share on other sites More sharing options...
Rallye VR6 Posted July 18, 2016 Share Posted July 18, 2016 Malo teže za vidjeti , ali izvadite senzor radilice na bloku i pogledajte trigger wheel ili skinite karter pa zavrtitite motor. Možda je iz nekog razloga savijen ili olabavljen Jer je očito da nešto u odnosu izmedju ta dva senzora ne valja Link to comment Share on other sites More sharing options...
tomica Posted July 19, 2016 Author Share Posted July 19, 2016 Ok pogledat cu pa javim Link to comment Share on other sites More sharing options...
tomica Posted July 19, 2016 Author Share Posted July 19, 2016 Trigger wheel je u redu nije ostecen ni nista . . Link to comment Share on other sites More sharing options...
