huzek Posted March 22, 2009 Share Posted March 22, 2009 Dakle danas mi se desilo malo sranje kod skidanja jednog imbus šarafa. Okrenuo mi se onaj unutarnji dio imbusa (oni kutevi) i sada nemam više nikakvih ideja kako da ga izvadim. Okolo ga ne mogu primiti jer se nalazi u rupici, sa sjekačom ne ide jer se valjda zapekao ili nešto i neće popustiti. Da li netko ima kakvu pametnu ideju? Hvala lepa unaprijed :thumbsup: Link to comment Share on other sites More sharing options...
bubinjo Posted March 22, 2009 Share Posted March 22, 2009 nabij unutra ravni srafciger i gripcangama okrenin na trzaj,vjerovatno ce ic ali ce puknut serafciger Link to comment Share on other sites More sharing options...
detroit Posted March 22, 2009 Share Posted March 22, 2009 ...probaj torx malo veci od rupe zatuc unutra i onda odsarafit... Link to comment Share on other sites More sharing options...
Jasa Posted March 22, 2009 Share Posted March 22, 2009 ...probaj torx malo veci od rupe zatuc unutra i onda odsarafit... Tak sam i ja uzeo najcvrsci sarafinciger kaj sam naso i sa cekicem nabijo dok nisam napraivo utor i odsarafio Link to comment Share on other sites More sharing options...
TomiTraktor Posted March 22, 2009 Share Posted March 22, 2009 probusi ga busilicom Link to comment Share on other sites More sharing options...
huzek Posted March 22, 2009 Author Share Posted March 22, 2009 Morat ću s torxom probat. To je dino nisam još. Sa šerafcigeom ne mogu nikak toliko nabiti ga unutra. Možda da ga izbrusim da bude oštar.... Pajdo kaj bum onda kad ga izbušim? Navoj će ostati u glavčini.... Link to comment Share on other sites More sharing options...
Jopa Posted March 22, 2009 Share Posted March 22, 2009 torax ti je najbolje rjesenje!!! milion puta sam tako izvadio inbus kad se zapeko i izglodao!! samo ako se jako zapeko dobro ga zali s wd-om i malo odsarafi pa malo zasarafi dok se ne otpusti! Link to comment Share on other sites More sharing options...
huzek Posted March 22, 2009 Author Share Posted March 22, 2009 Hvala svima. Probat ćemo :thumbsup::cheer: Link to comment Share on other sites More sharing options...
TomiTraktor Posted March 22, 2009 Share Posted March 22, 2009 Morat ću s torxom probat. To je dino nisam još. Sa šerafcigeom ne mogu nikak toliko nabiti ga unutra. Možda da ga izbrusim da bude oštar.... Pajdo kaj bum onda kad ga izbušim? Navoj će ostati u glavčini.... nece... ostat ce malo viriti van i kad skines felgu na skuteru primis ga kljestima i odsarafis probusis ga tako samo da glava prestane drzati felgu, mozda milimetar zagrebe borer i felgu ali nista strasno i btw kad cete stavljati opet gore - svih 5 stavite od inoxa iz kranjeca...2kn/kom su ili cak kunu komad - ne sjecams e vise ja sam sve vijke (i one osmice na deklu) zamjenio sa inox imbusima Link to comment Share on other sites More sharing options...
TomiTraktor Posted March 22, 2009 Share Posted March 22, 2009 varijanta dva je da to natopis sa psrejom za leance za motor koje ima teflona u sebi bed je sto malo prodire u amterijal i pitanje je da li bude ikada saraf drzao tu, ali vrijedi probati Link to comment Share on other sites More sharing options...
filip00 Posted March 22, 2009 Share Posted March 22, 2009 savjetujem polit WDom, malo izlupat sarafcigerom i cekicem da popusti zapeceno, a onda ili torx kao sto su gore rekli, ili sarafciger nasilu. hoce to tak. Link to comment Share on other sites More sharing options...
malawi Posted March 22, 2009 Share Posted March 22, 2009 (edited) ak je toliko dostupan, mozes dremelom prepilit ga na pola.. ravni sarafciger i ostalo je pjesma http://www.instructables.com/files/deriv/FY1/WRF0/I0MEZ7BD91F/FY1WRF0I0MEZ7BD91F.MEDIUM.jpg Edited March 22, 2009 by malawi Link to comment Share on other sites More sharing options...
huzek Posted March 22, 2009 Author Share Posted March 22, 2009 nece... ostat ce malo viriti van i kad skines felgu na skuteru primis ga kljestima i odsarafis probusis ga tako samo da glava prestane drzati felgu, mozda milimetar zagrebe borer i felgu ali nista strasno i btw kad cete stavljati opet gore - svih 5 stavite od inoxa iz kranjeca...2kn/kom su ili cak kunu komad - ne sjecams e vise ja sam sve vijke (i one osmice na deklu) zamjenio sa inox imbusima Ovo sam si i ja mislio ali nismo bili sigurni koliko će točno navoja ostati viriti iz glavčine??? Da li ću moći taj izvaditi ostatak šarafa iz glavčine? Link to comment Share on other sites More sharing options...
joke6 Posted March 22, 2009 Share Posted March 22, 2009 neman predođbu na kakvom je mistu al možda možeš nešto dovarit na njega Link to comment Share on other sites More sharing options...
