Jasa Posted August 27, 2009 Share Posted August 27, 2009 Help, kak se gasi taj mutavi AF na ovakvom radiu...prekopo sam cijela uputstva i nisam nista uspio naci i postiskal sve moguce gumbice, ali bez uspjeha Link to comment Share on other sites More sharing options...
rimA Posted August 27, 2009 Share Posted August 27, 2009 Kaj je AF? Link to comment Share on other sites More sharing options...
DarioB Posted August 27, 2009 Share Posted August 27, 2009 Kaj je AF? alternativna frekvencija Link to comment Share on other sites More sharing options...
Coupe VD Posted August 27, 2009 Share Posted August 27, 2009 Expert Mode In order to invoke Expert Mode, press and hold the SRC button until it goes beep. You now have a series of options you can change in a similar way to the tone controls (above). * AF (ON/OFF) controls the alternative frequency system which searches for a better frequency for the same station if reception becomes poor. Often good for national stations but not so good if reception is generally poor or for local ones. * SPEED (0-5) controls the increase in volume as you increase speed to compensate for road noise. The higher the number, the more pronounced it becomes. * LOUD (ON/OFF) a strange American invention which boosts the bass and treble at low volumes. * TUNER (AUT/MAN) setting Manual switches OFF the station seek function in Tuner Manual mode which keeps scanning until a strong enough signal is found. Instead it moves 100KHz for each click. * REAR (ON/OFF) controls the back speakers. * LIST (MAN/DYN) I’m not sure what this does. Press SRC again to leave this mode. Link to comment Share on other sites More sharing options...
Jasa Posted August 27, 2009 Author Share Posted August 27, 2009 E tooo...hvala :thumbsup: Link to comment Share on other sites More sharing options...
