Alfaludak Posted January 24, 2010 Posted January 24, 2010 KOji je to k....? Vidio sam na jednom forumu da je lik to koristio kod mapiranja IAW marelli centraline na fiat tipu. To je neki emulator? ili koji drek?? Jel se na tom moze drkat i kutevi paljenja i gorivo ili sta? Ako to radi kupio bi to da mogu mapirati serijski fiatov ECU http://www.moates.net/product_info.php?products_id=169 http://support.moates.net/2008/09/11/ostrich-20-overview/
Alfaludak Posted January 24, 2010 Author Posted January 24, 2010 http://cgi.ebay.com/ebaymotors/Moates-Ostrich-2-0-USB-Eprom-Emulator_W0QQcmdZViewItemQQhashZitem439c55289eQQitemZ290385635486QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
kutija Posted January 24, 2010 Posted January 24, 2010 ovo je samo emulator s kojim mozes pisat po eepromu u live-modu da ne moras svaki put vadit eprom i stavljat novi. Ako ne znas gdje ti se koji podatak nalazi na epromu i sto trebas tocno promijenit opet si na pocetku tj. nikakve koristi od ovoga......
Alfaludak Posted January 24, 2010 Author Posted January 24, 2010 znaci, ja među hrpom kockica i brojeva u bin fileu moram znat kaj je kaj? LOL poslao sam liku koji je radiuo sa tim na tom fiatu ali nemam nikakvog odgovora vec danima.... http://www.guy-croft.com/viewtopic.php?f=5&t=963&hilit=fiat+tipo pa pogledaj
Mitja Posted January 24, 2010 Posted January 24, 2010 Emulator. Onda ti treba i EPROM programator, da snimis EPROM. Za vecimu auta se dobiju programi, preko kojih mozes korigirati mape paljennja, benzina i slicno putem takog emulatora. Ali nisu jeftini.
Zvonimir_G. Posted January 24, 2010 Posted January 24, 2010 Ima u susjeda rijesenje za IAW http://rp-lab.com/map_editor.shtml
charger Posted January 24, 2010 Posted January 24, 2010 Najkraće i logičnije objašnjenje Its a chip emulator. Simply put, it replaces the "chip" in the ECU socket and allows you to change the tune in real time. Then you can save that tune and burn it to a chip. Then remove the ostrich, replace with the newly tuned chip and close up the ECU.
Alfaludak Posted January 24, 2010 Author Posted January 24, 2010 sa deckima iz RPlab sam se cuo prije dobre 4 godine, mrvicu preskupo moram priznat je bilo tada, cca 1000 eura mitja, jel mozes naci sta mi treba da bi ovo radilo na IAW-u? i da bi te bin fajlove mogao vidit u necemu prepoznatljivom eprom programator imam
killercivic Posted January 25, 2010 Posted January 25, 2010 looool , alfa to je samo eprom emulator a ne softwer za mapiranje dakle samo s tim nemoš niš šta to treba namapirat budem ti ja, koji IAW ?
Alfaludak Posted January 25, 2010 Author Posted January 25, 2010 nemos ni ti trebam real time mapiranje, ti mi mozes sprzit eprom
killercivic Posted January 25, 2010 Posted January 25, 2010 nemos ni ti trebam real time mapiranje, ti mi mozes sprzit eprom pa to ti je to sam sejvaš eprom i uplodaš ga preko ostriča, ko na megasquirtu kad stisneš sejv ili upload neznam sad. nemoraš ni palit-gasit auto čim dobije nove mape skuži ih
Akula Posted January 25, 2010 Posted January 25, 2010 prekomplicirano... ovo je jedno od fenomenalnih rješenja (hardverskih) http://www.nistune.com/
Mitja Posted January 25, 2010 Posted January 25, 2010 Mozes sa emulatorom isto realtime mapirat. Zato se i ozve emulator. Samo treba pravi program, koji zna na kojim lokacijama Eproma su mape.
Alfaludak Posted January 25, 2010 Author Posted January 25, 2010 mitja jel znas koji je program za marelli iaw
kutija Posted January 25, 2010 Posted January 25, 2010 svaki iaw ti je razlicit..... upilaj nikolu da ti nesto jeftinije rijesi jel zna gdje se sta nalazi na lancia/fiat tim iawima i moze svasta napravit za taj iaw samo zavisi koliko ce ti izac u susret. Ford iaw je razbio totalno i svasta ima za njega napravljeno. Ja ga pilao za moj iaw,ali nije bilo isplativo.....
Mitja Posted January 25, 2010 Posted January 25, 2010 Kolega koristi taj program , gotovo su gore mape za sve evropske aute. Ali moras dovesti auto u SLO do Avtoelektronike. Inace je to prilicno skupo za kupit.
killercivic Posted January 26, 2010 Posted January 26, 2010 mitja jel znas koji je program za marelli iaw alfa koji iaw? sve brojeve s centrale mi prepiši, šta si mu mjenjo injektore? turbinu? da ga treba real-time mapirat?
Alfaludak Posted January 26, 2010 Author Posted January 26, 2010 nisam jos mjenjao ali je decko kupio dijelove intercooler, injektore, bosch044, bregaste, usisna grana, i jednostavno bez remapa to je kita samo moze nesto poci po zlu ili stavit ms/vems
killercivic Posted January 26, 2010 Posted January 26, 2010 (edited) nisam jos mjenjao ali je decko kupio dijelove intercooler, injektore, bosch044, bregaste, usisna grana, i jednostavno bez remapa to je kita samo moze nesto poci po zlu ili stavit ms/vems pa ima neka formula da se tablica injectiona preračuna na veće injektore, kak ima u chrome za honde. extrudabody.com/TechInfo/InjectorCalc1.0.xls Edited January 26, 2010 by killercivic
