jura_vw Posted February 18, 2010 Posted February 18, 2010 ovako trebam si napravit adaptere za felge sa 4x100 na 5x100. koji materijal da koristim? obični aluminij mi se čini premekan, a od prokroma ići delat koji je pretežak opet ne valjda... dali je cijenom povoljan možda duraluminij i dali toga ima kod nas za kupit....
Marko Posted February 18, 2010 Posted February 18, 2010 (edited) kolko para mislis potrosit? edit: imas naravno strojopromet, za malo skuplje stvari imas bohler na zitnjaku Edited February 18, 2010 by Marko
jura_vw Posted February 18, 2010 Author Posted February 18, 2010 kolko para mislis potrosit? onolko koliko mi je potrebno da napravim adaptere... :doh:
Mexx Posted February 18, 2010 Posted February 18, 2010 pa zasto nebi kupio vec gotove adaptere? mislim da su oni alu...
jura_vw Posted February 18, 2010 Author Posted February 18, 2010 pa zasto nebi kupio vec gotove adaptere?mislim da su oni alu... pa kombiniram kaj me jeftinije dođe... tokarenje mi je đabe, pa ono... malo skupljam info
Mexx Posted February 18, 2010 Posted February 18, 2010 (edited) evo malo prijedlog za amterijal The adapters are fabricated from a suitable billet of 6061-T6 or similar specification aluminum. The billet is then CNC machined for precise tolerances and a perfect fit. Heavy Duty M12x1.50 studs can be pressed into the adapter for unrivalled strength. Short open ended lugnuts may be included with the adapter pair. al 6061 je materijal koje svi proizvodaci koriste za izradu Edited February 18, 2010 by Mexx
KIMI_1.8T Posted February 18, 2010 Posted February 18, 2010 (edited) Puno je pametnija stvar probusiti dodatne 4 rupe na rukavcima i diskovima. Provjereno. Nikako ne narezivati navoj koji bi trebao drzati kotac u aluminiju!! Edited February 18, 2010 by KIMI_1.8T
Bara Posted February 18, 2010 Posted February 18, 2010 izbuši 4 nove rupe, jednu staru koristiš i to je to, najbolje rješeje...
jura_vw Posted February 18, 2010 Author Posted February 18, 2010 napred će mi biti tako, a iza moram tak i tak delat distancu jer mi je felga dosta unutra, pa sam mislio umjesto distance domah napraviti adapter i zdravo
master_og Posted February 18, 2010 Posted February 18, 2010 napred će mi biti tako, a iza moram tak i tak delat distancu jer mi je felga dosta unutra, pa sam mislio umjesto distance domah napraviti adapter i zdravo a svi viču da adapter treba biti barem 2cm debel da bi to sve valjalo, jel ti treba tolka distanca
jura_vw Posted February 18, 2010 Author Posted February 18, 2010 a svi viču da adapter treba biti barem 2cm debel da bi to sve valjalo, jel ti treba tolka distanca treba mi 25mm
Risbo Posted February 18, 2010 Posted February 18, 2010 ja ti imam usadne vijke pa možeš kombinirati s njima. fiksiraš ih u glavčinu pa onda staviš samo distancu preko i onda ona ništa ne nosi. Onda možeš raditi i od običnog aluminija
