mario328i Posted August 21, 2017 Share Posted August 21, 2017 Koja je po vama bolja opcija za hlađenje motora?noviji auti sad svi imaju ventilator,ja razmisljam isto napraviti,visco van ,a ugraditi komplet ventilator na kiler + imam prednji kao "dodatni". Link to comment Share on other sites More sharing options...
Tomica93 Posted August 21, 2017 Share Posted August 21, 2017 ElektricniBrze se zagrije sam motor, vise snage imas dok ventilator ne radi, sveukupno i manja potrosnja. Nemas kaj puno razmisljati oko toga, tako sam i sebi napravio Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mario328i Posted August 21, 2017 Author Share Posted August 21, 2017 Al ovo je v8 ipak... Ima to veze micek? tudum sam za to,bolje provjeriti sve Link to comment Share on other sites More sharing options...
Tomica93 Posted August 21, 2017 Share Posted August 21, 2017 Nema veze sto je v8, tu samo ovisi velicina ventilatora i samog kileraSad je potrebno samo odabrati ventilator koji ima dobar protokSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mario328i Posted August 21, 2017 Author Share Posted August 21, 2017 Imas volje? kiler je original S50M3 moralo bi ih se naci za njega... Link to comment Share on other sites More sharing options...
Tomica93 Posted August 21, 2017 Share Posted August 21, 2017 Treba vidjeti dali za pocetak ima nesto OEMSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mario328i Posted August 21, 2017 Author Share Posted August 21, 2017 S50 motori su na visco bili, i 3.0 i 3.2 probat cu sa mehom vidjeti dal pase ventilator sa drugih motora.. Link to comment Share on other sites More sharing options...
2fast Posted August 21, 2017 Share Posted August 21, 2017 Ako te zanima, ovaj ima dvije brzine, usisava malu djecu: http://www.njuskalo.hr/ventilacija-klima-dijelovi/ventilator-kenlowe-12-305-mm-spal-oglas-22851519 Link to comment Share on other sites More sharing options...
Branx Posted August 21, 2017 Share Posted August 21, 2017 Svi koji su na BMW-ima radili konverziju visko -> električni, nisu uzimali el. ventilator manji od 16", tako da mislim da mu je ovo premalo... Link to comment Share on other sites More sharing options...
_DEX_ Posted August 21, 2017 Share Posted August 21, 2017 Pitaj @Enkei koji je on stavljao na M3 E36. On je isto radio konverziju. Link to comment Share on other sites More sharing options...
Enkei Posted August 21, 2017 Share Posted August 21, 2017 Stavio sam novi hladnjak, crijeva, stewart vodenu pumpu i hladniji termostat i vozio bez ikakvog ventilatora cca 3-4 godine. I skinuo sam klimu tako da je zrak dolazio ravno na hladnjak vode.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mario328i Posted August 21, 2017 Author Share Posted August 21, 2017 Meni je sa klimom, jos imam i taj ventilator napred.Sad bi ubacio na kiler jedan,naravno ne mali... Danasnji bmw-i koji su bez visca imaju vec za izbor,samo moram naci... Link to comment Share on other sites More sharing options...
Enkei Posted August 21, 2017 Share Posted August 21, 2017 Našarafiš su neku mrcinu naprijed i nek vrti mali po potrebi. Ili uzmes neki combo gdje je vec spojen ventić na hladnjak.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mario328i Posted August 21, 2017 Author Share Posted August 21, 2017 Kaj uopce stane na S50 max? to gledam po mjerama okvira ili samog vent.? Link to comment Share on other sites More sharing options...
Enkei Posted August 21, 2017 Share Posted August 21, 2017 Imaš gotovih već, izabereš si po modelu. A mjesta ima nekih 15 cm od vrha navoja na vodenoj do samog hladnjaka. A po visini moraš pripaziti na to da se s donje strane nemaš gdje uloviti zbog hladnjaka ulja. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mario328i Posted August 21, 2017 Author Share Posted August 21, 2017 Osmak nema hladnjak ulja,M ima daj mi molim te ako imas web ili nesto gdje je najbolje otic pogledati? izmjerit cu kiler i sa tim mjerama naci. Link to comment Share on other sites More sharing options...
HrSupra Posted August 21, 2017 Share Posted August 21, 2017 Mi smo na Supri to radili, nasli neke ogromne ventilatore od nekog v8 amerikanca, hlade ko mutavi Sent from my m2 using Tapatalk Link to comment Share on other sites More sharing options...
dejanR Posted August 21, 2017 Share Posted August 21, 2017 Samo OEM. Ako imaš visco u čemu je problem? Link to comment Share on other sites More sharing options...
mario328i Posted August 21, 2017 Author Share Posted August 21, 2017 U zujanju/galami... Odvratno za jedan V8.... Link to comment Share on other sites More sharing options...
Branx Posted August 21, 2017 Share Posted August 21, 2017 To je istina... kao ZET kad krećeš Dok ne preuzme brundanje motora/auspuha... Link to comment Share on other sites More sharing options...
fire Posted August 21, 2017 Share Posted August 21, 2017 Pogledaj ovo i dobro promisli Link to comment Share on other sites More sharing options...
mario328i Posted August 21, 2017 Author Share Posted August 21, 2017 Evo primjer gdje je tocno to sto bih ja odradio.Na ovoj emici u originalu ide visco,izbacen je radi manjka prostora i ugradjen ventilator. Kolko vidim drzi vodu.Nemoguce je da visco stave,masina ljubi frizider jbg. Link to comment Share on other sites More sharing options...
MeaCulpa Posted August 22, 2017 Share Posted August 22, 2017 10 hours ago, mario328i said: Evo primjer gdje je tocno to sto bih ja odradio. Na ovoj emici u originalu ide visco,izbacen je radi manjka prostora i ugradjen ventilator. Kolko vidim drzi vodu. Nemoguce je da visco stave,masina ljubi frizider jbg. kada će kod tebe ovo s lijeve strane Link to comment Share on other sites More sharing options...
mario328i Posted August 22, 2017 Author Share Posted August 22, 2017 Uf bojim se nikad bjezi....... 1 Link to comment Share on other sites More sharing options...
Boro Posted August 22, 2017 Share Posted August 22, 2017 Imam ja jedan spal najveci usisni za prodati ako kome treba....novSent from my SM-G955F using Tapatalk Link to comment Share on other sites More sharing options...
