bubinjo Posted December 2, 2009 Share Posted December 2, 2009 jeli moguce to nekak stavit na auto? Link to comment Share on other sites More sharing options...
the-rider Posted December 2, 2009 Share Posted December 2, 2009 http://img4.imageshack.us/img4/9992/25mmspacercloseup.jpg ovako nesto ti treba Link to comment Share on other sites More sharing options...
a112 Posted December 2, 2009 Share Posted December 2, 2009 Ili bušit glavčine ili felge ako se ne ide na adaptere. Link to comment Share on other sites More sharing options...
bubinjo Posted December 2, 2009 Author Share Posted December 2, 2009 adapteri nula bodova zato kaj je felga siroka dosta pa bi virilo i strugalo,jedino zabusit felgu al koliko je to sigurno? Link to comment Share on other sites More sharing options...
Ivsa Posted December 2, 2009 Share Posted December 2, 2009 mislim da tu nema pomoci osim s adapterima....... felgu nebi busio ni pod razno. Link to comment Share on other sites More sharing options...
Enkei Posted December 2, 2009 Share Posted December 2, 2009 adapteri nula bodova zato kaj je felga siroka dosta pa bi virilo i strugalo,jedino zabusit felgu al koliko je to sigurno? Bušit felge?? To se radi?? :huh: Link to comment Share on other sites More sharing options...
the-rider Posted December 2, 2009 Share Posted December 2, 2009 onda busiti glavcine, osim ako nemas rupe izmedu sadasnjih navoja, neki japanci znaju tako imati Link to comment Share on other sites More sharing options...
ZOD Posted December 2, 2009 Share Posted December 2, 2009 (edited) http://www.ultratuning.com/en/product-25121-pcd-adapter-from-4x100-571-to-4x108-651.html Ili na sličan način: http://i224.photobucket.com/albums/dd245/daxo84/CIMG5401.jpg Edited December 2, 2009 by ZOD Link to comment Share on other sites More sharing options...
>>>Gagi<<&l Posted December 2, 2009 Share Posted December 2, 2009 to je sve za ubit sebe i jos ljudi!!!! Link to comment Share on other sites More sharing options...
krzljavi Posted December 3, 2009 Share Posted December 3, 2009 da mi netko pokloni felge i đabe sve skemija nebi to napravio na svom autu Link to comment Share on other sites More sharing options...
Risbo Posted December 3, 2009 Share Posted December 3, 2009 Ne kužim zašto su problem ti adapteri. Ako se mogu staviti distance od 3cm i dugi šarafi, onda je ovo čak i bolje rješenje jer šarafiš u glavčinu distancu i kotač u distancu. To sve funkcionira ok i ima u Njemačkoj odobrenje TUV-a, tako da.... Link to comment Share on other sites More sharing options...
Iggy_R Posted December 3, 2009 Share Posted December 3, 2009 Ne kužim zašto su problem ti adapteri.Ako se mogu staviti distance od 3cm i dugi šarafi, onda je ovo čak i bolje rješenje jer šarafiš u glavčinu distancu i kotač u distancu. To sve funkcionira ok i ima u Njemačkoj odobrenje TUV-a, tako da.... Nije problem u adapteru nego u bušenju glavčine ili felge... a evo zašto ne može adapter... adapteri nula bodova zato kaj je felga siroka dosta pa bi virilo i strugalo Link to comment Share on other sites More sharing options...
bubinjo Posted December 3, 2009 Author Share Posted December 3, 2009 ja nemam sarafe imam navoje odnosno matice.uglavnom nasao sam dosta siroke felge sa 4x108 rupama i sad ako stavim distancu odnosno adapter viri mi navoj iz adaptera,jedino da adapter bude 3 cm debel kako risbo kaze,ali onda mi felge vire van karoserije :huh: Link to comment Share on other sites More sharing options...
Iggy_R Posted December 3, 2009 Share Posted December 3, 2009 Koliko vire? Možda možeš malo potokarit srce felge? Link to comment Share on other sites More sharing options...
bubinjo Posted December 3, 2009 Author Share Posted December 3, 2009 to neznam dok na stavim na auto,ali brijem da cu odusta previse kemije ima oko tog Link to comment Share on other sites More sharing options...
Risbo Posted December 3, 2009 Share Posted December 3, 2009 Pa isto tako možeš izbušiti glavčinu i pomaknuti rupe na 4x108 zamaknute za 45 stupnjeva. Izvadiš original šarafe i preseliš ih u nove rupe (moraš ih nabiti ili uprešati da oni zubići sjednu na tvrdo) Jedino je problem onda sa diskovima jer i njih moraš bušiti na 4x108 Daj sliku prednje i stražnje glavčine Link to comment Share on other sites More sharing options...
bubinjo Posted December 3, 2009 Author Share Posted December 3, 2009 Link to comment Share on other sites More sharing options...
semper Posted December 3, 2009 Share Posted December 3, 2009 da mi netko pokloni felge i đabe sve skemija nebi to napravio na svom autu na mom autu adapteri sa 4x108 na 4x100 zadnjih 5 godina i nikakvih problema... Link to comment Share on other sites More sharing options...
Rallye VR6 Posted December 3, 2009 Share Posted December 3, 2009 Kako volim kad lupetaju ono koji ne znaju ili nisu probali... Par stvari: Ako adapter ima TUV , onda je siguran (sve porš felge montirana na non porša su na adapterima , RH ZW1 felga serijski dolazi u 5x112 i adapterima na potrebne rupe it. ) Ako ima mjesta na glavčini , može se izbušiti , nema ama baš nikakve opasnosti (ovo imam na crnom Lupu sa 4x100 na 5x100 napravio sam hrpu km ) Može se i felga izbušiti ako je potpuno ravna na dosjedu na disk (recimo BBS koje uz to imaju i poklopac prekom šarafa pa se ne vidi , a i replike audi felgi imaji po 10 rupa) Sve ovo prolazi bez problema i potpuno je sigurno ako ona tko radi ima imalo soli u glavi i razmišlja što radi. Link to comment Share on other sites More sharing options...
a112 Posted December 3, 2009 Share Posted December 3, 2009 Ma ne valja to ništa Link to comment Share on other sites More sharing options...
