Dinkec Posted June 18, 2009 Posted June 18, 2009 Rene, daj mi zemi onog ATE 4.0 ulja iz ducana, koliko uopce ide toga u sistem za 156 jtd?
Raptor6767 Posted June 18, 2009 Author Posted June 18, 2009 Rene, daj mi zemi onog ATE 4.0 ulja iz ducana, koliko uopce ide toga u sistem za 156 jtd? Riješeno, upravo si uzeo posljednji komad (čak sam pomislio da ih više nemam pa sam odhebo Dadu danas) - nema ni dobavljač više, dečki nisu računali da ima toliko racera. :naughty: 1L ti je više nego dovoljna...:thumbsup: P.S. Zvrcni me kada da obavimo primopredaju večeras...ideš na liz?
Raptor6767 Posted June 18, 2009 Author Posted June 18, 2009 bubinjo, Mark, Dečki, stigli vam Power diskovi! :thumbsup: Hvala na povjerenju! :notworthy: Zvrcnite me pa da dogovorimo primopredaju.
Raptor6767 Posted June 21, 2009 Author Posted June 21, 2009 Evo, novo u Motul asortimanu, za sve one koji si briju na 5.1 kočionu tekućinu. This long life synthetic fluid has a wet boiling point of 185°C/365°F and is specially designed for use with ABS. This anti-corrosive fluid is perfectly neutral with seals used in braking systems. 500ml. U mogućnosti sam nabaviti i Motul RBF 600 kočionu tekućinu (oko 140kn/L - još ne znam točno kolika će cijena biti pošto sam tek dobio info od dobavljača, samo po narudžbi): This synthetic fluid has a higher boiling point than stock fluid for operation in racing conditions. The boiling points are 312°C/593°F dry and 216°C/420°F wet. 500ml.
Noci_jr Posted June 24, 2009 Posted June 24, 2009 vilice straznje obje za vectru 2.0di '98 i škare od podizaca prozora prednjih.. kulike
GoranE46 Posted June 24, 2009 Posted June 24, 2009 mislim da je on DOT 4 kao i SRF jel su to trkaća ulja...
Raptor6767 Posted June 24, 2009 Author Posted June 24, 2009 mislim da je on DOT 4 kao i SRF jel su to trkaa ulja... Tako je. Ovaj tjedan smo na godisnjem. U ponedeljak, ako vam nije hica, odgovorim vam na upite. P.S. Povrh svega, laptop mi je na popravku, lupam po mobu.
Raptor6767 Posted June 24, 2009 Author Posted June 24, 2009 Castrol SRF? Budem se raspitao kod dobavljaca pa ti javim. Mislim da je Dado (350Z) dao 70EUR/L.
GoranE46 Posted June 24, 2009 Posted June 24, 2009 Ja sam to iz Njemačke kupovao za oko 30€ litru... u AutoHrvatskoj je oko 550kn litra.... Pa eto sve ispod toga dobro dođe... i treba mi naravno 2L:D
Raptor6767 Posted June 24, 2009 Author Posted June 24, 2009 Ja sam to iz Njemake kupovao za oko 30 litru... u AutoHrvatskoj je oko 550kn litra.... Pa eto sve ispod toga dobro doe... i treba mi naravno 2L:D Isuse, to su stvarno brutalne cifre! Javim se iduci tjedan sa cijenama...
rio_cyber Posted June 29, 2009 Posted June 29, 2009 alo sused daj jednu brusnicu.. nego imal cjena /ot on mrzi reno ali opel jos vise /ot off :jelen:
Noci_jr Posted June 29, 2009 Posted June 29, 2009 jebote rio presto si cevape jest ) normalno pises. vidis da vozim rozi jugo
Raptor6767 Posted June 29, 2009 Author Posted June 29, 2009 Decki, dobit cete sve informacije najkasnije do sutra, kaos nam je danas posto nam je prvi radni dan. Probat cu sredit nesto veci popust vis-a-vie cekanja. :thumbsup:
KrunoL Posted June 29, 2009 Posted June 29, 2009 i ja cekam vec danima ocu veci popust...:rofl::rofl: Salim se Rene nabavio ulje u 1 danu koje nema kod sebe ...:thumbsup:
Stepp Posted June 29, 2009 Posted June 29, 2009 2 Rene: možeš li mi provjeriti ima li IKAKVIH amortizera za prednju osovinu za jeep wrangler 4.0 / 1995. godina...?
Raptor6767 Posted June 29, 2009 Author Posted June 29, 2009 2 Rene: možeš li mi provjeriti ima li IKAKVIH amortizera za prednju osovinu za jeep wrangler 4.0 / 1995. godina...? Pokušat ću iskopat sutra nešto pa ti javim...
Raptor6767 Posted June 30, 2009 Author Posted June 30, 2009 2 Rene: možeš li mi provjeriti ima li IKAKVIH amortizera za prednju osovinu za jeep wrangler 4.0 / 1995. godina...? Imaš PM...mislim da ćeš biti jako zadovoljan! :thumbsup:
Bezimeni Posted June 30, 2009 Posted June 30, 2009 zanima me samo informativno cijena za kompet kumplug set za peugeot 206 1.4 ?
Raptor6767 Posted June 30, 2009 Author Posted June 30, 2009 zanima me samo informativno cijena za kompet kumplug set za peugeot 206 1.4 ? Imas PM. Inace, napises bar godiste ili kW.
Bezimeni Posted June 30, 2009 Posted June 30, 2009 Imas PM. Inace, napises bar godiste ili kW. tnx, zanimalo me samo okvirno da vidim dal me mehanicar ozenio...
Raptor6767 Posted June 30, 2009 Author Posted June 30, 2009 tnx, zanimalo me samo okvirno da vidim dal me mehanicar ozenio... I? BTW, radi se o VALEU, prvoj ugradnji.
