Drag_steer Posted October 7, 2019 Posted October 7, 2019 znaci afr je izmedju 10-11 na leru, pod gasom je sve ok. da li ce to zeznut sportski katalizator? na leru obicno bude oko 11 ali padne i na 10 u nekim trenucima. recimo da je na 10:1 na leru. da li ce ga zeznut s vremenom?
Kic Posted October 7, 2019 Posted October 7, 2019 Na leru mora bit u closed loop i ciljat Stoic 14.7. Cemu tako bogata smjesa!? Stock ECU? 1
Drag_steer Posted October 9, 2019 Author Posted October 9, 2019 znam.. problemi s mapom. zanima me da li to moze zeznut katalizator? posto ne na leru samo takva smjesa
tcode Posted October 9, 2019 Posted October 9, 2019 Lako za katalizator, ali kaj ćeš kad Greta sazna? 1 2
kutija Posted October 9, 2019 Posted October 9, 2019 Lako za katalizator... stijenke cilindara neće biti sretne a kamoli leteći kada se razrijedi ulje... 1
Kic Posted October 9, 2019 Posted October 9, 2019 Ako je ovako (loše) podešena mapa na leru mogu si samo mislit kakva je u ostatku Ja bi flashno stock i promjeni tunera 1
Drag_steer Posted October 9, 2019 Author Posted October 9, 2019 (edited) ostatak je ok, ler je zajeban. nije me tolko strah za cilindre/bore wash ako si na to mislio, povremeno takne 10.xx : 1, najcesce plese oko 11, ili vise. na leru.. znaci katalizator bi trebao ostat ziv? Edited October 9, 2019 by Drag_steer
Kic Posted October 9, 2019 Posted October 9, 2019 Ne kuzim zasto ti je uopce diran ler u mapi? Da li je mijenjan promjer MAF-a ili su možda stavljene druge dizne? Ako je to slučaj, treba se pozabaviti kalibracijom MAFa i Injektora, a ne krpat sa sa korekcijama (pretpostavljam da je tu dobiven uredan AFR na WOT)
Drag_steer Posted October 11, 2019 Author Posted October 11, 2019 (edited) nesto su zajebali , rjesit ce se nadam se uskoro. radi se o tfsi motoru, ima 25% oduzimanja benze na leru (to je max kolko moze), i svakih x dana afr takne 10.5:1 i tad se upali check engine. Edited October 11, 2019 by Drag_steer
Drag_steer Posted October 18, 2019 Author Posted October 18, 2019 necu radit antireklamu :D nadam se da ce se rjesit uskoro kic: usis je ostao isti promjer, nesto su zajebali neznam ni ja sta tocno