TomiTraktor Posted March 22, 2009 Share Posted March 22, 2009 Ovo sam si i ja mislio ali nismo bili sigurni koliko će točno navoja ostati viriti iz glavčine??? Da li ću moći taj izvaditi ostatak šarafa iz glavčine? uglvnom ostane dovoljno... ako ne ostane uzmes tanki borer i zabijes ga u sredinu i onda se skrha saraf uglavnom, ali to se rijetkoooooooooo mora raditi... inace glava je od rube barem 7-8mm tako da bi tolko trebalo viriti Link to comment Share on other sites More sharing options...
huzek Posted March 22, 2009 Author Share Posted March 22, 2009 Hvala pajdo. Mislim da je ovo i najlakše Link to comment Share on other sites More sharing options...
HCC-R Posted March 22, 2009 Share Posted March 22, 2009 Neznam koliko imaš mjesta oko njega, kad se meni sjebao na poluosovini pobrusio sam rubove šarafa sa dremelom i nabio ključ 11 na njega i bez problema sam ga odšarafio... ovako nekako... Link to comment Share on other sites More sharing options...
huzek Posted March 22, 2009 Author Share Posted March 22, 2009 U rupi je. Ne može se doći do njega.... Link to comment Share on other sites More sharing options...
Roby Posted March 22, 2009 Share Posted March 22, 2009 ili torx nabit unutra, ili recimo ako je inbus 6-ica, probat nabit unutra malo pobrušen inbus 7-icu...na jedan od tih načina uvijek uspijem odserafit..naravno prije ga malo "zbombaš" cekicem da malo otpusti sa wd-om nemas kaj spricat jel logicno nemre prodrjet unutra do navoja Link to comment Share on other sites More sharing options...
Mille Posted March 22, 2009 Share Posted March 22, 2009 Najjednnostavnije je zavarit drugi šaraf za njega , i elegantno ga odšarafit .... haha . naravno ako imaš sve potrebno za taj posao ! Link to comment Share on other sites More sharing options...
matija0311 Posted March 22, 2009 Share Posted March 22, 2009 probuši šeraf i mir Link to comment Share on other sites More sharing options...
Giz Posted March 23, 2009 Share Posted March 23, 2009 nisam točno skužio di je ali svaki put do sad sam uspio na sljedeču foru. Nađem broj veči torax, zalijem WDom da otpusti i onda zagrijem fenom šeraf i mjesto oko njega. To malo omekša materijal pa zabijem čekićem torax unutra. Ohladim WDom pa ga ostavim da odstoji 10ak minuta. Nakon toga, fen na 500stupnjeva i kad je vruča sve oko šerafa on ga na trzaj cimnem. Do sad je svaki tako popustio. Link to comment Share on other sites More sharing options...
Alfaludak Posted March 23, 2009 Share Posted March 23, 2009 samo torax unutra cekicem nabijes - od lupanja po toraxu otpusti i seraf i samo ga otserafis Link to comment Share on other sites More sharing options...
Kruu Posted March 23, 2009 Share Posted March 23, 2009 Zabit torax i odšerafit jednim zgodnim alatom koji se ak se ne varam zove udarni odvijać, imam ga doma ali neznam kak se zove točno uglavnom alat sa izmjenjivim bitovima, stavi se torax (nabije čekićem), onda stavit taj udarni odvijać koji radi na principu da se udara od čekićem po osovini alata, a on prenosi silu rotiranjem. Zgodan alat koji me nekoliko puta izvukao iz gabule Evo ga: detalji ovdje: http://www.uniortools.com/cgi-bin/cms.cgi?doc=20266&prod=14888&sid=xLuehSlR0yRLhslp Adapter http://www.uniortools.com/cgi-bin/cms.cgi?doc=20266&prod=14900&sid=xLuehSlR0yRLhslp http://www.uniortools.com/cgi-bin/cms.cgi?doc=20266&prod=22741&sid=xLuehSlR0yRLhslp Link to comment Share on other sites More sharing options...
detroit Posted March 23, 2009 Share Posted March 23, 2009 ..kaj ljudi nece sve izmisliti... Link to comment Share on other sites More sharing options...
