jura_vw Posted February 18, 2010 Share Posted February 18, 2010 ovako trebam si napravit adaptere za felge sa 4x100 na 5x100. koji materijal da koristim? obični aluminij mi se čini premekan, a od prokroma ići delat koji je pretežak opet ne valjda... dali je cijenom povoljan možda duraluminij i dali toga ima kod nas za kupit.... Link to comment Share on other sites More sharing options...
Marko Posted February 18, 2010 Share Posted February 18, 2010 (edited) kolko para mislis potrosit? edit: imas naravno strojopromet, za malo skuplje stvari imas bohler na zitnjaku Edited February 18, 2010 by Marko Link to comment Share on other sites More sharing options...
jura_vw Posted February 18, 2010 Author Share Posted February 18, 2010 kolko para mislis potrosit? onolko koliko mi je potrebno da napravim adaptere... :doh: Link to comment Share on other sites More sharing options...
Mexx Posted February 18, 2010 Share Posted February 18, 2010 pa zasto nebi kupio vec gotove adaptere? mislim da su oni alu... Link to comment Share on other sites More sharing options...
jura_vw Posted February 18, 2010 Author Share Posted February 18, 2010 pa zasto nebi kupio vec gotove adaptere?mislim da su oni alu... pa kombiniram kaj me jeftinije dođe... tokarenje mi je đabe, pa ono... malo skupljam info Link to comment Share on other sites More sharing options...
Mexx Posted February 18, 2010 Share Posted February 18, 2010 (edited) evo malo prijedlog za amterijal The adapters are fabricated from a suitable billet of 6061-T6 or similar specification aluminum. The billet is then CNC machined for precise tolerances and a perfect fit. Heavy Duty M12x1.50 studs can be pressed into the adapter for unrivalled strength. Short open ended lugnuts may be included with the adapter pair. al 6061 je materijal koje svi proizvodaci koriste za izradu Edited February 18, 2010 by Mexx Link to comment Share on other sites More sharing options...
KIMI_1.8T Posted February 18, 2010 Share Posted February 18, 2010 (edited) Puno je pametnija stvar probusiti dodatne 4 rupe na rukavcima i diskovima. Provjereno. Nikako ne narezivati navoj koji bi trebao drzati kotac u aluminiju!! Edited February 18, 2010 by KIMI_1.8T Link to comment Share on other sites More sharing options...
master_og Posted February 18, 2010 Share Posted February 18, 2010 a izbušiti rupe nove??? Link to comment Share on other sites More sharing options...
Bara Posted February 18, 2010 Share Posted February 18, 2010 izbuši 4 nove rupe, jednu staru koristiš i to je to, najbolje rješeje... Link to comment Share on other sites More sharing options...
jura_vw Posted February 18, 2010 Author Share Posted February 18, 2010 napred će mi biti tako, a iza moram tak i tak delat distancu jer mi je felga dosta unutra, pa sam mislio umjesto distance domah napraviti adapter i zdravo Link to comment Share on other sites More sharing options...
master_og Posted February 18, 2010 Share Posted February 18, 2010 napred će mi biti tako, a iza moram tak i tak delat distancu jer mi je felga dosta unutra, pa sam mislio umjesto distance domah napraviti adapter i zdravo a svi viču da adapter treba biti barem 2cm debel da bi to sve valjalo, jel ti treba tolka distanca Link to comment Share on other sites More sharing options...
jura_vw Posted February 18, 2010 Author Share Posted February 18, 2010 a svi viču da adapter treba biti barem 2cm debel da bi to sve valjalo, jel ti treba tolka distanca treba mi 25mm Link to comment Share on other sites More sharing options...
Risbo Posted February 18, 2010 Share Posted February 18, 2010 ja ti imam usadne vijke pa možeš kombinirati s njima. fiksiraš ih u glavčinu pa onda staviš samo distancu preko i onda ona ništa ne nosi. Onda možeš raditi i od običnog aluminija Link to comment Share on other sites More sharing options...
