Drag_steer Posted September 2, 2010 Author Posted September 2, 2010 kw je inox a i vidim da ima kao dvije opruge na prednjem amortizeru... vjerojatno prednost kad ga se skroz spusti.
Rallye VR6 Posted September 2, 2010 Posted September 2, 2010 KW var 1 ima uloške koji gotovi dolaze u KW i samo se ubacuju unutra , a Var. 2 se RUČNO slaže , svaki amortizer posebno. Podmarka KW-a je weitec , a ne Lowtec.
jura_vw Posted September 2, 2010 Posted September 2, 2010 ne, ima i v1 od inoxa... ja ih imam i meni su super gewinde, nikakvih zamjerki..
Drag_steer Posted September 2, 2010 Author Posted September 2, 2010 izgleda da nije http://www.kw-suspensions.eu/int/kw_variant_1.php samo se nadam da nije neoudoban i da ne lupeta preko jacih rupa... ako je spusten mozda 3 , 4 cm u odnosu na serijski.
fokusicar Posted September 2, 2010 Posted September 2, 2010 nabavis si lowtec,al sa stelanjem tvrdoce.isti proizvod ko KW jer je pomarka od KW.daleko jeftinije a ista roba. Lowtec nema apsolutno nikakve veze sa KW-om ili Weitecom...:doh:
Drag_steer Posted September 2, 2010 Author Posted September 2, 2010 neznam da li je tolika razlika izmedju kw var1 i weiteca.... ono sto ja znam je da weitec nije inox i vidim da ima naprijed jednu oprugu a kw ima 2...
jura_vw Posted September 2, 2010 Posted September 2, 2010 kako, pa ima i weitec dvije opruge, samo što je kod weiteca ta opruga dole, a kod kw-a gore http://www.tuningracingcars27.com/images/combines_filetes_weitec.gif
Drag_steer Posted September 2, 2010 Author Posted September 2, 2010 jbg sad tek vidim znaci glavna mana weiteca je sto nije inox ...
STFIESTAST Posted September 2, 2010 Posted September 2, 2010 razmišljamo o istom gewindice mmm:thumbsup:
Dominik Posted September 2, 2010 Posted September 2, 2010 druga (mala ) opruga sluzi samo da glavna ne laprda kad dignes auto na dizalicu, nema nikakvu drugu funkciju
Drag_steer Posted September 2, 2010 Author Posted September 2, 2010 ok. nisam znao to.... stfiesta: sta kw ili weitec ces uzet
Goertosing Posted September 3, 2010 Posted September 3, 2010 Da ne otvaram novu temu, zanima me zna li tko dal se mogu negdje gewinde (il kraci amortizeri s kracim oprugama, ...nebitno) isprobati na svom autu prije kupnje, tj. da se kupe i montiraju al da postoji mogucnost povrata robe i punog iznosa novca za slucaj da nisu onakve kakvima ih se opisuje? Svejedno dal HR, SLO, A,... Jednom sam se opekao s skupim gewindama, a koje je tesko prodat dalje i s velikim gubitkom na cijeni...Malo mi je previše opet riskirat i dat hrpu love za nešto što ne znam kako ce se ponašati na autu, cak i kad se radi o 'brendu' i bez obzira na razne preporuke. Gdje god sam se raspitivao po ZG, pod jamstvom su obuhvaceni samo konkretni kvarovi ali ne i (debela) razlika između stvarnih i reklamiranih specifikacija
Gabre Posted September 3, 2010 Posted September 3, 2010 to ćeš eventualno u austriji ili njemačkoj moždaaaa moć napravit...
charger Posted September 3, 2010 Posted September 3, 2010 mislim da bi ti se svatko bilo gdje smijao u facu kad bi mu došao sa tim zahtjevom... al sama ideja je vrhunska...NOT
Uros Posted September 3, 2010 Posted September 3, 2010 ideja je isto ko da malo isprobaš gume pa vratiš jer ti nisu baš ....jao kaj se sve ljudi neće sjetiti.....
rimA Posted September 3, 2010 Posted September 3, 2010 Ajde ovjeri povrat pa pređi sa time,jedino ako vas 5 iz obitelji ide :thumbsup: Ja sam čovjeku napisao koliko košta... nisam ja njemu objašnjavao kako da prelazi granicu
golfijaner Posted September 3, 2010 Posted September 3, 2010 na mojim weitec gewindama nema malih opruga hm
jady Posted September 3, 2010 Posted September 3, 2010 To ti je sigurno ispričao onaj koji prodaje Lowtec... :samoubica: ne,nego iz tvornice KW-weitec putem maila,a i uocljivo iz raznih njemackih foruma
Rallye VR6 Posted September 3, 2010 Posted September 3, 2010 ne,nego iz tvornice KW-weitec putem maila,a i uocljivo iz raznih njemackih foruma Ja bio u KW tvornici i nitko nikad tamo nije spomenio Lowtec niti sam vidio tamo išta od Lowteca.
malawi Posted September 3, 2010 Posted September 3, 2010 Ja bio u KW tvornici i nitko nikad tamo nije spomenio Lowtec niti sam vidio tamo išta od Lowteca. covjek misli na weitec :thumbsup:
BaGy Posted September 3, 2010 Posted September 3, 2010 covjek misli na weitec :thumbsup: ne na lowtec misli
